Home » Eclipse Projects » Hudson » jira plugin 1.36-h-1
jira plugin 1.36-h-1 [message #1694753] Thu, 07 May 2015 14:43 Go to next message
Douglas Moore is currently offline Douglas MooreFriend
Does this plugin actually work with 3.2.2?
the page in the plugin page says it does but googling around i read it does not.
the hyperlink does not seem to work and configuring remote login does not work either. I maybe missing something but the instructions are pretty straight forward
Re: jira plugin 1.36-h-1 [message #1694762 is a reply to message #1694753] Thu, 07 May 2015 15:25 Go to previous messageGo to next message
This maybe a no no but I downloaded latest from jenkins 1.39 and its working
Re: jira plugin 1.36-h-1 [message #1695218 is a reply to message #1694762] Tue, 12 May 2015 18:34 Go to previous messageGo to next message
Winston Prakash is currently offline Winston PrakashFriend
If 1.39 works for you, you are welcome to use it Hudson. If you assure jira plugin 1.39 works with out issue in Hudson 3.2.2, then I'll add it to Hudson Plugin Central.
Winston Prakash
Eclipse Hudson team
Re: jira plugin 1.36-h-1 [message #1697106 is a reply to message #1695218] Mon, 01 June 2015 15:48 Go to previous message
Seems to be working fine.
Previous Topic:Dos trigger jobs throwing exception on save
Next Topic:Hudson 3.2.2 Login error
Current Time: Mon Oct 26 16:57:17 GMT 2020
Powered by FUDForum. Page generated in 0.05715 seconds
