Re: Drag and Container Drop Problem [message #1691734 is a reply to message #1691732] |
Thu, 09 April 2015 10:54 |
I think what you meant as "viewpoint" is a diagram.
This will not work because each modeling project has its own editing
domain. However, in the modeling project containing the opened diagram,
you can load the semantic resource of the other modeling project. Under
the modeling project, you have an element "Project Dependencies". Select
its only contextual menu "Add model" and browe workspace to choose the
semantic model of the second modeling project. Now you will see the
second semantic resource under the Project Dependencies element and
should be able to perform your drag and drop.
Steve
Le 09/04/2015 12:44, Arunkumar Ramaswamy a écrit :
> I have implemented a drag and container drop functionality. Now I am
> able to drag and drop from both different viewpoint and model explorer.
> But I am not able to do it when i dragged the model from another model.
> For example: i have two modeling projects (based on same metamodel and
> same sirius design) I want to drag and drop from one viewpoint of first
> model to another viewpoint of second model)
> Currently my implementation works within same model only !!!
> Any help much appreciated.
Steve Monnier - Obeo
Need professional services for Sirius?
Steve Monnier - Obeo Canada
FUDForum. Page generated in 0.02960 seconds
