Re: Attributes not showing [message #1692097 is a reply to message #1692037] |
Mon, 13 April 2015 12:24 |
Or, new in Mars M5, you can enable automatic synchronization of views
with the model. Either:
* in the Appearance properties, select the 'Synch with Model' option
* in your CSS stylesheet, set the canonical attribute. Something like this:
Class { canonical: true; }
HTH,
Christian
On 2015-04-12 15:14:51 +0000, Ed Willink said:
> Hi
> Try changing your right button menu filtering preferences / drag and
> drop them from the Model Explorer.
> Regards
> Ed Willink
> On 12/04/2015 14:18, Philippe de Rochambeau wrote:
>> In UML class diagrams, class attributes and methods aren't displayed.
>> Is this a bug?
Re: Attributes not showing [message #1692099 is a reply to message #1692097] |
Mon, 13 April 2015 12:26 |
Sorry, I meant Mars M6. Or whatever was the latest milestone.
Christian
On 2015-04-13 12:24:34 +0000, Christian W. Damus said:
> HTH,
> Christian
>> Hi
>> Regards
>> Ed Willink
>>> Is this a bug?
Re: Attributes not showing [message #1692152 is a reply to message #1692138] |
Tue, 14 April 2015 01:56 |
It's a milestone (pre-release) build of the upcoming 1.1 release. So,
quite different from the 1.0.2 release build that you have.
Christian
On 2015-04-13 20:48:39 +0000, Philippe de Rochambeau said:
> Mars M6? Which version is that? I am using Papyrus UML 1.0.2.v20150316134.
FUDForum. Page generated in 0.03780 seconds
