Home » Modeling » EMF » Validating Ecore models with independent OCL fragments
Validating Ecore models with independent OCL fragments [message #1697430] Wed, 03 June 2015 20:48 Go to next message
Edoaurd Batot is currently offline Edoaurd BatotFriend
Member
Hi folks !
Ed, how are you ? Enjoying the spring ?
Well, I'd like to test the models I've generated. I'd like to test them programmatically (no use of any UI) with OCL constraints generated programaticcally (I enjoy automation).
My question is : can anybody point me out a simple example to test a model (Ecore from XMI, with Resource etc.) with a String containing OCL constraint ?
Or, le cas échéant, a right API to tackle with that process...
I've got the org.eclipse.ocl.* in my build path, but still can change for a Dresden API, or anything if necessary/recomended.
Don't sell me tool or technology, please, I want it API style.
Thanks for your colaboration, have a great time.
Edouard
[Updated on: Wed, 03 June 2015 21:00]
Report message to a moderator
Re: Validating Ecore models with independent OCL fragments [message #1697431 is a reply to message #1697430] Wed, 03 June 2015 21:08 Go to previous messageGo to next message
Christian Damus is currently offline Christian DamusFriend
Hi, Edouard,
I would imagine that the JUnit tests in the Eclipse OCL project's git
repository have plenty of examples of evaluating OCL expressions on
instances of Ecore models loaded from XMI resources:
http://git.eclipse.org/c/ocl/org.eclipse.ocl.git/
HTH,
Christian
On 2015-06-03 20:48:15 +0000, Edoaurd Batot said:
> Hi folks !
> constraint ?
> Edouard
Re: Validating Ecore models with independent OCL fragments [message #1697436 is a reply to message #1697431] Wed, 03 June 2015 22:01 Go to previous message
Member
I like the guess, and your imagination sounds fertile, but... That's a pretty heavy direction, isn't it ?!
Previous Topic:container vs containment
Next Topic:[CDO] Builing cdo on builserver
Current Time: Wed Jul 15 05:33:23 GMT 2020
Powered by FUDForum. Page generated in 0.06552 seconds
