Home » Modeling » Graphiti » Adding shapes to the Diagram on the open of the Editor(I want add shapes to the diagram from model when the Editor is getting opened)
Adding shapes to the Diagram on the open of the Editor [message #1693879] Wed, 29 April 2015 05:56 Go to next message
Kalpana Ramasamy is currently offline Kalpana RamasamyFriend
I have a scenario-
Project and Nodes
I want to link Diagram-> Project
Shape -> Nodes
On open when creating Diagram will link Project to diagram
So I need to know the place where i can add Nodes to Diagram when the editor is getting opened
Re: Adding shapes to the Diagram on the open of the Editor [message #1693958 is a reply to message #1693879] Wed, 29 April 2015 13:39 Go to previous messageGo to next message
Michael Wenz is currently offline Michael WenzFriend
do you really want to add nodes to the diagram when the editor is being
opened? That would lead to the editor being dirty right after opening it.
Or do you mean you would like to add nodes when you create a new diagram
(file)? That should be rather easy, as there somehow needs to be a action
that triggers the diagram creation and there you could hook your
functionality to add the nodes.
HTH,
Michael
Re: Adding shapes to the Diagram on the open of the Editor [message #1694004 is a reply to message #1693958] Thu, 30 April 2015 03:43 Go to previous messageGo to next message
Hi Michael,
I have existing model objects(nodes) in the project,which will be given as input to editor
On first time open of the Editor,that is say when i create a diagram ,i want to add pictogram elements of these objects/nodes in the editor
Best Regards,
Kalpana R
Re: Adding shapes to the Diagram on the open of the Editor [message #1694076 is a reply to message #1694004] Thu, 30 April 2015 12:00 Go to previous message
Hi Kalpana R,
have you seen the tutorial section on "Dark Feature Processing"? Meant is
adding stuff to a diagram while it is not opened:
http://help.eclipse.org/kepler/index.jsp?topic=%2Forg.eclipse.graphiti.doc%2Fresources%2Fdocu%2Fgfw%2Fdark-feature-processing.htm&cp=27_1_11
The classes referenced on that page are part of the SDK tutorial plugin. You
could hook in similar functionality into the action you trigger to create
the diagram.
Michael
Previous Topic:Graph Editor
Next Topic:Kieler-Show Layout View in Graphiti
Current Time: Mon Apr 06 00:11:43 GMT 2020
Powered by FUDForum. Page generated in 0.02098 seconds
