Home » Eclipse Projects » RCP Testing Tool » Error on a test case without fail
Error on a test case without fail [message #1695900] Wed, 20 May 2015 04:13 Go to next message
Hi everyone,
I use RCP Testing Tool to test my application and I have an error which appear when I run a test case.
My test case pass without error, in the execution view, I have no failure but the Test Case node is in error and I have the following error :
Expect Report object, but found: Status OK: unknown code=0 OK null
I don't understand why I have this error with one test case and not with another.
What is the source of this error ?
Thanks per advance for the help.
  • Attachment: Capture.PNG
    (Size: 22.69KB, Downloaded 113 times)
Re: Error on a test case without fail [message #1695905 is a reply to message #1695900] Wed, 20 May 2015 04:41 Go to previous messageGo to next message
Hi Elise,
Could you please try to generate RCPTT report for this execution and attach it?
Yours sincerely,
Ulyana.
Re: Error on a test case without fail [message #1695952 is a reply to message #1695905] Wed, 20 May 2015 09:53 Go to previous messageGo to next message
Thanks for your fast reply.
I've attached the report in XML format and RCP TT format.
I hope this will be helpful.
I'm looking forward for your reply.
Re: Error on a test case without fail [message #1696051 is a reply to message #1695952] Thu, 21 May 2015 07:57 Go to previous messageGo to next message
Hi Elise,
The attached RCPTT report looks empty, is it the same for you?
Probably you will need to attach the whole Project with a test.
Kind regards,
Ulyana.
Re: Error on a test case without fail [message #1696072 is a reply to message #1696051] Thu, 21 May 2015 09:50 Go to previous message
Maybe I have made a mistake with the RCPTT report, but I've not kept it.
And after a lot of new execution the error disappeared without any change...I don't know why and how....
I'm sorry to can't give you anymore information but if this problem occurs another time I will come back to you.
Thanks for your help
Previous Topic:File Import script non platform dependent
Next Topic:Is there option to run tests only with certain tags for Runner (opposite to skipTags)
Current Time: Mon Jul 07 18:14:48 EDT 2025
Powered by FUDForum. Page generated in 1.70908 seconds
