Home » Eclipse Projects » Sirius » How to export specified diagram programmatically
How to export specified diagram programmatically [message #1692079] Mon, 13 April 2015 05:30 Go to next message
Hello everyone,
I have learned how to export a diagram programmatically from https://www.eclipse.org/forums/index.php/t/813864/. Now I have a further question that how to export a specified diagram programmatically. For example in a case I have several EMF model instances in a Model Project. Each instance has a responding diagram. And I want to generate the diagram responding the selected instance.
Xue Liu
[Updated on: Mon, 13 April 2015 05:35] by Moderator
Re: How to export specified diagram programmatically [message #1692080 is a reply to message #1692079] Mon, 13 April 2015 05:36 Go to previous messageGo to next message
No Message Body
[Updated on: Mon, 13 April 2015 05:37] by Moderator
Re: How to export specified diagram programmatically [message #1692338 is a reply to message #1692079] Wed, 15 April 2015 03:31 Go to previous messageGo to next message
As indicated in [1], to export a specific representation, a diagram for
example, you can use following API :
DialectUIManager.INSTANCE.export(representation, session,
absoluteImagePath, new ExportFormat(ExportDocumentFormat.NONE,
ImageFileFormat.PNG), new NullProgressMonitor());
Best Regards.
[1] https://www.eclipse.org/forums/index.php/t/813864/
Le 13/04/2015 11:30, Xue Liu a écrit :
> Hello everyone,
> question that how to export a specified diagram programmatically. for
> example in a case that I have several EMF model instances in a Model
> Regards,
> Xue Liu
Esteban Dugueperoux - Obeo
Need professional services for Sirius?
Re: How to export specified diagram programmatically [message #1694214 is a reply to message #1692338] Sat, 02 May 2015 05:48 Go to previous messageGo to next message
Thank you for your reply. Actually I know using
The problem is how to specify the "representation" relating to the instance you choose.
Any new ideas ?
Xue Liu
Re: How to export specified diagram programmatically [message #1694985 is a reply to message #1694214] Mon, 11 May 2015 04:24 Go to previous message
Le 02/05/2015 11:48, Xue Liu a écrit :
> Any new ideas ?
I think that
DialectManager.INSTANCE.getRepresentations(EObject semantic, Session
session)
is whath you need.
> Regards,
> Xue Liu
Laurent
Laurent Redor - Obeo
Previous Topic:Montreal Roadshow 2015
Next Topic:Customize edge style
Current Time: Mon Jun 23 09:48:40 EDT 2025
Powered by FUDForum. Page generated in 0.52274 seconds
