Home » Modeling » Papyrus » Applying user defined stereotypes to the model elements in block definition diagram,SysML(Applying user defined stereotypes to the model elements in block definition diagram,SysML)
Applying user defined stereotypes to the model elements in block definition diagram,SysML [message #1695623] Mon, 18 May 2015 04:17 Go to next message
Hi All,
Is it possible to apply a user defined stereotype to a model element in a block definition diagram ??
I created a profile with few user defined stereotypes and applied it to the model that i want to(in this case a sysML block definition diagram). It was successfully applied to the model. When i tried to apply it to the block element in the model,I am unable to see the stereotype that i created in the Applicable stereotypes dialog box!
Am I missing something here ? can someone help me?
Vishnu.
Re: Applying user defined stereotypes to the model elements in block definition diagram,SysML [message #1695678 is a reply to message #1695623] Mon, 18 May 2015 08:53 Go to previous messageGo to next message
Hello Vishnu,
could you please detail how you defined your stereotypes? on which metaclass did you apply them (extension relationship)?
It will help understanding the problem.
Best regards
Raphaël
Re: Applying user defined stereotypes to the model elements in block definition diagram,SysML [message #1695686 is a reply to message #1695678] Mon, 18 May 2015 09:20 Go to previous messageGo to next message
The SysML diagrams may not be able to display properly all stereotypes. Since the display of SysML stereotypes is hard-coded, they can't be removed, and custom stereotypes are displayed separately. However, there shouldn't be any issue for applying custom stereotypes semantically (Independently of display issues)
Stereotypes may differ a little bit, depending on whether they are extensions of SysML Stereotypes, or just complementary stereotypes, especially in diagrams in which they are hard-coded (= SysML Diagrams). The Papyrus implementation of SysML 1.4 should solve some of these issues, but unfortunately it's not ready for prime time yet.
Camille
Re: Applying user defined stereotypes to the model elements in block definition diagram,SysML [message #1696043 is a reply to message #1695678] Thu, 21 May 2015 06:49 Go to previous messageGo to next message
Thanks for replying!
I wanted to apply a stereotype to an association in the sysML block definition diagram.
WHAT I DID:
I created a new profile with the stereotype .I extended the metaclass "Association" to the stereotype since i wanted the type to be applied to an element which is association in this case.
I added the created profile to my model
then,for the respective association element,I added the stereotype by going to Properties=>stereotypes=> add.
But the thing is the name of the stereotype is not visible in the diagram.
Under the section "stereotype" in the manage labels section,I see "no text to display".Not sure why the name of the applied stereotype is not reflecting here.
Am I missing any metaclass extension???
Vishnu
Re: Applying user defined stereotypes to the model elements in block definition diagram,SysML [message #1696045 is a reply to message #1696043] Thu, 21 May 2015 07:00 Go to previous messageGo to next message
These steps seem to work fine in Papyrus 1.1/Mars, but the diagrams and stereotypes management have changed a lot compared to Luna. I guess you should wait for the next release of Papyrus on June 24th to get it working.
Camille
Re: Applying user defined stereotypes to the model elements in block definition diagram,SysML [message #1759062 is a reply to message #1696045] Wed, 05 April 2017 12:40 Go to previous message
I'm facing a similar problem. Stereotypes created by extionsion relationship from a metaclass are not visible when using the profile. Any progess on this topic here?
Previous Topic:How to customize the palette?
Next Topic:members of the same base reference metamodel
Current Time: Sat Nov 15 04:01:45 EST 2025
Powered by FUDForum. Page generated in 0.04440 seconds
