Re: Empty comments in imported XMI-based UML [message #1690690 is a reply to message #1690680] |
Mon, 30 March 2015 15:55   |
André Pankraz Messages: 5 Registered: March 2015 |
You are right, this was uncalled for. Someone tries to copy Linus-attitude here.
I just have a MagicDraw Export, which has the feature: Export Eclipse UML2 v4. Internally they use org.eclipse.uml2.uml_4.0.1 for writing the attached XMI export from a minimal Model with a comment.
It could be possible to just do this in Eclipse with same UML2 SDK, just create Model with Model element, attach comment, save.
Comment text should be "body"-attribute in XMI.
Same with SDK v4: "body"-subelement.
But I have no old Eclipse with SDK v4.0.1 und I'm not an UML-XMI expert.
Ed Willink wrote on Mon, 30 March 2015 15:08Hi
To be brutally honest.
"The interesting problem here is"
There is nothing interesting here without a complete file.
Ed Willink
On 30/03/2015 15:19, André Pankraz wrote:
> Might be a problem with your client? I used #xA and can see it in my
> post.
> To avoid confusion, I reduced the example to:
> Doesn't work:
> <ownedComment xmi:id="_18_0_2_617020b_1427462788135_117706_3985"
> annotatedElement="eee_1045467100313_135436_1" body="TEST"/>
> Works:
> annotatedElement="eee_1045467100313_135436_1" >
> <body>TEST</body>
> </ownedComment>
> The interesting problem here is, that MD18 with Eclipse UML2 SDK v4.x
> exports the ownedComment-text as body-attribute, and Eclipse UML2 v5.x
> SDK cannot read this (it wants it as a sub element <body>).
> Best regards,
> André
> Ed Willink wrote on Mon, 30 March 2015 13:56
>> Hi
>> That looks correct to me. I don't think that you are allowed to have
>> new-lines in non-data elements (in any XML version). Use &xA;
>> Regards
>> Ed Willink
Attachment: v4.zip
(Size: 631.54KB, Downloaded 200 times)
Re: Empty comments in imported XMI-based UML [message #1690817 is a reply to message #1690690] |
Tue, 31 March 2015 13:24   |
Ed Willink Messages: 7503 Registered: July 2009 |
You are right. I couldn't really believe that comments could go so
wrong. But with a concrete example it's difficult to argue.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=463551 raised.
Workaround: just change all your "http://www.eclipse.org/uml2/4.0.0/UML"
nsURIs to "http://www.eclipse.org/uml2/5.0.0/UML".
Ed Willink
>> Hi
>> Regards
>> Ed Willink
>>> Hi,
>>> post.
>>> Doesn't work:
>>> Works:
>>> <body>TEST</body>
>>> </ownedComment>
>>> Best regards,
>>> André
>>>> Hi
>>>> Regards
>>>> Ed Willink
FUDForum. Page generated in 0.02394 seconds
