Home » Eclipse Projects » Mylyn » Where can I find the Web Templates connector?
Where can I find the Web Templates connector? [message #1696344] Mon, 25 May 2015 22:29 Go to next message
Oliver Kopp is currently offline Oliver KoppFriend
I read https://wiki.eclipse.org/Mylyn/FAQ#Web_Templates_Connector and https://wiki.eclipse.org/Using_Sourceforge_with_Mylyn.
In my Eclipse Kepler, I have following update sites installed: http://download.eclipse.org/mylyn/releases/latest and Mylyn Snapshots http://download.eclipse.org/mylyn/snapshots/weekly
When I browse "Mylyn" in the "Available Software" dialog, I cannot find the "Web Templates Connector". Where is it supposed to be listed?
TYIA and greetings,
Oliver
Re: Where can I find the Web Templates connector? [message #1696345 is a reply to message #1696344] Mon, 25 May 2015 22:33 Go to previous messageGo to next message
Sam Davis is currently offline Sam DavisFriend
Member
You can get the web templates connector from the Mylyn Incubator update site: http://download.eclipse.org/mylyn/incubator/3.16
Sam
[Updated on: Mon, 25 May 2015 22:35]
Report message to a moderator
Re: Where can I find the Web Templates connector? [message #1696346 is a reply to message #1696345] Mon, 25 May 2015 23:34 Go to previous messageGo to next message
Thanks. Now it shows "There are no items available", even though I did not enable "Hide items that are already installed"
Re: Where can I find the Web Templates connector? [message #1696347 is a reply to message #1696346] Tue, 26 May 2015 00:41 Go to previous messageGo to next message
Member
Oops. After I responded to your question I added another snapshot site and accidentally broke the one I told you to use. It's fixed now, but you probably have a cache of the broken site, so you can use http://download.eclipse.org/mylyn/incubator/latest instead.
Sam
Re: Where can I find the Web Templates connector? [message #1719495 is a reply to message #1696347] Fri, 08 January 2016 11:32 Go to previous messageGo to next message
Thomas Trocha is currently offline Thomas TrochaFriend
I have the same problem as Oliver. I'm using eclipse mars, added the url: http://download.eclipse.org/mylyn/incubator/latest to my repositories, but it still says 'There are no items available'.
I tried all kinds of 'checkbox setups' but nothing changed. Is the Web Template Connector even mars compatible?
Greets,
Thomas
Re: Where can I find the Web Templates connector? [message #1719538 is a reply to message #1719495] Fri, 08 January 2016 17:30 Go to previous message
Member
That's because we're in the middle of releasing 3.17. It should be fixed later today. In the meantime you can use http://download.eclipse.org/mylyn/incubator/3.16
Sam
Previous Topic:Mylyn Wikitext (Mediawiki) - Local anchor navigation broken within generated Eclipse Help
Next Topic:Mylyn 3.16 is now available
Current Time: Wed Nov 30 21:58:52 GMT 2022
Powered by FUDForum. Page generated in 0.03973 seconds
