Home » Eclipse Projects » Requirements Modeling Framework  » Creating ReqIF model programmatically
Creating ReqIF model programmatically [message #1696217] Sat, 23 May 2015 05:08 Go to next message
I have my own EMF model, and I want to transform it ReqIF model. I could not find an example. So I try to do it like below:
public static ReqIF convert(Resource r) {
		ReqIF reqif = factory.createReqIF();
		ReqIFContent reqifContent = factory.createReqIFContent();
		Specification specification = factory.createSpecification();
		specification.setDesc("Deneme Reqif Specs");
		reqifContent.getSpecifications().add(specification);
		try {
			// Get the resource
			resource = r;
			// try to load the file into resource
			resource.load(null);
			Iterator<EObject> resourceObjects = resource.getAllContents();
			while (resourceObjects.hasNext()) {
				Object o = resourceObjects.next();
				SpecObject so = factory.createSpecObject();
				so.setDesc("deneme spec obj");
				reqifContent.getSpecObjects().add(so);
		}// end of try
		catch (NullPointerException | IOException e) {
			e.printStackTrace();
		reqif.setCoreContent(reqifContent);
		return reqif;
When I try to open ReqIF in ProR editor, I get nulllPointerException.
I outline view, I can see specObjects and requirements but there is no connections between them. I do not know how to do that.
Any suggestions are appreciated.
at org.eclipse.rmf.reqif10.pror.editor.agilegrid.ProrLayoutAdvisor.getRowHeight(ProrLayoutAdvisor.java:96)
at org.eclipse.rmf.reqif10.pror.editor.agilegrid.ProrAgileGridViewer$10.getLocation(ProrAgileGridViewer.java:821)
at org.eclipse.emf.edit.ui.dnd.EditingDomainViewerDropAdapter.helper(EditingDomainViewerDropAdapter.java:284)
at org.eclipse.emf.edit.ui.dnd.EditingDomainViewerDropAdapter.dragEnter(EditingDomainViewerDropAdapter.java:144)
at org.eclipse.rmf.reqif10.pror.editor.agilegrid.ProrAgileGridViewer$10.dragEnter(ProrAgileGridViewer.java:716)
at org.eclipse.swt.dnd.DNDListener.handleEvent(DNDListener.java:61)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4353)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1061)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1085)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1070)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:782)
at org.eclipse.swt.dnd.DropTarget.DragEnter(DropTarget.java:297)
at org.eclipse.swt.dnd.DropTarget.DragEnter_64(DropTarget.java:275)
at org.eclipse.swt.dnd.DropTarget$3.method3(DropTarget.java:245)
at org.eclipse.swt.internal.ole.win32.COMObject.callback3(COMObject.java:92)
at org.eclipse.swt.internal.ole.win32.COM.DoDragDrop(Native Method)
at org.eclipse.swt.dnd.DragSource.drag(DragSource.java:363)
at org.eclipse.swt.dnd.DragSource.access$0(DragSource.java:289)
at org.eclipse.swt.dnd.DragSource$1.handleEvent(DragSource.java:172)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4172)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3761)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1151)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1032)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:148)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:636)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:579)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:135)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
at org.eclipse.equinox.launcher.Main.main(Main.java:1438)
Re: Creating ReqIF model programmatically [message #1696222 is a reply to message #1696217] Sat, 23 May 2015 09:33 Go to previous messageGo to next message
I've managed to create reqif model programmaticaly. However there are some problems that I cannot figure out.
I cannot set the name of the specification document and spec objects. I have setted the desc. of SpecificationType and SpecObjectType. nothing happened.
Any suggestions?
  • Attachment: reqif.png
    (Size: 24.76KB, Downloaded 242 times)
[Updated on: Sat, 23 May 2015 14:43] by Moderator
Re: Creating ReqIF model programmatically [message #1696363 is a reply to message #1696222] Tue, 26 May 2015 02:13 Go to previous message
Hello Furkan,
Glad to hear you oculd figure out how to build a model.
The name in the GUI is actually taken from the AttributeValues. There is a separate configuration that decides which values are used. In the GUI, you configure it via ProR | General Configuration | Default label.
I assume that you want to do this programmatically: This information is stored in the tool extensions, and there is a separate plugin (I think called org.eclipse.rmf.pror.configuration or similar), which contains the eCore model and code for accessing it.
Best,
- Michael
Previous Topic:Serialization of EObject
Next Topic:Renaming a headline
Current Time: Fri May 23 08:37:56 EDT 2025
Powered by FUDForum. Page generated in 0.14398 seconds
