Re: Best strategy to use for <XML -> Custom-EMF model> [message #1690981 is a reply to message #1690972] |
Wed, 01 April 2015 12:11 |
Ed Merks Messages: 33141 Registered: July 2009 |
Stefan,
It's not clear how different those two representations are, so it's hard
to comment... To me generally it seems easier to have two well-defined
Java APIs and write Java code to map instances between those
representations than to write Java code for serializer and deserializer
logic. I doubt performance will be a significant concern either way.
On 01/04/2015 12:56 PM, Stefan Winkler wrote:
> I am currently facing the following question:
> I have an XSD which defines my XML data structure.
> And I have an (existing) Ecore model which defines my custom (target)
> EMF data structure.
> I now need to read and write XML-files based on the XSD which shall be
> represented in the custom EMF model.
> I have done searches and found out that there is no out-of-the-box way
> to map XSD to a custom Ecore model (correct my if I'm mistaken).
> Graphically, there is no way to do this
> XML (XSD) <-------[ EMF magic ]------> EMF (Ecore)
> So my question now is: does anyone have experience with similar
> settings? How did/would you solve this?
> Intuitively, I can imagine parsing the XML myself, thus doing this:
> XML (XSD) <-------[ custom SAX-based logic ]------> EMF (Ecore)
> Or I could generate an intermediate Ecore model for the XSD which does
> the XML reading/writing for me, but then I have to create mapping logic
> to my EMF model like this:
> XML (XSD) <-[ EMF serialization ]-> XSD_EMF (Ecore) <-- ...
> ... --[ EMF serialization ]-> EMF (Ecore)
> Does anyone have an opinion which approach seems better (both in terms
> of runtime performance, and in development effort).
> Thanks in advance,
> Stefan
Ed Merks
FUDForum. Page generated in 0.03738 seconds
