Home » Archived » Eclipse Process Manager (Stardust) » Cannot login to IPP-Portal at the first time after setup Application Server (Weblogic 12c)
Cannot login to IPP-Portal at the first time after setup Application Server (Weblogic 12c) [message #1696948] Fri, 29 May 2015 16:13 Go to next message
Biyuki Hana is currently offline Biyuki HanaFriend
Hi there,
Follow this document:
http://help.eclipse.org/luna/index.jsp?topic=%2Forg.eclipse.stardust.docs.dev%2Fhtml%2Fexamples%2Fdms%2Freadme.html
I just successfully deploy carnot.ear to Weblogic 12c and connecting with Audit trail (Oracle 11g) done also:
index.php/fa/22006/0/
index.php/fa/22007/0/
But when I login into IPP Portal using "motu" user, it message to me "Unknown Error" (if I type password: "motu"), in case I type wrong password It show: "AUTHx00123 - User 'motu' (Realm: 'carnot') does not exist or invalid password submitted."
index.php/fa/22008/0/
index.php/fa/22009/0/
Here 's WORKFLOWUSER table in my audit database:
index.php/fa/22010/0/
I try some way but currently Idon't know how to resolve this problem, so please help me.
Thanks you
Re: Cannot login to IPP-Portal at the first time after setup Application Server (Weblogic 12c) [message #1696951 is a reply to message #1696948] Fri, 29 May 2015 16:18 Go to previous messageGo to next message
Andreas Mueller is currently offline Andreas MuellerFriend
do you have a log file extract? I would be surprised if the log wouldn't show a stack trace.
Andreas
Re: Cannot login to IPP-Portal at the first time after setup Application Server (Weblogic 12c) [message #1696979 is a reply to message #1696951] Sat, 30 May 2015 01:01 Go to previous message
Hi Andreas,
Here is log file from weblogic:
[ServletContext@160602778[app:carnot-8.2.0 module:/ipp-portal path:null spec-version:3.0]] Root cause of ServletException. java.lang.Exception: java.lang.IllegalStateException: Response already committed at com.icesoft.faces.context.View.reportException(View.java:319) at com.icesoft.faces.context.View.servePage(View.java:201) at com.icesoft.faces.webapp.http.core.MultiViewServer.service(MultiViewServer.java:106) at com.icesoft.faces.webapp.http.common.ServerProxy.service(ServerProxy.java:43) at com.icesoft.faces.webapp.http.servlet.MainSessionBoundServlet$4.service(MainSessionBoundServlet.java:187) at com.icesoft.faces.webapp.http.servlet.BasicAdaptingServlet.service(BasicAdaptingServlet.java:51) at com.icesoft.faces.webapp.http.servlet.PathDispatcher.service(PathDispatcher.java:55) at com.icesoft.faces.webapp.http.servlet.SessionDispatcher.service(SessionDispatcher.java:107) at com.icesoft.faces.webapp.http.servlet.PathDispatcher.service(PathDispatcher.java:55) at com.icesoft.faces.webapp.http.servlet.MainServlet.service(MainServlet.java:204) at javax.servlet.http.HttpServlet.service(HttpServlet.java:844) at weblogic.servlet.internal.StubSecurityHelper$ServletServiceAction.run(StubSecurityHelper.java:280) at weblogic.servlet.internal.StubSecurityHelper$ServletServiceAction.run(StubSecurityHelper.java:254) at weblogic.servlet.internal.StubSecurityHelper.invokeServlet(StubSecurityHelper.java:136) at weblogic.servlet.internal.ServletStubImpl.execute(ServletStubImpl.java:341) at weblogic.servlet.internal.TailFilter.doFilter(TailFilter.java:25) at weblogic.servlet.internal.FilterChainImpl.doFilter(FilterChainImpl.java:79) at org.eclipse.stardust.ui.web.html5.EnhancedJarResourceFilter.doFilter(EnhancedJarResourceFilter.java:140) at weblogic.servlet.internal.FilterChainImpl.doFilter(FilterChainImpl.java:79) at org.eclipse.stardust.ui.web.viewscommon.login.filter.LoginFilter.doFilter(LoginFilter.java:324) at weblogic.servlet.internal.FilterChainImpl.doFilter(FilterChainImpl.java:79) at weblogic.servlet.internal.RequestDispatcherImpl.invokeServlet(RequestDispatcherImpl.java:574) at weblogic.servlet.internal.RequestDispatcherImpl.forward(RequestDispatcherImpl.java:272) at org.eclipse.stardust.ui.web.plugin.support.PluginResourceRequestProcessor.handleRequest(PluginResourceRequestProcessor.java:107) at org.eclipse.stardust.ui.web.plugin.support.PortalPluginContentFilter.doFilter(PortalPluginContentFilter.java:69) at weblogic.servlet.internal.FilterChainImpl.doFilter(FilterChainImpl.java:79) at weblogic.servlet.internal.RequestEventsFilter.doFilter(RequestEventsFilter.java:27) at weblogic.servlet.internal.FilterChainImpl.doFilter(FilterChainImpl.java:79) at weblogic.servlet.internal.WebAppServletContext$ServletInvocationAction.wrapRun(WebAppServletContext.java:3367) at weblogic.servlet.internal.WebAppServletContext$ServletInvocationAction.run(WebAppServletContext.java:3333) at weblogic.security.acl.internal.AuthenticatedSubject.doAs(AuthenticatedSubject.java:321) at weblogic.security.service.SecurityManager.runAs(SecurityManager.java:120) at weblogic.servlet.provider.WlsSubjectHandle.run(WlsSubjectHandle.java:57) at weblogic.servlet.internal.WebAppServletContext.doSecuredExecute(WebAppServletContext.java:2220) at weblogic.servlet.internal.WebAppServletContext.securedExecute(WebAppServletContext.java:2146) at weblogic.servlet.internal.WebAppServletContext.execute(WebAppServletContext.java:2124) at weblogic.servlet.internal.ServletRequestImpl.run(ServletRequestImpl.java:1564) at weblogic.servlet.provider.ContainerSupportProviderImpl$WlsRequestExecutor.run(ContainerSupportProviderImpl.java:254) at weblogic.work.ExecuteThread.execute(ExecuteThread.java:295) at weblogic.work.ExecuteThread.run(ExecuteThread.java:254) Caused By: java.lang.IllegalStateException: Response already committed at weblogic.servlet.internal.ServletResponseImpl.objectIfCommitted(ServletResponseImpl.java:1672) at weblogic.servlet.internal.ServletResponseImpl.sendRedirect(ServletResponseImpl.java:877) at weblogic.servlet.internal.ServletResponseImpl.sendRedirect(ServletResponseImpl.java:873) at org.eclipse.stardust.ui.web.common.PortalD2DFaceletViewHandler.renderView(PortalD2DFaceletViewHandler.java:110) at org.apache.myfaces.lifecycle.RenderResponseExecutor.execute(RenderResponseExecutor.java:41) at org.apache.myfaces.lifecycle.LifecycleImpl.render(LifecycleImpl.java:132) at com.icesoft.faces.webapp.http.core.JsfLifecycleExecutor.apply(JsfLifecycleExecutor.java:51) at com.icesoft.faces.context.View$2$1.respond(View.java:86) at com.icesoft.faces.webapp.http.servlet.ServletRequestResponse.respondWith(ServletRequestResponse.java:242) at com.icesoft.faces.context.View$2.serve(View.java:120) at com.icesoft.faces.context.View.servePage(View.java:193) at com.icesoft.faces.webapp.http.core.MultiViewServer.service(MultiViewServer.java:106) at com.icesoft.faces.webapp.http.common.ServerProxy.service(ServerProxy.java:43) at com.icesoft.faces.webapp.http.servlet.MainSessionBoundServlet$4.service(MainSessionBoundServlet.java:187) at com.icesoft.faces.webapp.http.servlet.BasicAdaptingServlet.service(BasicAdaptingServlet.java:51) at com.icesoft.faces.webapp.http.servlet.PathDispatcher.service(PathDispatcher.java:55) at com.icesoft.faces.webapp.http.servlet.SessionDispatcher.service(SessionDispatcher.java:107) at com.icesoft.faces.webapp.http.servlet.PathDispatcher.service(PathDispatcher.java:55) at com.icesoft.faces.webapp.http.servlet.MainServlet.service(MainServlet.java:204) at javax.servlet.http.HttpServlet.service(HttpServlet.java:844) at weblogic.servlet.internal.StubSecurityHelper$ServletServiceAction.run(StubSecurityHelper.java:280) at weblogic.servlet.internal.StubSecurityHelper$ServletServiceAction.run(StubSecurityHelper.java:254) at weblogic.servlet.internal.StubSecurityHelper.invokeServlet(StubSecurityHelper.java:136) at weblogic.servlet.internal.ServletStubImpl.execute(ServletStubImpl.java:341) at weblogic.servlet.internal.TailFilter.doFilter(TailFilter.java:25) at weblogic.servlet.internal.FilterChainImpl.doFilter(FilterChainImpl.java:79) at org.eclipse.stardust.ui.web.html5.EnhancedJarResourceFilter.doFilter(EnhancedJarResourceFilter.java:140) at weblogic.servlet.internal.FilterChainImpl.doFilter(FilterChainImpl.java:79) at org.eclipse.stardust.ui.web.viewscommon.login.filter.LoginFilter.doFilter(LoginFilter.java:324) at weblogic.servlet.internal.FilterChainImpl.doFilter(FilterChainImpl.java:79) at weblogic.servlet.internal.RequestDispatcherImpl.invokeServlet(RequestDispatcherImpl.java:574) at weblogic.servlet.internal.RequestDispatcherImpl.forward(RequestDispatcherImpl.java:272) at org.eclipse.stardust.ui.web.plugin.support.PluginResourceRequestProcessor.handleRequest(PluginResourceRequestProcessor.java:107) at org.eclipse.stardust.ui.web.plugin.support.PortalPluginContentFilter.doFilter(PortalPluginContentFilter.java:69) at weblogic.servlet.internal.FilterChainImpl.doFilter(FilterChainImpl.java:79) at weblogic.servlet.internal.RequestEventsFilter.doFilter(RequestEventsFilter.java:27) at weblogic.servlet.internal.FilterChainImpl.doFilter(FilterChainImpl.java:79) at weblogic.servlet.internal.WebAppServletContext$ServletInvocationAction.wrapRun(WebAppServletContext.java:3367) at weblogic.servlet.internal.WebAppServletContext$ServletInvocationAction.run(WebAppServletContext.java:3333) at weblogic.security.acl.internal.AuthenticatedSubject.doAs(AuthenticatedSubject.java:321) at weblogic.security.service.SecurityManager.runAs(SecurityManager.java:120) at weblogic.servlet.provider.WlsSubjectHandle.run(WlsSubjectHandle.java:57) at weblogic.servlet.internal.WebAppServletContext.doSecuredExecute(WebAppServletContext.java:2220) at weblogic.servlet.internal.WebAppServletContext.securedExecute(WebAppServletContext.java:2146) at weblogic.servlet.internal.WebAppServletContext.execute(WebAppServletContext.java:2124) at weblogic.servlet.internal.ServletRequestImpl.run(ServletRequestImpl.java:1564) at weblogic.servlet.provider.ContainerSupportProviderImpl$WlsRequestExecutor.run(ContainerSupportProviderImpl.java:254) at weblogic.work.ExecuteThread.execute(ExecuteThread.java:295) at weblogic.work.ExecuteThread.run(ExecuteThread.java:254)
Biyuki
Previous Topic:HOW TO RECEIVE A CARNOT.EAR FILE
Next Topic:Example Spring Test Project
Current Time: Sun Jan 17 11:00:57 GMT 2021
Powered by FUDForum. Page generated in 0.01866 seconds
