Equinox, chose service implementation at runtime [message #1693708] |
Mon, 27 April 2015 17:30 |
ALex W Messages: 56 Registered: July 2012 |
Member |
I'm working on a E4 application to control electronic boards. The application can only control a single board instance at a time, but I want to offer support for multiple boards without providing multiple versions of the compiled product/app (the user may have to restart the app to properly reload the bundles).
I'm using declarative services to implement a controller service for each board.
Is there any way to chose the implementation at runtime ?
I've been searching for weeks with no result. I'm open to almost anything :
- Lifecycle hook ?
- Bundlecontext registration filter ?
- Dynamic bundle loading ?
-... Anything else ?
I tried :
Bundle b = context.installBundle( location );
But this leads me to some stack trace and I still have to register the services manually (even though I have an OSGI component inside)
org.osgi.framework.BundleException: Error while renaming bundle file to final location: ....\.metadata\.plugins\org.eclipse.pde.core\MyApp.product\org.eclipse.osgi\187\0\bundleFile
at org.eclipse.osgi.storage.Storage.getContentFile0(Storage.java:765)
at org.eclipse.osgi.storage.Storage.getContentFile(Storage.java:741)
at org.eclipse.osgi.storage.Storage.install(Storage.java:506)
at org.eclipse.osgi.internal.framework.BundleContextImpl.installBundle(BundleContextImpl.java:146)
at org.eclipse.osgi.internal.framework.BundleContextImpl.installBundle(BundleContextImpl.java:139)
at org.myapp.core.internal.MyAppCoreActivator.start(myAppCoreActivator.java:34)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:771)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:764)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:721)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:936)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:319)
at org.eclipse.osgi.container.Module.doStart(Module.java:571)
at org.eclipse.osgi.container.Module.start(Module.java:439)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:454)
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:531)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:324)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:320)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:395)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:345)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:337)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160)
at org.eclipse.osgi.internal.framework.EquinoxBundle.loadClass(EquinoxBundle.java:568)
at org.eclipse.equinox.internal.ds.model.ServiceComponent.createInstance(ServiceComponent.java:493)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.createInstance(ServiceComponentProp.java:270)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.build(ServiceComponentProp.java:331)
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponent(InstanceProcess.java:620)
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponents(InstanceProcess.java:197)
at org.eclipse.equinox.internal.ds.Resolver.buildNewlySatisfied(Resolver.java:473)
at org.eclipse.equinox.internal.ds.Resolver.enableComponents(Resolver.java:217)
at org.eclipse.equinox.internal.ds.SCRManager.performWork(SCRManager.java:816)
at org.eclipse.equinox.internal.ds.SCRManager$QueuedJob.dispatch(SCRManager.java:783)
at org.eclipse.equinox.internal.ds.WorkThread.run(WorkThread.java:89)
Please help (maybe with technical snippets or link).
Thank you,
[Updated on: Mon, 27 April 2015 18:34] Report message to a moderator
Re: Equinox, chose service implementation at runtime [message #1693975 is a reply to message #1693727] |
Wed, 29 April 2015 16:53 |
Member |
Thomas Watson wrote on Mon, 27 April 2015 22:15I don't understand why you would not use configuration admin to configure your target filter for selecting the service in DS. DS should have built-in support for configuring such things with configuration admin.
Correct me if I'm wrong, but with the ConfigAdmin, it is up to the consuming service to explecitely mention which implementation it wants to use, right ?
In this case, it won't work for me, be cause I already have some view that are designed to run with the interface of the service (ie, any implementation will work transparently, but only one at a time).
The other services that requires the implementation already consume a sub interface of the desired service.
Sorry, if I'm not very clear, english is not my native language
FUDForum. Page generated in 0.01919 seconds
