Re: Error JVM code 11 [message #1696700 is a reply to message #1696551] |
Thu, 28 May 2015 01:53  |
Hi Dorian,
From what you've written, it sounds like the following is happening:
1. You start the AUT
2. You select "Start Test Suite"
3. The error occurs (I assume that the AUT closes)
Is that the case?
Is this something that has just started happening, or is it happening since a change in the Jubula version / your AUT version? In either case, have you correctly set up the AUT for RCP testing (described in the user manual)?
Can you reproduce this on other plaforms (Windows, for example)?
What version of Jubula and Java are you using?
Thanks for the extra information.
Alex
FUDForum. Page generated in 0.07953 seconds
