How can I use JvmModelInferrer and old Generator approach in parallel [message #1690899] |
Tue, 31 March 2015 20:00 |
How do I have to configure my Xtext project to enable the use of JvmModelInferrer and the old generator parallel in one project ?
I already have the following in my mwe2-File:
// generator API
fragment = generator.GeneratorFragment auto-inject {}
// provides the necessary bindings for java types integration
fragment = types.TypesGeneratorFragment auto-inject {}
// generates the required bindings only if the grammar inherits from Xbase
fragment = xbase.XbaseGeneratorFragment auto-inject {}
// generates the required bindings only if the grammar inherits from Xtype
fragment = xbase.XtypeGeneratorFragment auto-inject {}
The basic generator class does get generated but it is not called when I save my model.
What is wrong ?
Re: How can I use JvmModelInferrer and old Generator approach in parallel [message #1690982 is a reply to message #1690942] |
Wed, 01 April 2015 12:15 |
Karsten Thoms wrote on Wed, 01 April 2015 02:43or create another IGenerator as generator root, inject the JvmModelGenerator and dispatch to it and the other templates.
I created my own IGenerator implementation:
class IGeneratorRoot implements IGenerator {
@Inject
JvmModelGenerator jvmModelGenerator
@Inject
ContentProviderGenerator contentProviderGenerator
override doGenerate(Resource input, IFileSystemAccess fsa) {
jvmModelGenerator.doGenerate(input, fsa)
contentProviderGenerator.doGenerate(input, fsa)
and added this to my RuntimeModule:
public Class<? extends ContentProviderGenerator> bindContentProviderGenerator() {
return ContentProviderGenerator.class;
@SuppressWarnings("restriction")
public Class<? extends JvmModelGenerator> bindJvmModelGenerator() {
return JvmModelGenerator.class;
public Class<? extends IGenerator> bindIGenerator() {
return IGeneratorRoot.class;
but I get the following error:
1496 [Worker-2] ERROR org.eclipse.xtext.xbase.jvmmodel.JvmTypesBuilder - The source element must be contained in a resource
java.lang.IllegalArgumentException: The source element must be contained in a resource
at org.eclipse.xtext.xbase.jvmmodel.JvmTypesBuilder.isValidSource(JvmTypesBuilder.java:651)
at org.eclipse.xtext.xbase.jvmmodel.JvmTypesBuilder.associate(JvmTypesBuilder.java:642)
at org.eclipse.xtext.xbase.jvmmodel.JvmTypesBuilder.toParameter(JvmTypesBuilder.java:823)
at de.mdsd.xtext.android.contentprovider.jvmmodel.ContentProviderJvmModelInferrer.lambda$8(ContentProviderJvmModelInferrer.java:300)
at de.mdsd.xtext.android.contentprovider.jvmmodel.ContentProviderJvmModelInferrer$$Lambda$15/1169816667.apply(Unknown Source)
at org.eclipse.xtext.xbase.jvmmodel.JvmTypesBuilder.initializeSafely(JvmTypesBuilder.java:208)
at org.eclipse.xtext.xbase.jvmmodel.JvmTypesBuilder.toMethod(JvmTypesBuilder.java:689)
at de.mdsd.xtext.android.contentprovider.jvmmodel.ContentProviderJvmModelInferrer.lambda$0(ContentProviderJvmModelInferrer.java:320)
at de.mdsd.xtext.android.contentprovider.jvmmodel.ContentProviderJvmModelInferrer$$Lambda$1/1722450363.apply(Unknown Source)
at org.eclipse.xtext.xbase.jvmmodel.JvmTypesBuilder.toClass(JvmTypesBuilder.java:386)
at de.mdsd.xtext.android.contentprovider.jvmmodel.ContentProviderJvmModelInferrer._infer(ContentProviderJvmModelInferrer.java:323)
at de.mdsd.xtext.android.contentprovider.jvmmodel.ContentProviderJvmModelInferrer.infer(ContentProviderJvmModelInferrer.java:329)
at org.eclipse.xtext.xbase.jvmmodel.JvmModelAssociator.installDerivedState(JvmModelAssociator.java:382)
at org.eclipse.xtext.resource.DerivedStateAwareResource.installDerivedState(DerivedStateAwareResource.java:227)
at org.eclipse.xtext.xbase.resource.BatchLinkableResource.getContents(BatchLinkableResource.java:148)
at org.eclipse.xtext.xbase.typesystem.internal.LogicalContainerAwareBatchTypeResolver.getEntryPoints(LogicalContainerAwareBatchTypeResolver.java:44)
at org.eclipse.xtext.xbase.typesystem.internal.DefaultBatchTypeResolver.getTypeResolver(DefaultBatchTypeResolver.java:63)
at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver$1.get(CachingBatchTypeResolver.java:49)
at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver$1.get(CachingBatchTypeResolver.java:1)
at org.eclipse.xtext.util.OnChangeEvictingCache.get(OnChangeEvictingCache.java:77)
at org.eclipse.xtext.xbase.typesystem.internal.CachingBatchTypeResolver.doResolveTypes(CachingBatchTypeResolver.java:46)
at org.eclipse.xtext.xbase.typesystem.internal.AbstractBatchTypeResolver.resolveTypes(AbstractBatchTypeResolver.java:69)
at org.eclipse.xtext.xbase.resource.BatchLinkingService.resolveBatched(BatchLinkingService.java:64)
at org.eclipse.xtext.xbase.resource.BatchLinkableResource.resolveLazyCrossReferences(BatchLinkableResource.java:165)
at org.eclipse.xtext.EcoreUtil2.resolveLazyCrossReferences(EcoreUtil2.java:522)
at org.eclipse.xtext.ui.editor.reconciler.XtextDocumentReconcileStrategy.postParse(XtextDocumentReconcileStrategy.java:174)
at org.eclipse.xtext.ui.editor.reconciler.XtextDocumentReconcileStrategy.doReconcile(XtextDocumentReconcileStrategy.java:152)
at org.eclipse.xtext.ui.editor.reconciler.XtextDocumentReconcileStrategy.reconcile(XtextDocumentReconcileStrategy.java:66)
at org.eclipse.xtext.ui.editor.reconciler.XtextReconciler.doRun(XtextReconciler.java:445)
at org.eclipse.xtext.ui.editor.reconciler.XtextReconciler.access$3(XtextReconciler.java:425)
at org.eclipse.xtext.ui.editor.reconciler.XtextReconciler$1.process(XtextReconciler.java:366)
at org.eclipse.xtext.ui.editor.reconciler.XtextReconciler$1.process(XtextReconciler.java:1)
at org.eclipse.xtext.util.concurrent.IUnitOfWork$Void.exec(IUnitOfWork.java:37)
at org.eclipse.xtext.resource.OutdatedStateManager.exec(OutdatedStateManager.java:121)
at org.eclipse.xtext.ui.editor.model.XtextDocument$XtextDocumentLocker.modify(XtextDocument.java:428)
at org.eclipse.xtext.ui.editor.model.XtextDocument.internalModify(XtextDocument.java:162)
at org.eclipse.xtext.ui.editor.reconciler.XtextReconciler.run(XtextReconciler.java:363)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
I guess there is something wrong with the injection.
FUDForum. Page generated in 0.05729 seconds
