Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Forms]( ECP SDK e4)
[EMF Forms] [message #1695072] Mon, 11 May 2015 19:35 Go to next message
Mr Cur is currently offline Mr CurFriend
Member
I am working through the tutorial on http://eclipsesource.com/blogs/tutorials/getting-started-with-the-emf-client-platform/#custommodel
It is suggested to use ECP SDK e4.
Where can I find it?
I used http://download.eclipse.org/ecp/releases/releases_15/ and there is only e3.
Thanks in advance.
Cur
Re: [EMF Forms] [message #1695112 is a reply to message #1695072] Tue, 12 May 2015 06:55 Go to previous messageGo to next message
Jonas Helming is currently offline Jonas HelmingFriend
it depends on whether you want an e3 or an e4 application.
The e4 SDK should be on the target platform update site
(https://www.eclipse.org/ecp/emfforms/download.html)
Please let us know, if not.
Best regards
Jonas
Am 11.05.2015 um 21:35 schrieb Mr Cur:
> is only e3.
> Thanks in advance.
> Cur
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
Re: [EMF Forms] [message #1695222 is a reply to message #1695072] Tue, 12 May 2015 19:12 Go to previous messageGo to next message
Member
Thanks for the answer.
I thought I needed SDK 4 because I run Luna but appearantly, this is not the case. I get however the following error while running the demo:
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.pde.build [1192]
Unresolved requirement: Import-Package: org.eclipse.equinox.frameworkadmin; version="[2.0.0,3.0.0)"
The demo runs by the way.
Any ideas?
Thanks.
Cur
Re: [EMF Forms] [message #1695267 is a reply to message #1695222] Wed, 13 May 2015 07:09 Go to previous message
The issue looks unrelated to ECP or EMF Forms. The question is, why
*pde.build is part of you run config. How did you create it?
Best regards
Jonas
Am 12.05.2015 um 21:12 schrieb Mr Cur:
> !STACK 0
> Any ideas?
> Thanks.
> Cur
Previous Topic:[solved] [EMF Forms] Error using View Model Editor: "Bad type on operand stack"
Next Topic:Unable to locate installable unit
Current Time: Sat Sep 19 20:12:46 GMT 2020
Powered by FUDForum. Page generated in 0.02180 seconds
