Home » Modeling » EMF » Invalidation Event (CSOSessionInvalidationEvent)
Invalidation Event (CSOSessionInvalidationEvent) [message #1693145] Wed, 22 April 2015 05:09 Go to next message
UmaShankar Subramani is currently offline UmaShankar SubramaniFriend
In the constructor of InvalidationEvent, I tried to get the newObjects, dirtyObjects and detatchedObjects maps.
But the map is always empty. How can I get those objects ?
public InvalidationEvent(InternalCDOTransaction sender, CDOCommitInfo commitInfo)
super(CDOSessionImpl.this);
this.sender = sender;
this.sender.getNewObjects(); //Always empty
this.commitInfo = commitInfo;
Re: Invalidation Event (CSOSessionInvalidationEvent) [message #1693168 is a reply to message #1693145] Wed, 22 April 2015 08:27 Go to previous messageGo to next message
Eike Stepper is currently offline Eike StepperFriend
Am 22.04.2015 um 07:09 schrieb UmaShankar Subramani:
> this.sender.getNewObjects(); //Always empty this.commitInfo = commitInfo;
Why do you write code into CDO's event constructor? Don't use the sender; it's null unless the sender is a *local*
transaction.
The event's getNewObjects() method delegates to the internal commitInfo object.
Cheers
/Eike
http://www.esc-net.de
Re: Invalidation Event (CSOSessionInvalidationEvent) [message #1693175 is a reply to message #1693168] Wed, 22 April 2015 09:05 Go to previous messageGo to next message
Hi Eike,
During the commit "transaction.commit();" , I need to use the newObjects, dirtyObjects and detatchedObjects to generate a text file.
This file is sent to all clients. I am sending this file as CDORemoteMessage to all the clients.
I thought it is not a good to use the CDOTransactionImpl for this purpose. So I tried using InvalidationEvent. Could you please give me
more idea on this ?
/Uma
Re: Invalidation Event (CSOSessionInvalidationEvent) [message #1693176 is a reply to message #1693168] Wed, 22 April 2015 09:05 Go to previous messageGo to next message
No Message Body
[Updated on: Wed, 22 April 2015 09:10]
Report message to a moderator
Re: Invalidation Event (CSOSessionInvalidationEvent) [message #1693177 is a reply to message #1693168] Wed, 22 April 2015 09:05 Go to previous messageGo to next message
No Message Body
[Updated on: Wed, 22 April 2015 09:09]
Re: Invalidation Event (CSOSessionInvalidationEvent) [message #1693178 is a reply to message #1693175] Wed, 22 April 2015 09:13 Go to previous messageGo to next message
Am 22.04.2015 um 11:06 schrieb UmaShankar Subramani:
> Hi Eike,
> you please give me more idea on this ?
You only want to do this on the committing side, not on all receiving sides, right? Then you may want to register a
CDOTransactionHandler3 with your local transaction.
Cheers
/Eike
Re: Invalidation Event (CSOSessionInvalidationEvent) [message #1693179 is a reply to message #1693178] Wed, 22 April 2015 09:19 Go to previous messageGo to next message
Hi Eike,
I also want to do this on the receiving side (to receive the file and associate it with the respective model). How can I do that?
/Uma
Re: Invalidation Event (CSOSessionInvalidationEvent) [message #1693184 is a reply to message #1693179] Wed, 22 April 2015 09:57 Go to previous messageGo to next message
Am 22.04.2015 um 11:19 schrieb UmaShankar Subramani:
> Hi Eike,
> can I do that?
With "receiving side" I meant the other CDO clients that eventually receive an invalidation event. You want to make
those send additional files, too?
Cheers
/Eike
Re: Invalidation Event (CSOSessionInvalidationEvent) [message #1693192 is a reply to message #1693184] Wed, 22 April 2015 10:39 Go to previous messageGo to next message
Yes.
I want to send the additional file too, to all the clients.
How can I achieve this?
/Uma
Re: Invalidation Event (CSOSessionInvalidationEvent) [message #1693193 is a reply to message #1693192] Wed, 22 April 2015 10:42 Go to previous messageGo to next message
Am 22.04.2015 um 12:39 schrieb UmaShankar Subramani:
> Yes.
To be sure that I understand your problem, when client A commits something you want to send a file from client A to all
other clients, right?
Cheers
/Eike
Re: Invalidation Event (CSOSessionInvalidationEvent) [message #1693198 is a reply to message #1693193] Wed, 22 April 2015 11:07 Go to previous messageGo to next message
Yes. Exactly.
thanks,
Uma
Re: Invalidation Event (CSOSessionInvalidationEvent) [message #1693199 is a reply to message #1693198] Wed, 22 April 2015 11:11 Go to previous messageGo to next message
Am 22.04.2015 um 13:07 schrieb UmaShankar Subramani:
> Yes. Exactly.
Then you don't want to send that file in response to invalidation events, which occur on all clients.
Cheers
/Eike
Re: Invalidation Event (CSOSessionInvalidationEvent) [message #1693200 is a reply to message #1693199] Wed, 22 April 2015 11:32 Go to previous messageGo to next message
Yes. I do not want to send any other file. I just want to send only my file (which i generate).
/Uma
Re: Invalidation Event (CSOSessionInvalidationEvent) [message #1693202 is a reply to message #1693200] Wed, 22 April 2015 11:41 Go to previous message
Am 22.04.2015 um 13:32 schrieb UmaShankar Subramani:
See, that's why I suggested to implement and register a CDOTransactionHandler3.
Cheers
/Eike
Previous Topic:[CDO] Resolving merge conflicts
Next Topic:EMF usability improvement
Current Time: Fri Jul 23 15:27:35 GMT 2021
Powered by FUDForum. Page generated in 0.02490 seconds
