Eclipse Error: Permission Denied. [message #1689461] |
Mon, 23 March 2015 16:17 |
Lazy Shetty Messages: 3 Registered: October 2014 |
Junior Member |
i'm using,
Eclipse CDT
Version: Mars
Milestone 3 (4.5.0M3)
Build id: 20141113-0320
while trying to compiling a basic CPP code, the execution stopped giving an error message "c.exe stopped working".
after this i tried to rebuild and run the code, but while rebuilding the code i got the below error on the console;
21:15:50 **** Incremental Build of configuration Debug for project C ****
Info: Internal Builder is used for build
g++ -o C.exe cc.o
c:/mingw/bin/../lib/gcc/x86_64-w64-mingw32/4.9.1/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot open output file C.exe: Permission denied
collect2.exe: error: ld returned 1 exit status
21:15:50 Build Finished (took 180ms)
i tried to restart the Eclipse, but it didn't worked.
i tried to delete the file , didn't work.
i tried to clean project, didn't work.
if u say like it might be running in another window, i have been using only one eclipse window and only one console.
i fear that it might be running in the background. if so, how can i terminate it.
looking forward for a solution.
Thanks in advance.
Shetty.
FUDForum. Page generated in 0.03561 seconds
