Home » Eclipse Projects » RCP Testing Tool » AUT connection failing(AUT connection is getting failed )
AUT connection failing [message #1691598] Wed, 08 April 2015 08:16 Go to next message
When I run the product under test, the product is getting launched, after some i m getting a pop up "AUT connection has been failing for 537.0 seconds" .
index.php/fa/21485/0/
I have attached the error log for the reference.
Kindly help me in solving the issue.
Abhirami K
Re: AUT connection failing [message #1691609 is a reply to message #1691598] Wed, 08 April 2015 09:03 Go to previous messageGo to next message
Thank you for contacting us!
Please attach error log again, it was attached with an error.
Also could you please provide us with some additional information which typically helps us to investigate AUT startup issues:
  1. Original <your AUT>.ini, <your AUT>/configuration/config.in and <your AUT>/configuration/org.eclipse.equinox.simpleconfigurator/bundles.info (if present)
  2. RCPTT-generated config files: <rcptt-workspace>/.metadata/.plugins/org.eclipse.pde.core/<your aut name>/config.ini and <rcptt-workspace>/.metadata/.plugins/org.eclipse.pde.core/<your aut name>/org.eclipse.equinox.simpleconfigurator/bundles.info (if present)
  3. Generated .launch file: <rcptt-workspace>/.metadata/.plugins/org.eclipse.debug.core/.launches/<your aut name>.launch
In all files above please feel free to remove/replace any information you consider to be proprietary, we are only interested in Eclipse platform-related bundles and options
Re: AUT connection failing [message #1691728 is a reply to message #1691609] Thu, 09 April 2015 06:15 Go to previous messageGo to next message
Hi Olga,
Thanks for the response.
I am attaching the additional information/ log files you would need.
I have renamed certain sensible information, apart from that the logs are unchanged.
Abhirami K
[Updated on: Thu, 09 April 2015 06:17] by Moderator
Re: AUT connection failing [message #1707249 is a reply to message #1691598] Thu, 03 September 2015 05:50 Go to previous messageGo to next message
Abhirami Kumaraguruparan wrote on Wed, 08 April 2015 12:16
Abhirami K
I have the same issue.
Could you tell me if you found any workaround ?
Thanks in advance
Re: AUT connection failing [message #1709538 is a reply to message #1691728] Tue, 29 September 2015 04:05 Go to previous messageGo to next message
Hello Abhirami K,
There is an error in console log:
Caused by: com.continental.license.internal.core.InvalidLicenseException: The license is invalid for the product CESSAR-CT_3209
It seems that license verification is failed for your product, could you please check it?
Please try to run your AUT with correct license with RCPTT based on Mars?
What is the result?
Re: AUT connection failing [message #1709540 is a reply to message #1707249] Tue, 29 September 2015 04:11 Go to previous message
Hello Angelo,
In the previous case there is a problem with product license.
Which version of RCPTT do you use?
Could you please attach additional details for diagnostic:
  • AUT Console.log
  • Original <your AUT>.ini, <your AUT>/configuration/config.in and <your AUT>/configuration/org.eclipse.equinox.simpleconfigurator/bundles.info (if present)
  • RCPTT-generated config files: <rcptt-workspace>/.metadata/.plugins/org.eclipse.pde.core/<your aut name>/config.ini and <rcptt-workspace>/.metadata/.plugins/org.eclipse.pde.core/<your aut name>/org.eclipse.equinox.simpleconfigurator/bundles.info (if present)
  • Generated .launch file: <rcptt-workspace>/.metadata/.plugins/org.eclipse.debug.core/.launches/<your aut name>.launch
Previous Topic:Dismissing a File Chooser Dialog
Next Topic:multiple RCPTT projects
Current Time: Fri Jul 18 11:05:31 EDT 2025
Powered by FUDForum. Page generated in 0.05017 seconds
