Home » Eclipse Projects » BPMN 2.0 Modeler » GMF/EFM BPMN2 Modeler project(We are find GMF/EFM BPMN2 Modeler project)
GMF/EFM BPMN2 Modeler project [message #1689851] Tue, 24 March 2015 13:44 Go to next message
Enyo Goncalves is currently offline Enyo GoncalvesFriend
Hi all,
We are working to add OCL validations rule in CPMN2 Modeler. We need the project in GMF/EFM of the tool to realize it, however it is not avaliable. Could you help us?
Re: GMF/EFM BPMN2 Modeler project [message #1689874 is a reply to message #1689851] Tue, 24 March 2015 14:43 Go to previous messageGo to next message
Robert Brodt is currently offline Robert BrodtFriend
The BPMN2 Modeler does not use GMF - it uses Graphiti instead. Not sure what EFM is, did you mean EMF?
I really don't understand what you are asking for here...If you are trying to add OCL validations to the BPMN2 Modeler project, you can just add on to the existing <constraintBinding> extension point in the editor core.
Re: GMF/EFM BPMN2 Modeler project [message #1690567 is a reply to message #1689874] Sat, 28 March 2015 23:34 Go to previous messageGo to next message
Hi Robert,
Thanks.
I worked with GMF in other projects, but now I am starting a new work with BPMN2 modeller.
I am trying to add OCL validations to the BPMN2 Modeler project.
In which file I can just add on to the existing <constraintBinding> extension point?
Re: GMF/EFM BPMN2 Modeler project [message #1690670 is a reply to message #1690567] Mon, 30 March 2015 13:46 Go to previous message
You'll need to create an extension plugin. Have a look at the Extending the BPMN2 Runtime tutorial to get started. Then you can add your <constraintBinding> extension to your plugin.xml
Previous Topic:User task with notification
Next Topic:TextObjectEditor - setMultiLine(true) not working as expected?
Current Time: Wed Jun 03 05:27:46 GMT 2020
Powered by FUDForum. Page generated in 0.01961 seconds
