Re: [ATL] how to delete an element used do block in matched rules [message #33049 is a reply to message #33014] |
Sun, 22 April 2007 11:54   |
Originally posted by: marcos.didonet-del-fabro.univ-nantes.fr
usually you should not modify the output model.
In your case I suggest to put a filter in the guard of the rule to not allow creating the
element.
Marcos.
jihed wrote:
> Hi..
> After using matched rules.. i want to know if it's possible to delete in
> do{} sections some elements genrated by matched rules...?
> IF yes How we can do it ?
> Thank you for answer ...
Re: [ATL] how to delete an element used do block in matched rules [message #33152 is a reply to message #33049] |
Sun, 22 April 2007 14:22   |
Originally posted by: touzitou.enstimac.fr
Hello;
The problem is that making a filter seems to be very heavy(it takes time
to evaluate the guard and compare values) that's why i want to generate
needed elements using called rules applied to the generated model and
after to delete elements i don't need !!
a++
Jihed
Marcos Didonet Del Fabro a écrit :
> Hello,
> allow creating the element.
> Regards,
> Marcos.
> jihed wrote:
>> Hi..
>> in do{} sections some elements genrated by matched rules...?
FUDForum. Page generated in 0.01944 seconds
