Home » Eclipse Projects » Sirius » How to handle Notes on diagrams
How to handle Notes on diagrams [message #1691872] Fri, 10 April 2015 05:03 Go to next message
In my metamodel, I provide an 'Annotation' concept. It contains a text attribute and can be associated with other Elements.
The diagram should display Annotations using the Note style as provided by Sirius. However, I am not completely clear on how to use this style.
First: is the body of such note represented by the Style's label attribute?
Second: does such note allow representation of a top level label and a body and if so, how to configure the style.
Third: even if setting the label's alignment to 'Left', it is still not completely displayed at the left margin. (See my screenschot.)
Any suggestions?
Greetings,
Wilbert.
  • Attachment: labelbug.png
    (Size: 120.80KB, Downloaded 137 times)
Re: How to handle Notes on diagrams [message #1691879 is a reply to message #1691872] Fri, 10 April 2015 05:30 Go to previous messageGo to next message
Hello Wilbert,
My answers below.
Steve
Le 10/04/2015 11:03, Wilbert Alberts a écrit :
Yes, it will display what is given in the "Label Expression" field.
No, there is only one label expression field. However, you can set an
expression that combines several properties of your semantic model.
In fact the label is aligned left/center/right but the inner text area
is centered. This is more obvious with a smaller text and an icon as you
can see in my screenshot. However, it sound reasonable to have the same
alignement for the inner text as the label widget so you can raise a
bugzilla.
> Any suggestions?
> Greetings,
> Wilbert.
Steve Monnier - Obeo
Need professional services for Sirius?
Re: How to handle Notes on diagrams [message #1691885 is a reply to message #1691879] Fri, 10 April 2015 06:02 Go to previous messageGo to next message
Did so: https://bugs.eclipse.org/bugs/show_bug.cgi?id=464378
Re: How to handle Notes on diagrams [message #1691886 is a reply to message #1691885] Fri, 10 April 2015 06:08 Go to previous message
Thank you!
Previous Topic:Cascading Style Definitions
Next Topic:Questions about diagram(notation) extension
Current Time: Tue Jun 24 01:13:15 EDT 2025
Powered by FUDForum. Page generated in 0.08796 seconds
