Home » Eclipse Projects » NatTable » set Custom icon in table column HeaderMenu(popup menu)
icon5.gif  set Custom icon in table column HeaderMenu(popup menu) [message #1695542] Sat, 16 May 2015 06:14 Go to next message
Lalit Solanki is currently offline Lalit SolankiFriend
Hi friend ,
I am using nattable and trying to set custom icon or add new custom item in popup menu when show Column name-> right click-> popup menu item ,so it is possible or not in nattable ???
http://D:/Lalit/Images/custom icon problem.png
please help me friend and it is possible or not in nattable
Lalit
[Updated on: Sat, 16 May 2015 06:37]
Report message to a moderator
Re: set Custom icon in table column HeaderMenu(popup menu) [message #1695548 is a reply to message #1695542] Sat, 16 May 2015 09:32 Go to previous messageGo to next message
Dirk Fauth is currently offline Dirk FauthFriend
Yes it is possible. When creating a custom menu configuration you can specify every attribute on building a menu item via IMenuItemProvider
Re: set Custom icon in table column HeaderMenu(popup menu) [message #1695606 is a reply to message #1695548] Mon, 18 May 2015 03:49 Go to previous message
ok Thank you so much Dirk sir and sorry for previas discussion...
Lalit
Previous Topic:Resize NatTable on collapse and expand
Next Topic:DefaultGlazedListsStaticFilterStrategy.removeStaticFilter does not remove matcher in underlying set
Current Time: Tue Apr 16 19:18:37 GMT 2024
Powered by FUDForum. Page generated in 2.46946 seconds
