Re: Listen for (re)application of a profile [message #1696325 is a reply to message #1696313] |
Mon, 25 May 2015 17:08   |
Hi, Patrik,
If you're working in Papyrus, have a look at the
org.eclipse.papyrus.uml.tools.listeners.ProfileApplicationListener
class and search references to it for examples of how it's used. This
provides a custom notification, sent by a Package, when profiles are
applied or unapplied. Most significantly, it accounts for "external"
profile applications that actually don't modify the package at all in
real EMF terms when they are created and destroyed.
HTH,
Christian
On 2015-05-25 14:00:24 +0000, Patrik Nandorf said:
> Is there a way to listen for (re)application of a profile on a model?
> I'd like to run some code when a profile is applied or updated.
> /Patrik
Re: Listen for (re)application of a profile [message #1696326 is a reply to message #1696325] |
Mon, 25 May 2015 17:11   |
I should clarify: the Papyrus editor uses this listener internally to
dispatch ProfileApplicationNotifications on Packages. You don't
interact with the ProfileApplicationListener, as such, but just receive
the notifications in the usual way, via Adapter or ResourceSetListener.
cW
On 2015-05-25 17:08:18 +0000, Christian W. Damus said:
> Hi, Patrik,
> HTH,
> Christian
>> /Patrik
FUDForum. Page generated in 0.02063 seconds
