Home » Eclipse Projects » Mylyn » Custom Priority Mapping Web Connector
Custom Priority Mapping Web Connector [message #1694820] Fri, 08 May 2015 08:27 Go to next message
Jochen Wirth is currently offline Jochen WirthFriend
Hi everybody,
i am using the Advanced Web Connector to integrate our redmine to eclipse. Everything works fine exept the icons for priorities in the task list view. Because of several issues our prioritylist in redmine is customized.
I wonder if there is an possibility to customize / overwrite the mapping of priorities or do I have to make my own connector.
I googled it but I maybe I overlooked the solution.
Best wishes.
Joe
Re: Custom Priority Mapping Web Connector [message #1694897 is a reply to message #1694820] Fri, 08 May 2015 20:10 Go to previous messageGo to next message
Sam Davis is currently offline Sam DavisFriend
Member
I think this is probably not possible with the web templates connector. Have you tried the Redmine connector? http://www.redmine.org/projects/redmine/wiki/HowTo_Mylyn
Sam
Re: Custom Priority Mapping Web Connector [message #1694914 is a reply to message #1694897] Sat, 09 May 2015 05:28 Go to previous message
Thanks for your reply.
i have tried the connector but i think the project is unsupported and the connector seems to bei incompatible to luna.
Greetings
Joe
[Updated on: Sat, 09 May 2015 05:30]
Report message to a moderator
Previous Topic:Mylyn 3.15 is now available
Next Topic:Mylyn Wikitext (Mediawiki) - Local anchor navigation broken within generated Eclipse Help
Current Time: Thu Dec 08 06:04:56 GMT 2022
Powered by FUDForum. Page generated in 0.02777 seconds
