Home » Modeling » Ecore Tools » Transforming Ecore diagrams with mediniQVT
Transforming Ecore diagrams with mediniQVT [message #1695588] Sun, 17 May 2015 14:09 Go to next message
Gonzalo Bressan Zuber is currently offline Gonzalo Bressan ZuberFriend
Member
Dear Community, i dont know if this is the place of this post
I have the MoDisco Java metamodel and i need replace a plus sign for a minus sign. Is it functionally possible?
relation InfixExpression2InfixExpression {
tvl : String;
tvr : String;
checkonly domain sourcemodel s: java::InfixExpression {
leftOperand = sLOperand : java::NumberLiteral {
tokenValue = tvl
rightOperand = sROperand : java::NumberLiteral {
tokenValue = tvr
operator = java::InfixExpressionKind::PLUS
enforce domain targetmodel t: java1::InfixExpression {
leftOperand = tLOperand : java1::NumberLiteral {
tokenValue = tvl
rightOperand = tROperand : java1::NumberLiteral {
tokenValue = tvr
operator = java1::InfixExpressionKind::MINUS
I attach the qvt file.
I recieve the following error at the transformation execution.
Exception occured in transformation
The value 'PLUS' is not a valid enumerator of 'InfixExpressionKind'
I hope you can help me.
Thanks.
Re: Transforming Ecore diagrams with mediniQVT [message #1732556 is a reply to message #1695588] Wed, 18 May 2016 08:53 Go to previous message
Cedric Brun is currently offline Cedric BrunFriend
I sincerly hope you got your anwser since then but I'll drop a note anyway for anybody ending on this post.
You should probably ask on the QVT forum: https://www.eclipse.org/forums/index.php?t=thread&frm_id=244
http://cedric.brun.io news and articles on eclipse and eclipse modeling.
Previous Topic:SPEM2 metamodel defined with Ecore
Next Topic:[Texo] Install texo in eclipse neon fails - org.json not found
Current Time: Fri Aug 14 06:41:56 GMT 2020
Powered by FUDForum. Page generated in 0.01266 seconds
