Home » Modeling » UML2 » Listen for (re)application of a profile
Listen for (re)application of a profile [message #1696313] Mon, 25 May 2015 14:00 Go to next message
Patrik Nandorf is currently offline Patrik NandorfFriend
Is there a way to listen for (re)application of a profile on a model?
I'd like to run some code when a profile is applied or updated.
/Patrik
[Updated on: Mon, 25 May 2015 14:00]
Report message to a moderator
Re: Listen for (re)application of a profile [message #1696320 is a reply to message #1696313] Mon, 25 May 2015 15:10 Go to previous messageGo to next message
EMF allows an org.eclipse.emf.common.notify.Adapter to be added to any
EObject and it will receive notifications of all chnages to the EObject,
so just add an Adapter to the Packages in which you are interested.
The EMF book has much more detail.
Ed Willink
> /Patrik
Re: Listen for (re)application of a profile [message #1696325 is a reply to message #1696313] Mon, 25 May 2015 17:08 Go to previous messageGo to next message
Christian Damus is currently offline Christian DamusFriend
Hi, Patrik,
If you're working in Papyrus, have a look at the
org.eclipse.papyrus.uml.tools.listeners.ProfileApplicationListener
class and search references to it for examples of how it's used. This
provides a custom notification, sent by a Package, when profiles are
applied or unapplied. Most significantly, it accounts for "external"
profile applications that actually don't modify the package at all in
real EMF terms when they are created and destroyed.
HTH,
Christian
> /Patrik
Re: Listen for (re)application of a profile [message #1696326 is a reply to message #1696325] Mon, 25 May 2015 17:11 Go to previous messageGo to next message
I should clarify: the Papyrus editor uses this listener internally to
dispatch ProfileApplicationNotifications on Packages. You don't
interact with the ProfileApplicationListener, as such, but just receive
the notifications in the usual way, via Adapter or ResourceSetListener.
cW
On 2015-05-25 17:08:18 +0000, Christian W. Damus said:
> Hi, Patrik,
> HTH,
> Christian
>> /Patrik
Re: Listen for (re)application of a profile [message #1697175 is a reply to message #1696326] Tue, 02 June 2015 07:48 Go to previous message
Thanks Christian
Previous Topic:Cannot apply SysML stereotype
Next Topic:XMI serialization
Current Time: Sat Aug 13 06:40:40 GMT 2022
Powered by FUDForum. Page generated in 0.02152 seconds
