Eclipselink connection error (trying to create too many connections) [message #1693226] |
Wed, 22 April 2015 13:33 |
Ravi Shankar Karupalli Messages: 5 Registered: April 2015 |
Hi, we are currently migrating Toplink to Eclipselink 2.4.2 in our application which is running on Websphere 8. At the server startup I can see that Eclipselink is able to connect to Datasource from this log.
[30/03/15 16:28:05:056 BST] 00000009 SystemOut O [EL Config]: connection: 2015-03-30 16:28:05.055--connecting(DatabaseLogin(
platform=>Oracle11Platform
user name=> "null"
connector=>JNDIConnector datasource name=>jdbc/xxxTabDataSource
[30/03/15 16:28:05:056 BST] 00000009 SystemOut O [EL Config]: connection: 2015-03-30 16:28:05.056--Connected: jdbc:oracle:thin:@XXX:000:XXX
User: XXX_PRX
Database: Oracle Version: Oracle Database 11g Enterprise Edition Release 11.2.0.4.0 - 64bit Production
With the Partitioning option
Driver: Oracle JDBC driver Version: 11.2.0.2.0
[30/03/15 16:28:05:134 BST] 00000009 SystemOut O [EL Info]: connection: 2015-03-30 16:28:05.134-- xxxSession login successful
When running any query, the application seems to be trying to create too many connections and finally failing with either Stackflow or Pool allocation error. In the logs we can see that multiple connections for the same query
[30/03/15 16:28:05:056 BST] 0000002d SystemOut O [EL Fine]: sql: 2015-04-22 13:18:06.065--Connection(1414240713)--SELECT USER_ID, BRAND_ACRONYM, DEPARTMENT_CODE, EXPIRY_DATE, IS_SUPER_USER, LAST_LOGIN_DATE, PII_VISIBILITY, ROLE_ID, START_DATE, USER_EMAILID, USER_FNAME, USER_FUNCTION, USER_SNAME, USER_STATUS, USER_TELEPHONE FROM XYZ.USER_PROFILE WHERE (USER_ID = ?)
bind => [XXXXXX]
[30/03/15 16:28:05:056 BST] 0000002d SystemOut O [EL Fine]: sql: 2015-04-22 13:18:06.071--Connection(-259746999)--SELECT USER_ID, BRAND_ACRONYM, DEPARTMENT_CODE, EXPIRY_DATE, IS_SUPER_USER, LAST_LOGIN_DATE, PII_VISIBILITY, ROLE_ID, START_DATE, USER_EMAILID, USER_FNAME, USER_FUNCTION, USER_SNAME, USER_STATUS, USER_TELEPHONE FROM XYZ.USER_PROFILE WHERE (USER_ID = ?)
bind => [XXXXXX]
....... (the above repeated for 50 times)
The final error is either this one ..
[30/03/15 16:28:05:056 BST] 0000002d ServletWrappe E com.ibm.ws.webcontainer.servlet.ServletWrapper service Uncaught service() exception thrown by servlet action: java.lang.StackOverflowError
at com.ibm.ejs.j2c.PoolManager.reserve(PoolManager.java:2609)
at com.ibm.ejs.j2c.ConnectionManager.allocateMCWrapper(ConnectionManager.java:1500)
at com.ibm.ejs.j2c.ConnectionManager.allocateConnection(ConnectionManager.java:1012)
at com.ibm.ws.rsadapter.jdbc.WSJdbcDataSource.getConnection(WSJdbcDataSource.java:669)
at com.ibm.ws.rsadapter.jdbc.WSJdbcDataSource.getConnection(WSJdbcDataSource.java:636)
at org.eclipse.persistence.sessions.JNDIConnector.connect(JNDIConnector.java:123)
at org.eclipse.persistence.sessions.DatasourceLogin.connectToDatasource(DatasourceLogin.java:162)
or
at java.util.Hashtable$HashEnumIterator.nextElement(Hashtable.java:808)
at java.util.PropertyPermissionCollection.implies(PropertyPermissionCollection.java:69)
at org.eclipse.osgi.internal.permadmin.PermissionInfoCollection.implies(PermissionInfoCollection.java:80)
at org.eclipse.osgi.internal.permadmin.BundlePermissions.implies(BundlePermissions.java:59)
at java.security.ProtectionDomain.implies(ProtectionDomain.java:213)
at java.security.AccessController.checkPermission(AccessController.java:173)
at java.lang.SecurityManager.checkPermission(SecurityManager.java:544)
at com.ibm.ws.security.core.SecurityManager.checkPermission(SecurityManager.java:208)
at java.lang.SecurityManager.checkPropertyAccess(SecurityManager.java:1297)
at java.lang.System.getProperty(System.java:408)
at java.lang.System.getProperty(System.java:392)
at sun.security.action.GetPropertyAction.run(GetPropertyAction.java:86)
Could you please help in identifying the root cause of the issue. The application was working correctly when we were using Toplink. We moved all the configuration data to eclipselink.
Ravi
Re: Eclipselink connection error (trying to create too many connections) [message #1693324 is a reply to message #1693241] |
Thu, 23 April 2015 08:46 |
Hi Thanks for the response. the full stack trace is very long, hence I was hesitant to post it earlier. Here is the full stack trace.
[4/22/15 13:18:06:465 BST] 0000002d SystemOut O [EL Fine]: sql: 2015-04-22 13:18:06.465--Connection(-1417456453)--SELECT USER_ID, BRAND_ACRONYM, DEPARTMENT_CODE, EXPIRY_DATE, IS_SUPER_USER, LAST_LOGIN_DATE, PII_VISIBILITY, ROLE_ID, START_DATE, USER_EMAILID, USER_FNAME, USER_FUNCTION, USER_SNAME, USER_STATUS, USER_TELEPHONE FROM USER_PROFILE WHERE (USER_ID = ?)
bind => [XYZ]
[4/22/15 13:18:06:644 BST] 0000002d ServletWrappe E com.ibm.ws.webcontainer.servlet.ServletWrapper service Uncaught service() exception thrown by servlet action: java.lang.StackOverflowError
at sun.security.action.GetPropertyAction.run(GetPropertyAction.java:51)
at java.security.AccessController.doPrivileged(AccessController.java:273)
at java.io.PrintWriter.<init>(PrintWriter.java:89)
at java.io.PrintWriter.<init>(PrintWriter.java:73)
at com.ibm.ejs.ras.StreamEvent6.convertToString(StreamEvent6.java:298)
at com.ibm.ws.logging.object.WsLogRecordFactory.createWsLogRecord(WsLogRecordFactory.java:401)
at com.ibm.ejs.ras.Tr.logToWsHandlers(Tr.java:1720)
at com.ibm.ejs.ras.Tr.systemOut(Tr.java:1022)
at com.ibm.ejs.ras.SystemOutStream.dispatchEvent(SystemOutStream.java:393)
at com.ibm.ejs.ras.SystemStream.write(SystemStream.java:298)
at com.ibm.ejs.ras.SystemOutStream.write(SystemOutStream.java:80)
at sun.nio.cs.StreamEncoder$CharsetSE.writeBytes(StreamEncoder.java:355)
at sun.nio.cs.StreamEncoder$CharsetSE.implFlushBuffer(StreamEncoder.java:425)
at sun.nio.cs.StreamEncoder$CharsetSE.implFlush(StreamEncoder.java:429)
at sun.nio.cs.StreamEncoder.flush(StreamEncoder.java:175)
at java.io.OutputStreamWriter.flush(OutputStreamWriter.java:274)
at java.io.BufferedWriter.flush(BufferedWriter.java:247)
at java.io.PrintWriter.flush(PrintWriter.java:287)
at org.eclipse.persistence.logging.DefaultSessionLog.log(DefaultSessionLog.java:144)
at org.eclipse.persistence.internal.sessions.AbstractSession.log(AbstractSession.java:3246)
at org.eclipse.persistence.internal.sessions.AbstractSession.log(AbstractSession.java:4364)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.basicExecuteCall(DatabaseAccessor.java:583)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.executeCall(DatabaseAccessor.java:537)
at org.eclipse.persistence.internal.sessions.AbstractSession.basicExecuteCall(AbstractSession.java:1805)
at org.eclipse.persistence.sessions.server.ServerSession.executeCall(ServerSession.java:566)
at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeCall(DatasourceCallQueryMechanism.java:207)
at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeCall(DatasourceCallQueryMechanism.java:193)
at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.selectOneRow(DatasourceCallQueryMechanism.java:668)
at org.eclipse.persistence.internal.queries.ExpressionQueryMechanism.selectOneRowFromTable(ExpressionQueryMechanism.java:2769)
at org.eclipse.persistence.internal.queries.ExpressionQueryMechanism.selectOneRow(ExpressionQueryMechanism.java:2722)
at org.eclipse.persistence.queries.ReadObjectQuery.executeObjectLevelReadQuery(ReadObjectQuery.java:453)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.executeDatabaseQuery(ObjectLevelReadQuery.java:1150)
at org.eclipse.persistence.queries.DatabaseQuery.execute(DatabaseQuery.java:852)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.execute(ObjectLevelReadQuery.java:1109)
at org.eclipse.persistence.queries.ReadObjectQuery.execute(ReadObjectQuery.java:421)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.executeInUnitOfWork(ObjectLevelReadQuery.java:1197)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.internalExecuteQuery(UnitOfWorkImpl.java:2879)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1607)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1589)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1540)
at org.eclipse.persistence.internal.sessions.AbstractSession.checkAndRefreshInvalidObject(AbstractSession.java:1051)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.cloneAndRegisterObject(UnitOfWorkImpl.java:981)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildWorkingCopyCloneNormally(ObjectBuilder.java:739)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildObjectInUnitOfWork(ObjectBuilder.java:676)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildObject(ObjectBuilder.java:609)
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildObject(ObjectBuilder.java:564)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.buildObject(ObjectLevelReadQuery.java:777)
at org.eclipse.persistence.queries.ReadObjectQuery.registerResultInUnitOfWork(ReadObjectQuery.java:787)
at org.eclipse.persistence.queries.ReadObjectQuery.executeObjectLevelReadQuery(ReadObjectQuery.java:460)
Re: Eclipselink connection error (trying to create too many connections) [message #1693375 is a reply to message #1693342] |
Thu, 23 April 2015 15:23 |
Yes we are able to recreate the issue easily. This is the first query of the application(Checking user access level). So I presume this issue will occur with any query. This is the query
bind => [XYZ]
This is standard user information table. The above query was working fine when we were using Toplink.
FUDForum. Page generated in 0.03315 seconds
