Home » Modeling » EMF » [Teneo] problem with update site
[Teneo] problem with update site [message #1693684] Mon, 27 April 2015 13:49 Go to next message
Thomas Elskens is currently offline Thomas ElskensFriend
Could it be that the dependencies of Teneo (http://www.elver.org/eclipse/2.1.0/update/) reside on an update-site ancient style ?
I can fetch the dependencies with PDE-target-assistance, but when I try to launch a build, Tycho refuses the repository:
[ERROR] Failed to resolve target definition C:\git\portfolio\be.groups.portfolio.targetdefinition\be.groups.portfolio.targetdefinition.target:
Failed to load p2 metadata repository from location http://www.elver.org/eclipse/2.1.0/update: No repository found at http://www.elver.org/eclipse/2.1.0/update.
If I'm correct, is there any way to fetch these dependencies from a regular p2 site ? I've looked for them on Orbit, but org.hibernate is absent and javax.persistence only available in an antiquated version. Only dom4j is available with the good version number...
Many thanks in advance,
Thomas Elskens
Re: [Teneo] problem with update site [message #1693756 is a reply to message #1693684] Tue, 28 April 2015 07:35 Go to previous messageGo to next message
Martin Taal is currently offline Martin TaalFriend
Hi Thomas,
I don't know of other sites which have these plugins. I can change the update site. You seem to know what's wrong with
it. If you can give me some hints I can change the format.
Here is the github repo with the complete site so you can see the current structure:
https://github.com/mtaal/texoteneodeps/tree/master/org.eclipse.emf.teneo.update
Let me know what you think, thanks!
gr. Martin
On 27-04-15 15:49, Thomas Elskens wrote:
> Hello,
> style ?
> Quote:
>> C:\git\portfolio\be.groups.portfolio.targetdefinition\be.groups.portfolio.targetdefinition.target: Failed to load p2
> Thomas Elskens
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Teneo] problem with update site [message #1693821 is a reply to message #1693756] Tue, 28 April 2015 14:10 Go to previous messageGo to next message
Hi Martin,
Thanks for the quick answer.
In se, the update site seems okay. As far as I understand what is happening, the problem is really with Tycho. Tycho only resolves dependencies from a "modern" p2 repository, not from an "old" Eclipse Update Site (you can recognize the old format via the presence of the site.xml file).
With the sources you hinted at, I could generate a p2 repository and that one works fine for me (both in PDE and with Maven/Tycho).
It's really extremely easy to implement with Eclipse PDE: in the workspace where you have your feature projects, do
* File > Export > Plug-in development > Deployable Features >
* Choose the features you want to export
* In the destination tab, specify the output directory
* In the options tab, check Generate p2 repository
That's all : PDE generates a repository you can depose as is on your http server. If you're interested in this little enhancement, beware that users still working with Eclipse 3.5 or less cannot use a p2 repository.
Thanks anyhow for the bundling of all those dependencies, it's a real time saver!
Thomas Elskens
Re: [Teneo] problem with update site [message #1693858 is a reply to message #1693821] Tue, 28 April 2015 19:51 Go to previous messageGo to next message
Hi Thomas,
I recreated the 2.1.0 update site as a p2 repository. Can you check if this indeed helps?
The 2.0.0 update site has not changed, I think I will keep that one as it is.
gr. Martin
On 28-04-15 16:10, Thomas Elskens wrote:
> Hi Martin,
> old format via the presence of the site.xml file). With the sources you hinted at, I could generate a p2 repository and
> * File > Export > Plug-in development > Deployable Features > * Choose the features you want to export
> Thomas Elskens
The Netherlands
Re: [Teneo] problem with update site [message #1696384 is a reply to message #1693858] Tue, 26 May 2015 09:10 Go to previous messageGo to next message
First of all sorry for the very late reaction : I somehow did not notice your answer coming by....
The site http://www.elver.org/eclipse/2.1.0/update/ seems to be perfect now, but as of today I can't reach any longer the official site http://download.eclipse.org/modeling/emf/teneo/updates/2.1.0/?d. Perhaps just a temporary network error ... ?
Thomas Elskens
Re: [Teneo] problem with update site [message #1696419 is a reply to message #1696384] Tue, 26 May 2015 11:35 Go to previous message
Hi Thomas,
My mistake, is now back.
http://download.eclipse.org/modeling/emf/teneo/updates/2.1.0/interim/
gr. Martin
On 26-05-15 11:10, Thomas Elskens wrote:
> Hello,
> error ... ?
> Thomas Elskens
The Netherlands
Previous Topic:[OOMPH] ClassCastException on Installer start
Next Topic:[EMF] How to use container the right way
Current Time: Mon Jan 27 15:23:11 GMT 2020
Powered by FUDForum. Page generated in 0.02254 seconds
