Home » Modeling » EMF » [EMF Forms] ViewModel generation does not work with classes in packages
[EMF Forms] ViewModel generation does not work with classes in packages [message #1696128] Fri, 22 May 2015 08:59 Go to next message
Tobias Zangl is currently offline Tobias ZanglFriend
Hey,
first of all i was not sure if this is the right place for this topic or if it belongs to "EMF Technology"?
My Problem:
I have an ecore file with 3 subpackages and i am not able to create view model (projects) for the classes in the subpackages. For the classes in the ecore package everything works fine. I don't get any error message, it is just not creating any .viewmodel files.
Is there anything wrong with creating multiple subpackages in an ecore file?
Should i create multiple ecore files instead?
If i create the viewmodel file by hand in the text editor the View Model Editor does not complain but the emf forms preview brings the following error:
	at org.eclipse.emf.ecore.impl.EStructuralFeatureImpl.getSettingDelegate(EStructuralFeatureImpl.java:840)
	at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSettingDelegate(BasicEObjectImpl.java:1561)
Any help would be appreciated. Smile
Greetings,
Tobi
Re: [EMF Forms] ViewModel generation does not work with classes in packages [message #1696183 is a reply to message #1696128] Fri, 22 May 2015 15:22 Go to previous messageGo to next message
Tobias,
Comments below.
On 22/05/2015 3:39 PM, Tobias Zangl wrote:
> Hey,
> My Problem:
> file?
No, but it's generally inviting problems...
That's generally better support by the whole technology stack.
> following error:
> at
> at
This suggests that you have a structural feature that doesn't have a
type. I'm not sure how that's possible for a model that's well formed.
But you say the generated model otherwise works fine?
> Any help would be appreciated. :)
> Greetings,
> Tobi
Ed Merks
Re: [EMF Forms] ViewModel generation does not work with classes in packages [message #1696223 is a reply to message #1696183] Sat, 23 May 2015 14:01 Go to previous messageGo to next message
Jonas Helming is currently offline Jonas HelmingFriend
Please also see:
http://eclipsesource.com/blogs/2013/03/19/emf-dos-and-don%C2%B4ts-5/
Am 22.05.2015 um 17:22 schrieb Ed Merks:
> Tobias,
> Comments below.
>> Hey,
>> My Problem:
>> file?
>> following error:
>> at
>> at
>> Greetings,
>> Tobi
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
Re: [EMF Forms] ViewModel generation does not work with classes in packages [message #1696324 is a reply to message #1696223] Mon, 25 May 2015 16:06 Go to previous message
Thank you very much.
Everything works fine after splitting up the sub packages in different ecore files. Smile
Also thanks for the Dos and Dont's link, havent found that yet.
Greetings,
Tobi
Previous Topic:[CDO] How do Passive updates work ?
Next Topic:[OOMPH] ClassCastException on Installer start
Current Time: Sat Jul 24 18:39:21 GMT 2021
Powered by FUDForum. Page generated in 0.01694 seconds
