Home » Eclipse Projects » NatTable » Search value on particular column but not effect other column.
Search value on particular column but not effect other column. [message #1694218] Sat, 02 May 2015 08:06 Go to next message
Hi Sir/friend ,
https://www.eclipse.org/forums/index.php?t=getfile&id=21713&
I am trying to searching on name but not effect AGE, CITY, SALARY or COMPANY column record means search only name column not re-order other column.
please any idea about this features in nabula nattable...please help me ...
  • Attachment: test1.PNG
    (Size: 39.17KB, Downloaded 409 times)
[Updated on: Sat, 02 May 2015 08:24] by Moderator
Re: Search value on particular column but not effect other column. [message #1694270 is a reply to message #1694218] Mon, 04 May 2015 02:46 Go to previous messageGo to next message
Hi friend ,
This feature is available or not in nattable ?
please help me ...
thank you my eclipse forumn friends...
Re: Search value on particular column but not effect other column. [message #1694271 is a reply to message #1694270] Mon, 04 May 2015 02:47 Go to previous messageGo to next message
I don't understand your question
Re: Search value on particular column but not effect other column. [message #1694277 is a reply to message #1694271] Mon, 04 May 2015 03:28 Go to previous messageGo to next message
hi sir,
sorry sir bad may explain,
http://D:\Lalit\Images\test2.png
Sir i am select one value in NAME column and filter same value show on column but not effect other column like above image in select "Gopalbhai" at that time only show match value in column but not effect other column...
thank you ,
  • Attachment: test2.PNG
    (Size: 40.27KB, Downloaded 166 times)
[Updated on: Mon, 04 May 2015 03:32] by Moderator
Re: Search value on particular column but not effect other column. [message #1694280 is a reply to message #1694277] Mon, 04 May 2015 03:31 Go to previous messageGo to next message
I still don't understand. The image shows the filter row and not a search box. Therefore what you are saying doesn't make sense, since you are filtering.
Re: Search value on particular column but not effect other column. [message #1694283 is a reply to message #1694280] Mon, 04 May 2015 03:44 Go to previous messageGo to next message
hi sir ,
sir i am know but i am just asking this feature in nattable or not.
ok sir thank you sir ,,,
Re: Search value on particular column but not effect other column. [message #1694285 is a reply to message #1694283] Mon, 04 May 2015 03:55 Go to previous messageGo to next message
Such a "feature" wouln't make sense. What would you expect to show then? An inconsistent table where column 1 shows 3 rows while all other showing 20 rows?
To stop that discussion ... no it is not supported as it doesn't make sense from the rendering point of view.
Re: Search value on particular column but not effect other column. [message #1694300 is a reply to message #1694285] Mon, 04 May 2015 05:02 Go to previous message
hi Sorry sir my bad question ...
Previous Topic:Error : launching exported RCP e4 Application with nattable to other plugin project
Next Topic:Draw selection before handling selection events
Current Time: Mon Jul 07 23:12:37 EDT 2025
Powered by FUDForum. Page generated in 0.46225 seconds
