Home » Modeling » OCL » Applying OCL at models (vs metamodels)
Applying OCL at models (vs metamodels) [message #1692999] Tue, 21 April 2015 07:35 Go to next message
Wilbert Alberts is currently offline Wilbert AlbertsFriend
I defined a language called sys using the ecore facilities. This language provides means to define so called Entities which are having Typed Attributes. (Very similar to ecore/uml classes.)
I know that I can add OCL constraints at this level to add additional validation capabilities.
I would like to give this language to users. They will make models containing Entities.
However, I would like to give them the ability to also add additional constraints. For instance, if they define an Job Entity which is having a weight, they might want to add an invariant to it stating that the weight should not exceed a certain amount. This invariant is not imposed on the sys language, but on a model expressed in the sys language.
Would it be possible to use OCL for this purpose? I think that I need to map certain OCL concepts to concepts in the sys language. For instance, what are objects in the sys language and what does it mean to dereference an object.
Has such thing tried before? Are they any examples, articles or anything else that I could study?
Greetings,
Wilbert
Re: Applying OCL at models (vs metamodels) [message #1693165 is a reply to message #1692999] Wed, 22 April 2015 08:16 Go to previous messageGo to next message
It's only software ... almost anything is possible.
More specifically I think you are looking at
https://bugs.eclipse.org/bugs/show_bug.cgi?id=457627.
Ed WIllink
On 21/04/2015 08:35, Wilbert Alberts wrote:
> language.
> Greetings,
> Wilbert
Re: Applying OCL at models (vs metamodels) [message #1698815 is a reply to message #1693165] Thu, 18 June 2015 07:05 Go to previous messageGo to next message
Denis Nikiforov is currently offline Denis NikiforovFriend
I need to achieve a similar thing. Suppose there is an UML model with a Person class. The Person class has an age attribute.
Is it possible to define the following OCL-constraint?
import mymodel : 'MyModel.uml'
package Root
context Person
inv: age > 0
endpackage
Is it possible to edit and validate such a constraint in the Complete OCL editor?
Does Eclipse OCL support a simillar scenario for Ecore-based model instances? For example I created an mydsl.ecore model. Is it possible to define constraints on the M1 layer (somemodel.mydsl) instead of M2 layer (mydsl.ecore)?
Re: Applying OCL at models (vs metamodels) [message #1698816 is a reply to message #1698815] Thu, 18 June 2015 07:19 Go to previous message
Sorry for stupid question Smile At least for UML it works fine Smile
Previous Topic:Access unnavigable opposites of reference and composition relations in Ecore
Next Topic:How to import an UML element into a pivot model?
Current Time: Mon Jan 20 05:36:03 GMT 2020
Powered by FUDForum. Page generated in 0.01967 seconds
