Home » Modeling » OCL » Unresolved namespace with generic
Unresolved namespace with generic [message #1696840] Thu, 28 May 2015 23:18 Go to next message
Beat Lussi is currently offline Beat LussiFriend
I've implemented a generic property. The code works, but within OCLinEcore occurs always the following error:
Unresolved Namespace ProductLine.ecore.oclas#//@nestedPackage.0/@ownedType.6/@ownedTemplateSignature' ProductLine.ecore /CDD_Project/model line: 88 /CDD_Project/model/ProductLine.ecore OCLinEcore Problem
The code section is:
class FeatureGroup(FeatureType)
attribute isSelected : Boolean = 'false';
attribute numberOfFeatures : Integer { derived }
derivation: self.assignedFeature->size();
property assignedFeature :
				productline::FeatureGroup::_'ProductLine.ecore.oclas#//@nestedPackage.0/@ownedType.6/@ownedTemplateSignature'::_'ProductLine.ecore.oclas#//@nestedPackage.0/@ownedType.6/@ownedTemplateSignature/@ownedParameter.0'::FeatureType[2..*] { ordered };
attribute name : String;
invariant assignedSelfReferencing: self.assignedFeature->excludes(self);
What's wrong?
Re: Unresolved namespace with generic [message #1696890 is a reply to message #1696840] Fri, 29 May 2015 08:57 Go to previous messageGo to next message
The Ecore to text serialization appears to trying to construct a
declaration such as:
productline::FeatureGroup::XXX::FeatureType[2..*] { ordered };
but 'XXX' has failed to convert to a sensible package name.
Without seeing the *.ecore file(s) it is difficult to be sure. Perhaps
the 'correct' spelling of XXX clashes with some other declaration or
reserved word.
Please raise a Bugzilla with a fuller repro, and an Eclipse OCL version
number. (Today if you want to grab a last chance at a fix in time for
the Mars release.)
Ed Willink
On 29/05/2015 00:18, Beat Lussi wrote:
> Hi
> { ordered };
> What's wrong?
> Thanks
Re: Unresolved namespace with generic [message #1696963 is a reply to message #1696890] Fri, 29 May 2015 18:22 Go to previous messageGo to next message
Hi Ed
Okay, I've reported with the number Bug 468846. An ecore file is attached. The error occurs with Luna Release 1 (4.4.1) . I never tried another version of Eclipse. In the attachement is the eclipse configuration and an example ecore file.
Thanks & Best regards
Ed Willink wrote on Fri, 29 May 2015 08:57
reserved word.
the Mars release.)
Ed Willink
> Hi
> { ordered };
> What's wrong?
> Thanks
Re: Unresolved namespace with generic [message #1696985 is a reply to message #1696963] Sat, 30 May 2015 05:14 Go to previous messageGo to next message
The same thing happens with Mars Release 4.5.0RC2
Re: Unresolved namespace with generic [message #1696986 is a reply to message #1696985] Sat, 30 May 2015 05:37 Go to previous messageGo to next message
No. See
https://bugs.eclipse.org/bugs/show_bug.cgi?id=468846
The fix is in RC3 on Monday (or now in
http://www.eclipse.org/modeling/download.php?file=/modeling/mdt/ocl/downloads/drops/6.0.0/N201505291545/mdt-ocl-Update-N201505291545.zip).
Ed Willink
Re: Unresolved namespace with generic [message #1697275 is a reply to message #1696986] Tue, 02 June 2015 21:21 Go to previous messageGo to next message
Hi Ed
I tried with the fix but I've still a problem with unresolved type (the same example ecore file). I see in the eclipse configuration that the fix is installed (OCL 6.0.0).
Is something wrong with my code?
Ed Willink wrote on Sat, 30 May 2015 05:37
No. See
Ed Willink
Re: Unresolved namespace with generic [message #1697280 is a reply to message #1697275] Tue, 02 June 2015 21:45 Go to previous message
6.0.0 does not exist yet, so you cannot have 6.00 installed. You
presumably have some pre-release.
Ed Willink
On 02/06/2015 22:21, Beat Lussi wrote:
> Hi Ed
>> No. See
>> Regards
>> Ed Willink
Previous Topic:Possible bug in generated code
Next Topic:Validating OCL programmatically
Current Time: Fri Feb 21 00:20:30 GMT 2020
Powered by FUDForum. Page generated in 0.01955 seconds
