Home » Eclipse Projects » BPMN 2.0 Modeler » Export diagram as html file(I wanna know if it's possible to export a diagram to html file (like a web file that can be "surfed / navigable"), as we can do with the Bizagi publishing as web.)
Export diagram as html file [message #1693709] Mon, 27 April 2015 18:45 Go to next message
Mariana Silva is currently offline Mariana SilvaFriend
Re: Export diagram as html file [message #1693903 is a reply to message #1693709] Wed, 29 April 2015 09:04 Go to previous message
Ralph Soika is currently offline Ralph SoikaFriend
Hi Mariana,
there is no standard HTML export in the Modeler implemented. But as BPMN is standard there are some projects working on that requirement . Take a look at:
http://bpmn.io/blog/posts/2014-bpmn-js-viewer-is-here.html
https://github.com/bpmn-io/bpmn-js
https://github.com/bpmn-io/bpmn.io
You can import your BPMN models, generated with the Eclipse BPMN2 modeler, with the BPMN-js-Viewer. The result is pretty good.
Ralph
Previous Topic:Developer Tutorial : ToolPalettes
Next Topic:Problem adding attributes to Conversation
Current Time: Mon Oct 02 05:53:25 GMT 2023
Powered by FUDForum. Page generated in 0.01848 seconds
