Re: How to provide feedback to the user for non creatable edges [message #1689900 is a reply to message #1689418] |
Tue, 24 March 2015 15:37   |
Le 23/03/2015 15:37, Martin Schreiber a écrit :
> I do have an "Element based Edge" and a creation tool for it.
> I am using a java service to determine if a connection is possible or
> not using the service in the "Connection Complete Precondition"
> expression. There is this icon next to the mouse pointer showing if a
> connection is possible or not (based on what the "Connection Complete
> Precondition" expression returns. That is great, but there might be
> different cases why a connection cannot be made.
> Is there a way to set a text (like a tooltip) right next to the icon
> showing that the connection cannot be made?
Unfortunately, there is currently no way to do that.
A such feature requires:
* a technical way in GEF/GMF to display this kind of information when
tool is forbidden.
* adaptation of Sirius to use it with a new field in VSM for this
explanation text
> thanks!
Best Regards,
Laurent Redor - Obeo
Need professional services for Sirius?
Re: How to provide feedback to the user for non creatable edges [message #1690262 is a reply to message #1690098] |
Thu, 26 March 2015 08:20  |
Le 25/03/2015 10:11, Martin Schreiber a écrit :
> Hi Laurent,
> thanks for your response.
> I did find a way that works for me.
> As I said, I am using a service which checks as precondition if a
> connection could be created or not.
> Connection Complete Precondition:
> "[isConnectionPossible(preSource, preTarget) /]"
> Within that service method ("isConnectionPossible") I do something like
> this:
> Display.getDefault().asyncExec(() -> {
> if (Display.getDefault().getCursorControl() != null) {
> Display.getDefault().getCursorControl().setToolTipText("The message why
> connection not possible");
> in case I want to display why the connection could not be made.
> Not sure if this is an elegant way to do it, but it works fine for me.
Indeed, there is a risk with asyncExec. The toolTip could be displayed
on the standard cursor and never removed.
> It would still be a cool feature if Sirius would support that by a new
> field like "Connection Status Text" or similar...
We have no plans to work on this feature in the following weeks. That
said this feature can move forward if you provide a solution for it (see
the Contributor Guide) or you contact Obeo for sponsored work.
> thanks!
> martin
FUDForum. Page generated in 0.02122 seconds
