Home » Eclipse Projects » WindowBuilder » WindowBuilder does not install on Mars SR3
WindowBuilder does not install on Mars SR3 [message #1697009] Sat, 30 May 2015 22:44 Go to next message
Vincenzo Caselli is currently offline Vincenzo CaselliFriend
Trying to install WB on latest Mars RC3 fails with the error below.
I tried with previous releases of Mars (RC2a and RC1) and all goes well.
My environment is:
- Windows 8.1 64 bit
- Java 7 64bit
- Eclipse Mars 64bit RC3 Build id: I20150528-0700
Any hint?
Thank you
Vincenzo
An error occurred while collecting items to be installed
session context was:(profile=SDKProfile, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
Problems downloading artifact: osgi.bundle,org.eclipse.wb.core.lib,1.8.0.r45x201412082350.
File has invalid content:C:\Users\Vincenzo\AppData\Local\Temp\signatureFile193664623116537112.jar
Invalid content:lib/asm-all-3.3.1.jar
The file "lib/asm-all-3.3.1.jar" in the jar "C:\Users\Vincenzo\AppData\Local\Temp\signatureFile193664623116537112.jar" has been tampered!
Invalid content:lib/commons-collections-3.2.1.jar
The file "lib/commons-collections-3.2.1.jar" in the jar "C:\Users\Vincenzo\AppData\Local\Temp\signatureFile193664623116537112.jar" has been tampered!
Invalid content:lib/MVEL-fork.jar
The file "lib/MVEL-fork.jar" in the jar "C:\Users\Vincenzo\AppData\Local\Temp\signatureFile193664623116537112.jar" has been tampered!
Invalid content:lib/nebula-cwt.jar
The file "lib/nebula-cwt.jar" in the jar "C:\Users\Vincenzo\AppData\Local\Temp\signatureFile193664623116537112.jar" has been tampered!
Invalid content:lib/nebula-cdatetime.jar
The file "lib/nebula-cdatetime.jar" in the jar "C:\Users\Vincenzo\AppData\Local\Temp\signatureFile193664623116537112.jar" has been tampered!
Invalid content:lib/commons-beanutils-1.8.0.jar
The file "lib/commons-beanutils-1.8.0.jar" in the jar "C:\Users\Vincenzo\AppData\Local\Temp\signatureFile193664623116537112.jar" has been tampered!
Invalid content:lib/commons-digester-2.0.jar
The file "lib/commons-digester-2.0.jar" in the jar "C:\Users\Vincenzo\AppData\Local\Temp\signatureFile193664623116537112.jar" has been tampered!
Invalid content:lib/commons-lang-2.5.jar
The file "lib/commons-lang-2.5.jar" in the jar "C:\Users\Vincenzo\AppData\Local\Temp\signatureFile193664623116537112.jar" has been tampered!
Invalid content:lib/commons-io-2.0.1.jar
The file "lib/commons-io-2.0.1.jar" in the jar "C:\Users\Vincenzo\AppData\Local\Temp\signatureFile193664623116537112.jar" has been tampered!
Invalid content:lib/guava-13.0.1.jar
The file "lib/guava-13.0.1.jar" in the jar "C:\Users\Vincenzo\AppData\Local\Temp\signatureFile193664623116537112.jar" has been tampered!
Invalid content:lib/commons-primitives-1.0.jar
The file "lib/commons-primitives-1.0.jar" in the jar "C:\Users\Vincenzo\AppData\Local\Temp\signatureFile193664623116537112.jar" has been tampered!
Invalid content:lib/commons-logging-1.1.1.jar
The file "lib/commons-logging-1.1.1.jar" in the jar "C:\Users\Vincenzo\AppData\Local\Temp\signatureFile193664623116537112.jar" has been tampered!
Problems downloading artifact: osgi.bundle,org.eclipse.wb.rcp.swing2swt,1.8.0.r45x201412090039.
File has invalid content:C:\Users\Vincenzo\AppData\Local\Temp\signatureFile7710241417194737139.jar
Invalid content:swing2swt.jar
The file "swing2swt.jar" in the jar "C:\Users\Vincenzo\AppData\Local\Temp\signatureFile7710241417194737139.jar" has been tampered!
Problems downloading artifact: osgi.bundle,org.eclipse.wb.runtime.lib,1.8.0.r45x201412082350.
File has invalid content:C:\Users\Vincenzo\AppData\Local\Temp\signatureFile108906935212993756.jar
Invalid content:lib/cglib-nodep-2.2.jar
The file "lib/cglib-nodep-2.2.jar" in the jar "C:\Users\Vincenzo\AppData\Local\Temp\signatureFile108906935212993756.jar" has been tampered!
Re: WindowBuilder does not install on Mars SR3 [message #1697026 is a reply to message #1697009] Sun, 31 May 2015 16:38 Go to previous messageGo to next message
Eric Clayberg is currently offline Eric ClaybergFriend
RC3 changed the packaging rules for plugins, so we need to change the WB build to comply with those changes.
Use RC2 until we have a compatible build.
Re: WindowBuilder does not install on Mars SR3 [message #1697046 is a reply to message #1697026] Mon, 01 June 2015 08:11 Go to previous messageGo to next message
Thank you Eric!
I'll keep using RC2a for a while.
Where can I stay tuned (this post? official WB page?) in order to be notified as soon as the WB build is back again on track ?
Thank you very much for the answer and for the your huge great work on WB!!!
Cheers
Vincenzo
Re: WindowBuilder does not install on Mars SR3 [message #1697095 is a reply to message #1697046] Mon, 01 June 2015 14:24 Go to previous message
We'll reply to this post once it's available.
Previous Topic:Design view showing exceptions
Next Topic:Window Builder causes a copy of the project to run, and it will not close?
Current Time: Tue Jul 14 23:58:34 GMT 2020
Powered by FUDForum. Page generated in 0.01569 seconds
