Home » Newcomers » Newcomers » JPA with MS access database(JPA with MS access database)
JPA with MS access database [message #1693047] Tue, 21 April 2015 08:28 Go to next message
I am learning JPA with eclipse luna.
I have MS Access database, and want to understand how to add a database connection with it.
Could anybody please help me on this.
Also, where can I find a complete tutorial for hello world example for JPA?
Shubhada
Re: JPA with MS access database [message #1693095 is a reply to message #1693047] Tue, 21 April 2015 12:00 Go to previous messageGo to next message
This is not the place for general Java programming questions; try a general programming forum or JPA forum instead, such as Stack Overflow, etc.
Re: JPA with MS access database [message #1693146 is a reply to message #1693095] Wed, 22 April 2015 01:33 Go to previous messageGo to next message
This is eclipse related question. I just want to know how to connect to ms access database through eclipse luna.
I followed following steps:
DataSource Explorer -->Database connections --> new -->"HERE DIDN'T FIND MS ACCESS LISTED"
Could you please tell how to add its connection?
Re: JPA with MS access database [message #1693220 is a reply to message #1693146] Wed, 22 April 2015 09:07 Go to previous messageGo to next message
That has nothing to do with JPA. Either way, you need to research using MS Access via JDBC - there are lots of resources about that available on the web. Once you can use JDBC to connect to Access, you can use that to connect with Eclipse's DataSource Explorer.
Re: JPA with MS access database [message #1693299 is a reply to message #1693146] Wed, 22 April 2015 23:13 Go to previous messageGo to next message
On 04/21/2015 11:33 PM, Shubhada Savdekar wrote:
> MS ACCESS LISTED"
Check out the Eclipse DTP forum. There might be help there.
Re: JPA with MS access database [message #1695042 is a reply to message #1693047] Mon, 11 May 2015 10:49 Go to previous message
My suggestion is to choose a different database. You're just creating problems for yourself by using MS Access from Java. Try downloading a copy of MySql or Postgres instead. Not only are they easier to work with (and significantly better as databases to begin with) but there's a ton of help articles available online for working with Java.
[Updated on: Mon, 11 May 2015 10:50] by Moderator
Previous Topic:Can't install RadRails on Eclipse Luna 4.4.2
Next Topic:Connect devices with eclipse..
Current Time: Sun Nov 02 12:39:00 EST 2025
Powered by FUDForum. Page generated in 0.08630 seconds
