Home » Eclipse Projects » NatTable » object is not an instance of declaring class Problem in example _6042_TreeStructureGridExample
object is not an instance of declaring class Problem in example _6042_TreeStructureGridExample [message #1693600] Sun, 26 April 2015 07:27 Go to next message
I changed something for testing in _6042_TreeStructureGridExample example application. It is below(Changes indicated with comment "New added for testing something")
 private class PersonWithAddressTreeColumnPropertyAccessor implements IColumnPropertyAccessor {
        private IColumnPropertyAccessor cpa;
        public PersonWithAddressTreeColumnPropertyAccessor(IColumnPropertyAccessor cpa) {
            this.cpa = cpa;
        public Object getDataValue(Object rowObject, int columnIndex) {
            if (rowObject instanceof PersonWithAddress) {
                return this.cpa.getDataValue((PersonWithAddress) rowObject, columnIndex);
            //New added for testing something
            else if(rowObject instanceof LastNameGroup){
            	 return this.cpa.getDataValue((LastNameGroup) rowObject, columnIndex);
            else if(rowObject instanceof FirstNameGroup){
           	 return this.cpa.getDataValue((FirstNameGroup) rowObject, columnIndex);
            } else if (columnIndex == 0) {
                return rowObject;
            return null;
And there is only one column
 String[] propertyNames = { "lastName"};
//        		"firstName" , "gender",                "married", "birthday" };
when I run application the error occured. The error is below
java.lang.RuntimeException: java.lang.IllegalArgumentException: object is not an instance of declaring class
	at mywork.ReflectiveColumnPropertyAccessor.getDataValue(ReflectiveColumnPropertyAccessor.java:56)
	at mywork._6042_TreeStructureGridExample$PersonWithAddressTreeColumnPropertyAccessor.getDataValue(_6042_TreeStructureGridExample.java:375)
	at org.eclipse.nebula.widgets.nattable.extension.glazedlists.GlazedListsDataProvider.getDataValue(GlazedListsDataProvider.java:100)
	at org.eclipse.nebula.widgets.nattable.layer.DataLayer.getDataValue(DataLayer.java:143)
	at org.eclipse.nebula.widgets.nattable.layer.DataLayer.getDataValueByPosition(DataLayer.java:424)
	at org.eclipse.nebula.widgets.nattable.layer.AbstractLayerTransform.getDataValueByPosition(AbstractLayerTransform.java:372)
	at org.eclipse.nebula.widgets.nattable.layer.AbstractIndexLayerTransform.getDataValueByPosition(AbstractIndexLayerTransform.java:381)
	at org.eclipse.nebula.widgets.nattable.layer.CompositeLayer.getDataValueByPosition(CompositeLayer.java:600)
	at org.eclipse.nebula.widgets.nattable.layer.cell.AbstractLayerCell.getDataValue(AbstractLayerCell.java:64)
	at org.eclipse.nebula.widgets.nattable.layer.cell.CellDisplayConversionUtils.convertDataType(CellDisplayConversionUtils.java:21)
	at org.eclipse.nebula.widgets.nattable.painter.cell.AbstractTextPainter.convertDataType(AbstractTextPainter.java:175)
	at org.eclipse.nebula.widgets.nattable.painter.cell.TextPainter.paintCell(TextPainter.java:159)
	at org.eclipse.nebula.widgets.nattable.painter.cell.CellPainterWrapper.paintCell(CellPainterWrapper.java:73)
	at org.eclipse.nebula.widgets.nattable.painter.cell.decorator.LineBorderDecorator.paintCell(LineBorderDecorator.java:84)
	at org.eclipse.nebula.widgets.nattable.painter.cell.decorator.CellPainterDecorator.paintCell(CellPainterDecorator.java:290)
	at org.eclipse.nebula.widgets.nattable.tree.painter.IndentedTreeImagePainter.paintCell(IndentedTreeImagePainter.java:303)
	at org.eclipse.nebula.widgets.nattable.painter.cell.decorator.PaddingDecorator.paintCell(PaddingDecorator.java:205)
	at org.eclipse.nebula.widgets.nattable.painter.cell.BackgroundPainter.paintCell(BackgroundPainter.java:53)
	at org.eclipse.nebula.widgets.nattable.painter.layer.CellLayerPainter.paintCell(CellLayerPainter.java:230)
	at org.eclipse.nebula.widgets.nattable.painter.layer.CellLayerPainter.paintLayer(CellLayerPainter.java:88)
	at org.eclipse.nebula.widgets.nattable.painter.layer.GridLineCellLayerPainter.paintLayer(GridLineCellLayerPainter.java:116)
	at org.eclipse.nebula.widgets.nattable.selection.SelectionLayerPainter.paintLayer(SelectionLayerPainter.java:109)
	at org.eclipse.nebula.widgets.nattable.layer.CompositeLayer$CompositeLayerPainter.paintLayer(CompositeLayer.java:993)
	at org.eclipse.nebula.widgets.nattable.painter.layer.NatLayerPainter.paintLayer(NatLayerPainter.java:47)
	at org.eclipse.nebula.widgets.nattable.NatTable.paintNatTable(NatTable.java:453)
	at org.eclipse.nebula.widgets.nattable.NatTable.paintControl(NatTable.java:448)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:230)
	at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4353)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1061)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1085)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1070)
	at org.eclipse.swt.widgets.Composite.WM_PAINT(Composite.java:1491)
	at org.eclipse.swt.widgets.Control.windowProc(Control.java:4667)
	at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:339)
	at org.eclipse.swt.widgets.Display.windowProc(Display.java:5023)
	at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
	at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2549)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3759)
	at org.eclipse.nebula.widgets.nattable.examples.runner.StandaloneNatExampleRunner.run(StandaloneNatExampleRunner.java:43)
	at org.eclipse.nebula.widgets.nattable.examples.runner.StandaloneNatExampleRunner.run(StandaloneNatExampleRunner.java:23)
	at mywork._6042_TreeStructureGridExample.main(_6042_TreeStructureGridExample.java:95)
Caused by: java.lang.IllegalArgumentException: object is not an instance of declaring class
	at mywork.ReflectiveColumnPropertyAccessor.getDataValue(ReflectiveColumnPropertyAccessor.java:53)
	... 47 more
Error while painting table: java.lang.IllegalArgumentException: object is not an instance of declaring class
What is the problem?
Re: object is not an instance of declaring class Problem in example _6042_TreeStructureGridExample [message #1693601 is a reply to message #1693600] Sun, 26 April 2015 07:39 Go to previous messageGo to next message
The ReflectiveColumnPropertyAccessor uses reflection to access the data. It initializes access methods once, for the first input.
If the other inputs are from another classes, the access methods will fail, as they refer to another class.
You need to keep an instance of ReflectiveColumnPropertyAccessor for each class.
Re: object is not an instance of declaring class Problem in example _6042_TreeStructureGridExample [message #1693604 is a reply to message #1693601] Sun, 26 April 2015 09:26 Go to previous messageGo to next message
Thank you for your response
Is there any example code for your mentioned and solutions
Re: object is not an instance of declaring class Problem in example _6042_TreeStructureGridExample [message #1693606 is a reply to message #1693604] Sun, 26 April 2015 10:14 Go to previous messageGo to next message
You could simply implement a custom IColumnPropertyAccessor instead of using reflection if you need to deal with different classes in one collection.
Re: object is not an instance of declaring class Problem in example _6042_TreeStructureGridExample [message #1693607 is a reply to message #1693606] Sun, 26 April 2015 10:43 Go to previous messageGo to next message
Ok. I created new ICloumnPropertyAccessor. How can I define to NatTable. In example defined this like below
this.bodyDataProvider =
                    new GlazedListsDataProvider(
                            this.treeList, new PersonWithAddressTreeColumnPropertyAccessor(columnPropertyAccessor));
How can I define second one
I have been using NatTable for two days. So that I cannot understand exactly .
Thankyou
Re: object is not an instance of declaring class Problem in example _6042_TreeStructureGridExample [message #1693610 is a reply to message #1693607] Sun, 26 April 2015 13:54 Go to previous message
Dear Fauth,
Ok. I understood. I will implement new ICloumnPropertyAccessor.
Thank you
Previous Topic:changed data in nabula nattable(Cell Value changed) or how to effect from database side
Next Topic:Dynamic conditional highlighting
Current Time: Wed Jul 16 14:30:24 EDT 2025
Powered by FUDForum. Page generated in 0.10830 seconds
