Home » Eclipse Projects » Oomph » Startup Tasks not executing on redirected catalog
Startup Tasks not executing on redirected catalog [message #1696971] Fri, 29 May 2015 20:35 Go to next message
Michael  Haeusler is currently offline Michael HaeuslerFriend
I tried to prepare my own project catalog as mentioned here. https://wiki.eclipse.org/Eclipse_Oomph_Authoring
with the little difference that I do not host the setup files on a webserver but use local file refererences.
preparing the new Eclipse instance works without problems, however the startup tasks are not executed and they are not showing up if I click "Perform Setup Tasks..." in the help menu.
finally I figured out what the problem is:
in my oomph.ini I have the following redirection:
-Doomph.redirection.setup=http://git.eclipse.org/c/oomph/org.eclipse.oomph.git/plain/setups/->catalog/
however in the eclipse.ini of the new Eclipse instance I get these entries:
-Doomph.redirection.index.redirection=index:/->file:/c:/development/oomph/catalog
-Doomph.redirection.index.location.redirection=http://git.eclipse.org/c/oomph/org.eclipse.oomph.git/plain/setups/->file:/c:/development/oomph/catalog
what happens is that the new Eclipse instance does not find my setup files and therefore does not execute anything at all.
I manually changed the eclipse.ini to this
-Doomph.redirection.index.redirection=index:/->file:/c:/development/oomph/catalog/
-Doomph.redirection.index.location.redirection=http://git.eclipse.org/c/oomph/org.eclipse.oomph.git/plain/setups/->file:/c:/development/oomph/catalog/
So I assume this might be a bug which is related to the file:/ URL because it seems to work correct when using an http redirect URL in the oomph.ini.
would be great if this could be fixed before final Mars release Very Happy
Re: Startup Tasks not executing on redirected catalog [message #1697090 is a reply to message #1696971] Mon, 01 June 2015 13:39 Go to previous messageGo to next message
Michael,
Comments below.
On 01/06/2015 3:16 PM, Michael äusler wrote:
> Hello,
Is it literally like this? The thing after the -> should be an
absolute file:... URI. Is that not the case?
> entries:
> the oomph.ini.
> would be great if this could be fixed before final Mars release :d
Ed Merks
Re: Startup Tasks not executing on redirected catalog [message #1698173 is a reply to message #1697090] Thu, 11 June 2015 20:07 Go to previous messageGo to next message
yes it was intentionally that the redirect is to a relative path, because I want to use this distribution (including the setup redirection) in our company.
and it is almost works correct with the relative path, except for the missing slash at the end of the redirect.
Re: Startup Tasks not executing on redirected catalog [message #1698363 is a reply to message #1698173] Mon, 15 June 2015 06:42 Go to previous message
Michael,
What is it supposed to be relative to?
Ed Merks
Previous Topic:Eclipse Installer, Windows standard user and User Account Control
Next Topic:Undesirable Preference Recorder Behavior in Java EE EPP
Current Time: Thu Jan 23 08:20:29 GMT 2025
Powered by FUDForum. Page generated in 0.04122 seconds
