Home » Modeling » GMF (Graphical Modeling Framework) » How can i customize a dialog box in GMF(Customize dialog box in GMF)
How can i customize a dialog box in GMF [message #1693995] Wed, 29 April 2015 22:36 Go to next message
Gregorio Barberio is currently offline Gregorio BarberioFriend
I am doing a project in GMF. I want to customize the standard dialog box which contains a set of values on the left side (Choices), that can be selected to the right side (Feature), and can be moved up or down.
I would like to add a new button (i.e. Info) that shows informations about the selected item in the left list.
index.php/fa/21700/0/
Kindly help me or suggest me a valid example...
Re: How can i customize a dialog box in GMF [message #1703606 is a reply to message #1693995] Mon, 03 August 2015 15:04 Go to previous message
Aurélien Pupier is currently offline Aurélien PupierFriend
Hi Gregorio,
There are several ways, more or less intruisive.
Perhaps the better for you is to start from this tutorial: http://doc.hammurapi.com/dokuwiki/doku.php?id=gmf_cheat_sheet#custom_property_editors
Aurélien Pupier - Red Hat
Senior Software Engineer in Fuse Tooling team
Previous Topic:node generated as link
Next Topic:Switching Diagram Label Icon during runtime on/off
Current Time: Fri Feb 26 13:12:54 GMT 2021
Powered by FUDForum. Page generated in 0.02127 seconds
