Home » Eclipse Projects » EclipseLink » Error inserting certain UTF-8 characters into MySql database
Error inserting certain UTF-8 characters into MySql database [message #1690238] Thu, 26 March 2015 00:19 Go to next message
Ralf Heydenreich is currently offline Ralf HeydenreichFriend
Hi all,
I have some Lithuanian strings that can't be inserted in a MySQL
database via EclipseLink JPA. I have the following string: "Ukmergės
kel. Užubalių k.". The database gets "Ukmerg?s kel. Užubali? k.". Since
I can insert this string into the database via an INSERT command (with a
database tool) correctly, I assume that the connection isn't set up
right. The JDBC string looks like follows:
javax.persistence.jdbc.url=jdbc\:mysql\://localhost/mystrangedb?useUnicode=yes&characterEncoding=UTF-8
I've checked the string with debug view (in Eclipse). There it was also
correct. Is there any extra setting for Unicode encoding in EclipseLink?
Any help would be appreciated.
Ralf.
Re: Error inserting certain UTF-8 characters into MySql database [message #1690239 is a reply to message #1690238] Thu, 26 March 2015 00:23 Go to previous messageGo to next message
Rick Curtis is currently offline Rick CurtisFriend
What is the version of your MySQL JDBC driver?
Re: Error inserting certain UTF-8 characters into MySql database [message #1690358 is a reply to message #1690239] Thu, 26 March 2015 20:24 Go to previous message
Am 26.03.2015 um 01:23 schrieb Rick Curtis:
I'm using version 5.1.30 of the MySQL driver.
Ralf.
Previous Topic:Getting Configuration error. Class [drive-class] not found intermittently
Next Topic:Is it possible to weave a .class file programmatically
Current Time: Fri Apr 19 10:15:45 GMT 2024
Powered by FUDForum. Page generated in 0.01829 seconds
