Re: Eclipse has an installer! [message #1692235 is a reply to message #1691680] |
Tue, 14 April 2015 12:42   |
Andrew Mazar wrote on Wed, 08 April 2015 23:07Looks cool. What's the advantage of having it install though? Will there be some interesting installation options, like preinstall software stuffs? Hmm...
Easier to combine packages together, and it also walks you through some default preferences that are easier to miss. Also, it allows you to record/save preferences, and to apply preference changes to all your workspaces.
Denis Roy
Eclipse Webmaster -- webmaster@eclipse.org
Re: Eclipse has an installer! [message #1699785 is a reply to message #1699718] |
Fri, 26 June 2015 15:00   |
Oleg Šelajev wrote on Fri, 26 June 2015 03:28
How does one package an existing Eclipse Mars installation as a "User package" for Eclipse Installer by Oomph?
What I really want to preserve and be reconfigured on install are:
* Installation settings, eclipse.ini contents
* Plugins and their configuration
* Workspace projects or at least their list and VCS urls
* Settings and configuration (line numbers, formatter, content assist, templates, types to import)
Are these things possible to persist in a User package at all?
Is there any documentation on the subject?
Thank you!
Your best option is to ask in the Oomph forum:
https://www.eclipse.org/forums/index.php/f/287/
Denis Roy
Re: Eclipse has an installer! [message #1711636 is a reply to message #1709274] |
Sun, 18 October 2015 20:25   |
OpenOffice Bugs Messages: 2 Registered: September 2015 |
Eike Stepper wrote on Fri, 25 September 2015 14:28Am 18.09.2015 um 21:27 schrieb OpenOffice Bugs:
> I tried to install Eclipse Mars using the Eclipse Installer, and it gave me an error message saying I need JDK 8.
> I'm using JDK 7 because my computer still uses Windows XP, where JDK 8 isn't supported.
> I was able to get Eclipse to run by installing it manually, and putting a reference to my JDK in eclipse.ini.
Please note that the installer binaries that are available on the main download page now only require Java 7.
Apologies for the late reply, but thanks for fixing the installer!
[Updated on: Sun, 18 October 2015 20:26] Report message to a moderator
FUDForum. Page generated in 0.04378 seconds
