Home » Eclipse Projects » DTP » Help with Ecore ODA Driver - Need MindMap data
Help with Ecore ODA Driver - Need MindMap data [message #32918] Tue, 17 July 2007 06:18 Go to next message
Jeff Ramsdale is currently offline Jeff RamsdaleFriend
I had several offers to help with work on an Ecore ODA driver. What I
most need right now is more robust test data. Would someone be willing
to produce some sample data conforming to the MindMap model as mentioned
in the Bugzilla entry for this feature request?
Bugzilla entry:
< https://bugs.eclipse.org/bugs/show_bug.cgi?id=132958&que ry_format=specific&order=relevance+desc&bug_status=_ _open__>
Model:
< http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.gmf/exa mples/org.eclipse.gmf.examples.mindmap/model/mindmap.ecore?r evision=1.1&root=Modeling_Project>
Jeff
Re: Help with Ecore ODA Driver - Need MindMap data [message #32988 is a reply to message #32918] Thu, 19 July 2007 15:41 Go to previous messageGo to next message
Jeff,
Probably it's best just to manufacture your own using the generated
editor. I'm not sure there are any real world uses of this sample model...
> mentioned in the Bugzilla entry for this feature request?
> Bugzilla entry:
> Model:
> Jeff
Re: Help with Ecore ODA Driver - Need MindMap data [message #37971 is a reply to message #32918] Fri, 02 November 2007 20:20 Go to previous messageGo to next message
Originally posted by: jconlon.apache.org
Hi Jeff,
I've been a sleep at the wheel - just now checked the dtp mail list and
saw your Ecore threads. (Had been watching EMF and Birt. DUH.)
Do you still need MindMap data??
Is there anything else I can do to help?
best regards,
John Conlon
> Bugzilla entry:
> Model:
> Jeff
Re: Help with Ecore ODA Driver - Need MindMap data [message #37997 is a reply to message #37971] Mon, 05 November 2007 05:53 Go to previous messageGo to next message
Sure thing! I'd slowed down a bit working on it, but was just easing
back into development. Could still use some good test data--if you'd
want to jump in that'd be a good place. I believe I have a basic driver
working but I don't have much for the UI yet.
Someone else has contacted me about helping on the project but we were
just getting started discussing how best to collaborate. Since our goal
is to donate the code (but that takes a while, from what I hear) we need
a place to park until the process is complete.
Jeff
John E. Conlon wrote:
> Hi Jeff,
> best regards,
> John Conlon
>> Bugzilla entry:
>> Model:
>> Thanks,
>> Jeff
Re: Help with Ecore ODA Driver - Need MindMap data [message #38123 is a reply to message #37997] Mon, 05 November 2007 16:18 Go to previous messageGo to next message
Cool. Glad to help.
You still want it as a mindmap model? Not too familiar with the model,
but I do use the Java based mindmap application FreeMind so I am
familiar with the problem domain. (I am assuming it is the same.) If
you wand the data as a mindmap model a trivial question comes to mind -
do you have a subject you would like to map out?
BTW-Why mindmap and not the perennially favorite Library or
PurchaseOrder variants?
First things first.
Do you mean a code repository site?
regards,
John
> Jeff
>> Hi Jeff,
>> and saw your Ecore threads. (Had been watching EMF and Birt. DUH.)
>> best regards,
>> John Conlon
>>> willing to produce some sample data conforming to the MindMap model
>>> as mentioned in the Bugzilla entry for this feature request?
>>> Bugzilla entry:
>>> Model:
>>> Thanks,
>>> Jeff
Re: Help with Ecore ODA Driver - Need MindMap data [message #38219 is a reply to message #37997] Tue, 06 November 2007 00:50 Go to previous messageGo to next message
--------------080403060101020806020705
Hi Jeff,
While I now understand the mindmap model structure, I am not too sure
about the use cases for these mindmap elements. This model is not much
like the other mindmap software that I have worked with.
Nevertheless I created a mindmap model called oda4Emf.mindmap and a
mindmap gmf diagram oda4Emf.mmd. These files are attached.
Note: While the contents may have some relationship to the project of
creating a ODA 4 EMF, the actual content was just created to fill the
need for test data.
As mentioned above I just sort of winged it so this model may contain
some usage mistakes that need correcting. Like I said, I really don't
understand the use cases for the different elements of the model.
Do you think that this mindmap model may present too unusual model for
the report writers?
cheers,
John
> Jeff
>> Hi Jeff,
>> best regards,
>> John Conlon
>>> Bugzilla entry:
>>> Model:
>>> Thanks,
>>> Jeff
Content-Type: text/xml;
name="oda4Emf.mindmap"
Content-Disposition: inline;
filename="oda4Emf.mindmap"
PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiPz4KPG1pbmRt YXA6bWFwIHht
bG5zOm1pbmRtYXA9Imh0dHA6Ly93d3cuZXhhbXBsZS5vcmcvbWluZG1hcCIg dGl0bGU9IkNy
ZWF0aW5nIGFuIE9EQSBmb3IgRU1GIj4KICA8cm9vdFRvcGljcyBuYW1lPSJQ ZXJpb2RpY2Fs
Ii8+CiAgPHJvb3RUb3BpY3MgbmFtZT0iRWNsaXBzZSBNYWdhemluZSIvPgog IDxyb290VG9w
aWNzIG5hbWU9ImVjbGlwc2UuZHRwIj4KICAgIDxjb21tZW50cyBhdXRob3I9 IiMvL0BtYXAv
QHJlc291cmNlcy4yIiBwb3N0RGF0ZT0iMjAwNy0wNy0xNiIgc3ViamVjdD0i SGVscCB3aXRo
IEVjb3JlIE9EQSBEcml2ZXIgLSBOZWVkIE1pbmRNYXAgZGF0YSI+CiAgICAg IDxpdGVtcy8+
CiAgICAgIDxpdGVtcyBhdXRob3I9IiMvL0BtYXAvQHJlc291cmNlcy4yIiBi b2R5PSJJIGhh
ZCBzZXZlcmFsIG9mZmVycyB0byBoZWxwIHdpdGggd29yayBvbiBhbiBFY29y ZSBPREEgZHJp
dmVyLiBXaGF0IEkgbW9zdCBuZWVkIHJpZ2h0IG5vdyBpcyBtb3JlIHJvYnVz dCB0ZXN0IGRh
dGEuIFdvdWxkIHNvbWVvbmUgYmUgd2lsbGluZyAmI3hBO3RvIHByb2R1Y2Ug c29tZSBzYW1w
bGUgZGF0YSBjb25mb3JtaW5nIHRvIHRoZSBNaW5kTWFwIG1vZGVsIGFzIG1l bnRpb25lZCBp
biB0aGUgQnVnemlsbGEgZW50cnkgZm9yIHRoaXMgZmVhdHVyZSByZXF1ZXN0 PyIgaXRlbVBv
c3REYXRlPSIyMDA3LTA3LTE2Ii8+CiAgICAgIDxpdGVtcy8+CiAgICAgIDxp dGVtcyBhdXRo
b3I9IiMvL0BtYXAvQHJlc291cmNlcy4zIiBib2R5PSIiLz4KICAgICAgPGl0 ZW1zIGF1dGhv
cj0iIy8vQG1hcC9AcmVzb3VyY2VzLjMiIGJvZHk9IkplZmYsIFByb2JhYmx5 IGl0J3MgYmVz
dCBqdXN0IHRvIG1hbnVmYWN0dXJlIHlvdXIgb3duIHVzaW5nIHRoZSBnZW5l cmF0ZWQgZWRp
dG9yLiAgSSdtIG5vdCBzdXJlIHRoZXJlIGFyZSBhbnkgcmVhbCB3b3JsZCB1 c2VzIG9mIHRo
aXMgc2FtcGxlIG1vZGVsLi4uIiBpdGVtUG9zdERhdGU9IjIwMDctMDctMTki Lz4KICAgICAg
PGl0ZW1zIGF1dGhvcj0iIy8vQG1hcC9AcmVzb3VyY2VzLjAiIGJvZHk9Ikhp IEplZmYsIEkn
dmUgYmVlbiBhIHNsZWVwIGF0IHRoZSB3aGVlbCAtIGp1c3Qgbm93IGNoZWNr ZWQgdGhlIGR0
cCBtYWlsIGxpc3QgYW5kIHNhdyB5b3VyIEVjb3JlIHRocmVhZHMuICAoSGFk IGJlZW4gd2F0
Y2hpbmcgRU1GIGFuZCBCaXJ0LiBEVUguKSYjeEE7JiN4QTtEbyB5b3Ugc3Rp bGwgbmVlZCBN
aW5kTWFwIGRhdGE/PyBJcyB0aGVyZSBhbnl0aGluZyBlbHNlIEkgY2FuIGRv IHRvIGhlbHA/
IGJlc3QgcmVnYXJkcywgSm9obiBDb25sb24iIGl0ZW1Qb3N0RGF0ZT0iMjAw Ny0xMS0wMyIv
PgogICAgICA8aXRlbXMvPgogICAgICA8aXRlbXMvPgogICAgICA8aXRlbXMv PgogICAgICA8
aXRlbXMgYXV0aG9yPSIjLy9AbWFwL0ByZXNvdXJjZXMuMiIgYm9keT0iU3Vy ZSB0aGluZyEg
SSdkIHNsb3dlZCBkb3duIGEgYml0IHdvcmtpbmcgb24gaXQsIGJ1dCB3YXMg anVzdCBlYXNp
bmcgYmFjayBpbnRvIGRldmVsb3BtZW50LiBDb3VsZCBzdGlsbCB1c2Ugc29t ZSBnb29kIHRl
c3QgZGF0YS0taWYgeW91J2Qgd2FudCB0byBqdW1wIGluIHRoYXQnZCBiZSBh IGdvb2QgcGxh
Y2UuIEkgYmVsaWV2ZSBJIGhhdmUgYSBiYXNpYyBkcml2ZXIgd29ya2luZyBi dXQgSSBkb24n
dCBoYXZlIG11Y2ggZm9yIHRoZSBVSSB5ZXQuJiN4QTsmI3hBO1NvbWVvbmUg ZWxzZSBoYXMg
Y29udGFjdGVkIG1lIGFib3V0IGhlbHBpbmcgb24gdGhlIHByb2plY3QgYnV0 IHdlIHdlcmUg
anVzdCBnZXR0aW5nIHN0YXJ0ZWQgZGlzY3Vzc2luZyBob3cgYmVzdCB0byBj b2xsYWJvcmF0
ZS4gU2luY2Ugb3VyIGdvYWwgaXMgdG8gZG9uYXRlIHRoZSBjb2RlIChidXQg dGhhdCB0YWtl
cyBhIHdoaWxlLCBmcm9tIHdoYXQgSSBoZWFyKSB3ZSBuZWVkIGEgcGxhY2Ug dG8gcGFyayB1
bnRpbCB0aGUgcHJvY2VzcyBpcyBjb21wbGV0ZS4gSmVmZiAiIGl0ZW1Qb3N0 RGF0ZT0iMjAw
Ny0xMS0wNCIvPgogICAgICA8aXRlbXMgYXV0aG9yPSIjLy9AbWFwL0ByZXNv dXJjZXMuMCIg
Ym9keT0iQ29vbC4gIEdsYWQgdG8gaGVscC4gWW91IHN0aWxsIHdhbnQgaXQg YXMgYSBtaW5k
bWFwIG1vZGVsPyAgTm90IHRvbyBmYW1pbGlhciB3aXRoIHRoZSBtb2RlbCwg YnV0IEkgZG8g
dXNlIHRoZSBKYXZhIGJhc2VkIG1pbmRtYXAgYXBwbGljYXRpb24gRnJlZU1p bmQgc28gSSBh
bSBmYW1pbGlhciB3aXRoIHRoZSBwcm9ibGVtIGRvbWFpbi4gIChJIGFtIGFz c3VtaW5nIGl0
IGlzIHRoZSBzYW1lLikgSWYgeW91IHdhbmQgdGhlIGRhdGEgYXMgYSBtaW5k bWFwIG1vZGVs
IGEgdHJpdmlhbCBxdWVzdGlvbiBjb21lcyB0byBtaW5kIC0gZG8geW91IGhh dmUgYSBzdWJq
ZWN0IHlvdSB3b3VsZCBsaWtlIHRvIG1hcCBvdXQ/JiN4QTsmI3hBO0JUVy1X aHkgbWluZG1h
cCBhbmQgbm90IHRoZSBwZXJlbm5pYWxseSBmYXZvcml0ZSBMaWJyYXJ5IG9y IFB1cmNoYXNl
T3JkZXIgdmFyaWFudHM/ICIgaXRlbVBvc3REYXRlPSIyMDA3LTExLTA1Ii8+ CiAgICA8L2Nv
bW1lbnRzPgogICAgPGNvbW1lbnRzIGF1dGhvcj0iIy8vQG1hcC9AcmVzb3Vy Y2VzLjIiIHBv
c3REYXRlPSIyMDA3LTA3LTA3IiBzdWJqZWN0PSJFY29yZSAmYW1wOyBPREEi PgogICAgICA8
aXRlbXMgYXV0aG9yPSIjLy9AbWFwL0ByZXNvdXJjZXMuMiIgYm9keT0iSSBo YXZlIG5lZWQg
b2YgYW4gT0RBIGRhdGEgcHJvdmlkZXIgZm9yIEVjb3JlIG1vZGVscyAodWx0 aW1hdGVseSBm
b3IgQklSVCByZXBvcnRpbmcpLiBJJ3ZlIHNlZW4gdGhpcyByZXF1ZXN0ZWQg YmVmb3JlIGJ1
dCBsaXR0bGUgY29udmVyc2F0aW9uIGFyb3VuZCB0aGUgdG9waWMuIEknbSBj b250ZW1wbGF0
aW5nIGF0dGVtcHRpbmcgdG8gd3JpdGUgYSBwcm92aWRlciBidXQgSSdtIGZh aXJseSBuZXcg
dG8gRFRQIGFuZCBPREEgYW5kIHVuc3VyZSBvZiB0aGUgcGl0ZmFsbHMgSSBt YXkgZW5jb3Vu
dGVyLiBBbnlvbmUgd2FudCB0byBvZmZlciB3b3JkcyBvZiB3YXJuaW5nIG9y IGVuY291cmFn
ZW1lbnQ/SmVmZiIgaXRlbVBvc3REYXRlPSIyMDA3LTA3LTA3Ii8+CiAgICAg IDxpdGVtcyBh
dXRob3I9IiMvL0BtYXAvQHJlc291cmNlcy4zIiBib2R5PSJKZWZmLCBIb3Bl ZnVsbHkgeW91
J2xsIGV4Y3VzZSBteSBpZ25vcmFuY2UsIGJ1dCB3aGF0J3MgYW4gT0RBIGRh dGEgcHJvdmlk
ZXI/IiBpdGVtUG9zdERhdGU9IjIwMDctMDctMDkiLz4KICAgIDwvY29tbWVu dHM+CiAgPC9y
b290VG9waWNzPgogIDxyb290VG9waWNzIG5hbWU9Ik5ld3Nncm91cCIvPgog IDxyb290VG9w
aWNzIG5hbWU9Ik9EQSBFeHRlbnNpb25zIGFuZCBCaXJ0Ij4KICAgIDxjb21t ZW50cyBhdXRo
b3I9IiMvL0BtYXAvQHJlc291cmNlcy4xIiBwb3N0RGF0ZT0iMjAwNy0wMy0w MSIgc3ViamVj
dD0iQSBQcmltZXIgb24gT0RBIEV4dGVuc2lvbnMgYW5kIEJJUlQiPgogICAg ICA8aXRlbXMg
YXV0aG9yPSIjLy9AbWFwL0ByZXNvdXJjZXMuMCIgYm9keT0iIi8+CiAgICAg IDxpdGVtcyBh
dXRob3I9IiMvL0BtYXAvQHJlc291cmNlcy4xIiBib2R5PSJDcmVhdGluZyBD dXN0b20gRGF0
YSBTb3VyY2VzIGZvciBCSVJUIFJlcG9ydHMgVXNpbmcgT0RBIEV4dGVuc2lv biBQb2ludHMi
IGl0ZW1Qb3N0RGF0ZT0iMjAwMS0wMS0xMSIvPgogICAgICA8aXRlbXMgYm9k eT0iU2Vjb25k
IGl0ZW0iLz4KICAgIDwvY29tbWVudHM+CiAgICA8Y29tbWVudHMgYXV0aG9y PSIjLy9AbWFw
L0ByZXNvdXJjZXMuMSIgc3ViamVjdD0iT0RBIEV4dGVuc2lvbnMgYW5kIEJJ UlQgLSBQYXJ0
IDIiPgogICAgICA8aXRlbXMvPgogICAgICA8aXRlbXMgYXV0aG9yPSIjLy9A bWFwL0ByZXNv
dXJjZXMuMSIgYm9keT0iQ3VzdG9taXppbmcgdGhlIFVzZXLigJlzIEV4cGVy aWVuY2UiIGl0
ZW1Qb3N0RGF0ZT0iMjAwNy0wNC0wMSIvPgogICAgPC9jb21tZW50cz4KICAg IDxjb21tZW50
cyBhdXRob3I9IiMvL0BtYXAvQHJlc291cmNlcy4xIiBwb3N0RGF0ZT0iMjAw Ny0xMC0wMSIg
c3ViamVjdD0iT0RBIEV4dGVuc2lvbnMgYW5kIEJJUlQ6IFBhcnQgMyIvPgog IDwvcm9vdFRv
cGljcz4KICA8cm9vdFRvcGljcyBuYW1lPSJSZWZlcmVuY2VzIi8+CiAgPHJv b3RUb3BpY3Mg
bmFtZT0iT0RBIGZvciBFTUYiLz4KICA8cm9vdFRvcGljcyBuYW1lPSJUYXNr Ii8+CiAgPHJv
b3RUb3BpY3MgbmFtZT0iQ3JlYXRlIEN1c3RvbSBFTUYgRGF0YVNvdXJjZSIv PgogIDxyb290
VG9waWNzIG5hbWU9IkNyZWF0ZSBJbnRlZ3JhdGlvbiBUZXN0cyIvPgogIDxy b290VG9waWNz
IG5hbWU9IkNyZWF0ZSBUZXN0IERhdGEiLz4KICA8cm9vdFRvcGljcyBuYW1l PSJDcmVhdGUg
RGVzaWduZXIgVUkgUGx1Z2luIi8+CiAgPHJlbGF0aW9ucyBsYWJlbD0iZWNs aXBzZSBtYWdh
emluZXMiIHNvdXJjZT0iIy8vQG1hcC9Acm9vdFRvcGljcy4xIiB0YXJnZXQ9 IiMvL0BtYXAv
QHJvb3RUb3BpY3MuMCIgdHlwZT0iRVhURU5EUyIvPgogIDxyZWxhdGlvbnMg bGFiZWw9ImVj
bGlwc2UgbmV3c2dyb3VwcyIgc291cmNlPSIjLy9AbWFwL0Byb290VG9waWNz LjIiIHRhcmdl
dD0iIy8vQG1hcC9Acm9vdFRvcGljcy4zIiB0eXBlPSJFWFRFTkRTIi8+CiAg PHJlbGF0aW9u
cyBsYWJlbD0ic2VyaWVzT25PZGFBbmRCaXJ0IiBzb3VyY2U9IiMvL0BtYXAv QHJvb3RUb3Bp
Y3MuNCIgdGFyZ2V0PSIjLy9AbWFwL0Byb290VG9waWNzLjEiIHR5cGU9IklO Q0xVREVTIi8+
CiAgPHJlbGF0aW9ucyBsYWJlbD0icmVmZXJlbmNlcyIgc291cmNlPSIjLy9A bWFwL0Byb290
VG9waWNzLjYiIHRhcmdldD0iIy8vQG1hcC9Acm9vdFRvcGljcy41IiB0eXBl PSJJTkNMVURF
UyIvPgogIDxyZWxhdGlvbnMgbGFiZWw9InRhc2tzIiBzb3VyY2U9IiMvL0Bt YXAvQHJvb3RU
b3BpY3MuNiIgdGFyZ2V0PSIjLy9AbWFwL0Byb290VG9waWNzLjciIHR5cGU9 IklOQ0xVREVT
Ii8+CiAgPHJlbGF0aW9ucyBsYWJlbD0ibmV3c2dyb3VwcyIgc291cmNlPSIj Ly9AbWFwL0By
b290VG9waWNzLjUiIHRhcmdldD0iIy8vQG1hcC9Acm9vdFRvcGljcy4zIiB0 eXBlPSJJTkNM
VURFUyIvPgogIDxyZWxhdGlvbnMgbGFiZWw9InBlcmlvZGljYWxzIiBzb3Vy Y2U9IiMvL0Bt
YXAvQHJvb3RUb3BpY3MuNSIgdGFyZ2V0PSIjLy9AbWFwL0Byb290VG9waWNz LjAiIHR5cGU9
IklOQ0xVREVTIi8+CiAgPHJlbGF0aW9ucyBsYWJlbD0iZXh0ZW5kcyIgc291 cmNlPSIjLy9A
bWFwL0Byb290VG9waWNzLjgiIHRhcmdldD0iIy8vQG1hcC9Acm9vdFRvcGlj cy43IiB0eXBl
PSJFWFRFTkRTIi8+CiAgPHJlbGF0aW9ucyBsYWJlbD0iZXh0ZW5kcyIgc291 cmNlPSIjLy9A
bWFwL0Byb290VG9waWNzLjkiIHRhcmdldD0iIy8vQG1hcC9Acm9vdFRvcGlj cy43IiB0eXBl
PSJFWFRFTkRTIi8+CiAgPHJlbGF0aW9ucyBsYWJlbD0iaW5jbHVkZXMiIHNv dXJjZT0iIy8v
QG1hcC9Acm9vdFRvcGljcy45IiB0YXJnZXQ9IiMvL0BtYXAvQHJvb3RUb3Bp Y3MuMTAiIHR5
cGU9IklOQ0xVREVTIi8+CiAgPHJlbGF0aW9ucyBsYWJlbD0iZXh0ZW5kcyIg c291cmNlPSIj
Ly9AbWFwL0Byb290VG9waWNzLjExIiB0YXJnZXQ9IiMvL0BtYXAvQHJvb3RU b3BpY3MuNyIg
dHlwZT0iRVhURU5EUyIvPgogIDxyZXNvdXJjZXMgZW1haWw9Impjb25sb25A dmVydGljb24u
Y29tIiBuYW1lPSJKb2huIENvbmxvbiIvPgogIDxyZXNvdXJjZXMgY29tbWVu dHM9IiMvL0Bt
YXAvQHJvb3RUb3BpY3MuNC9AY29tbWVudHMuMCAjLy9AbWFwL0Byb290VG9w aWNzLjQvQGNv
bW1lbnRzLjEgIy8vQG1hcC9Acm9vdFRvcGljcy40L0Bjb21tZW50cy4yIiBu YW1lPSJTY290
dCBSb3NlbmJhdW0iLz4KICA8cmVzb3VyY2VzIGNvbW1lbnRzPSIjLy9AbWFw L0Byb290VG9w
aWNzLjIvQGNvbW1lbnRzLjAgIy8vQG1hcC9Acm9vdFRvcGljcy4yL0Bjb21t ZW50cy4xIiBl
bWFpbD0iamVmZi5yYW1zZGFsZUBnbWFpbC5jb20iIG5hbWU9IkplZmYgUmFt c2RhbGUiLz4K
ICA8cmVzb3VyY2VzIGVtYWlsPSJtZXJrc0BjYS5pYm0uY29tIiBuYW1lPSJF ZCBNZXJrcyIv
Pgo8L21pbmRtYXA6bWFwPg==
name="oda4Emf.mmd"
filename="oda4Emf.mmd"
<notation:Diagram xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:mindmap="http://www.example.org/mindmap" xmlns:notation="http://www.eclipse.org/gmf/runtime/1.0.1/notation" xmi:id="_NwOUUIvCEdy3F4CgSLvFkw" type="Mindmap" name="oda4Emf..mmd" measurementUnit="Pixel">
<children xmi:type="notation:Node" xmi:id="_SroIQIvLEdy3F4CgSLvFkw" type="2001">
<children xmi:type="notation:Node" xmi:id="_SrovUIvLEdy3F4CgSLvFkw" type="5002"/>
<children xmi:type="notation:Node" xmi:id="_SrovUYvLEdy3F4CgSLvFkw" type="7001">
<styles xmi:type="notation:DrawerStyle" xmi:id="_SrovUovLEdy3F4CgSLvFkw"/>
<styles xmi:type="notation:SortingStyle" xmi:id="_SrovU4vLEdy3F4CgSLvFkw"/>
<styles xmi:type="notation:FilteringStyle" xmi:id="_SrovVIvLEdy3F4CgSLvFkw"/>
</children>
<styles xmi:type="notation:ShapeStyle" xmi:id="_SroIQYvLEdy3F4CgSLvFkw" fontName="Sans"/>
<element xmi:type="mindmap:Topic" href="oda4Emf.mindmap#//@map/@rootTopics.0"/>
<layoutConstraint xmi:type="notation:Bounds" xmi:id="_SroIQovLEdy3F4CgSLvFkw" x="490" y="50"/>
</children>
<children xmi:type="notation:Node" xmi:id="_dnK94IvNEdy3F4CgSLvFkw" type="2001">
<children xmi:type="notation:Node" xmi:id="_dnLk8IvNEdy3F4CgSLvFkw" type="5002"/>
<children xmi:type="notation:Node" xmi:id="_dnLk8YvNEdy3F4CgSLvFkw" type="7001">
<styles xmi:type="notation:DrawerStyle" xmi:id="_dnLk8ovNEdy3F4CgSLvFkw"/>
<styles xmi:type="notation:SortingStyle" xmi:id="_dnLk84vNEdy3F4CgSLvFkw"/>
<styles xmi:type="notation:FilteringStyle" xmi:id="_dnLk9IvNEdy3F4CgSLvFkw"/>
</children>
<styles xmi:type="notation:ShapeStyle" xmi:id="_dnK94YvNEdy3F4CgSLvFkw" fontName="Sans"/>
<element xmi:type="mindmap:Topic" href="oda4Emf.mindmap#//@map/@rootTopics.1"/>
<layoutConstraint xmi:type="notation:Bounds" xmi:id="_dnK94ovNEdy3F4CgSLvFkw" x="370" y="160"/>
</children>
<children xmi:type="notation:Node" xmi:id="_wCJSIIvSEdy3F4CgSLvFkw" type="2002">
<children xmi:type="notation:Node" xmi:id="_wCJSI4vSEdy3F4CgSLvFkw" type="5003">
<layoutConstraint xmi:type="notation:Location" xmi:id="_wCJ5MIvSEdy3F4CgSLvFkw" x="60" y="10"/>
</children>
<styles xmi:type="notation:ShapeStyle" xmi:id="_wCJSIYvSEdy3F4CgSLvFkw" fontName="Sans"/>
<element xmi:type="mindmap:Resource" href="oda4Emf.mindmap#//@map/@resources.0"/>
<layoutConstraint xmi:type="notation:Bounds" xmi:id="_wCJSIovSEdy3F4CgSLvFkw" y="-60"/>
</children>
<children xmi:type="notation:Node" xmi:id="_UJQ_YIvVEdy3F4CgSLvFkw" type="2002">
<children xmi:type="notation:Node" xmi:id="_UJRmcIvVEdy3F4CgSLvFkw" type="5003">
<layoutConstraint xmi:type="notation:Location" xmi:id="_UJRmcYvVEdy3F4CgSLvFkw" x="60"/>
</children>
<styles xmi:type="notation:ShapeStyle" xmi:id="_UJQ_YYvVEdy3F4CgSLvFkw" fontName="Sans"/>
<element xmi:type="mindmap:Resource" href="oda4Emf.mindmap#//@map/@resources.1"/>
<layoutConstraint xmi:type="notation:Bounds" xmi:id="_UJQ_YovVEdy3F4CgSLvFkw" y="-260"/>
</children>
<children xmi:type="notation:Node" xmi:id="_aVxgwIvcEdy3F4CgSLvFkw" type="2001">
<children xmi:type="notation:Node" xmi:id="_aVyH0IvcEdy3F4CgSLvFkw" type="5002"/>
<children xmi:type="notation:Node" xmi:id="_aVyH0YvcEdy3F4CgSLvFkw" type="7001">
<children xmi:type="notation:Node" xmi:id="_pG7A4IvcEdy3F4CgSLvFkw" type="3001">
<children xmi:type="notation:Node" xmi:id="_pG7n8IvcEdy3F4CgSLvFkw" type="5001"/>
<children xmi:type="notation:Node" xmi:id="_pG7n8YvcEdy3F4CgSLvFkw" type="7002">
<children xmi:type="notation:Node" xmi:id="_DZmDcIvdEdy3F4CgSLvFkw" type="3002">
<element xmi:type="mindmap:ThreadItem" href="oda4Emf.mindmap#//@map/@rootTopics.2/@comments.0/@items.0 "/>
<layoutConstraint xmi:type="notation:Location" xmi:id="_DZmDcYvdEdy3F4CgSLvFkw"/>
</children>
<children xmi:type="notation:Node" xmi:id="_IwBVkIvdEdy3F4CgSLvFkw" type="3002">
<element xmi:type="mindmap:ThreadItem" href="oda4Emf.mindmap#//@map/@rootTopics.2/@comments.0/@items.1 "/>
<layoutConstraint xmi:type="notation:Location" xmi:id="_IwBVkYvdEdy3F4CgSLvFkw"/>
</children>
<children xmi:type="notation:Node" xmi:id="_j9EVsIvdEdy3F4CgSLvFkw" type="3002">
<element xmi:type="mindmap:ThreadItem" href="oda4Emf.mindmap#//@map/@rootTopics.2/@comments.0/@items.2 "/>
<layoutConstraint xmi:type="notation:Location" xmi:id="_j9EVsYvdEdy3F4CgSLvFkw"/>
</children>
<children xmi:type="notation:Node" xmi:id="_ZKNaoIveEdy3F4CgSLvFkw" type="3002">
<element xmi:type="mindmap:ThreadItem" href="oda4Emf.mindmap#//@map/@rootTopics.2/@comments.0/@items.3 "/>
<layoutConstraint xmi:type="notation:Location" xmi:id="_ZKNaoYveEdy3F4CgSLvFkw"/>
</children>
<children xmi:type="notation:Node" xmi:id="_fXFzoIveEdy3F4CgSLvFkw" type="3002">
<element xmi:type="mindmap:ThreadItem" href="oda4Emf.mindmap#//@map/@rootTopics.2/@comments.0/@items.4 "/>
<layoutConstraint xmi:type="notation:Location" xmi:id="_fXFzoYveEdy3F4CgSLvFkw"/>
</children>
<children xmi:type="notation:Node" xmi:id="_06-2EIviEdy3F4CgSLvFkw" type="3002">
<element xmi:type="mindmap:ThreadItem" href="oda4Emf.mindmap#//@map/@rootTopics.2/@comments.0/@items.5 "/>
<layoutConstraint xmi:type="notation:Location" xmi:id="_06-2EYviEdy3F4CgSLvFkw"/>
</children>
<children xmi:type="notation:Node" xmi:id="_IMKL0IvjEdy3F4CgSLvFkw" type="3002">
<element xmi:type="mindmap:ThreadItem" href="oda4Emf.mindmap#//@map/@rootTopics.2/@comments.0/@items.6 "/>
<layoutConstraint xmi:type="notation:Location" xmi:id="_IMKL0YvjEdy3F4CgSLvFkw"/>
</children>
<children xmi:type="notation:Node" xmi:id="_IatlMIvjEdy3F4CgSLvFkw" type="3002">
<element xmi:type="mindmap:ThreadItem" href="oda4Emf.mindmap#//@map/@rootTopics.2/@comments.0/@items.7 "/>
<layoutConstraint xmi:type="notation:Location" xmi:id="_IatlMYvjEdy3F4CgSLvFkw"/>
</children>
<children xmi:type="notation:Node" xmi:id="_I3JpkIvjEdy3F4CgSLvFkw" type="3002">
<element xmi:type="mindmap:ThreadItem" href="oda4Emf.mindmap#//@map/@rootTopics.2/@comments.0/@items.8 "/>
<layoutConstraint xmi:type="notation:Location" xmi:id="_I3JpkYvjEdy3F4CgSLvFkw"/>
</children>
<children xmi:type="notation:Node" xmi:id="_Jcw4EIvjEdy3F4CgSLvFkw" type="3002">
<element xmi:type="mindmap:ThreadItem" href="oda4Emf.mindmap#//@map/@rootTopics.2/@comments.0/@items.9 "/>
<layoutConstraint xmi:type="notation:Location" xmi:id="_Jcw4EYvjEdy3F4CgSLvFkw"/>
</children>
<children xmi:type="notation:Node" xmi:id="_WoPa4IvjEdy3F4CgSLvFkw" type="3002">
<element xmi:type="mindmap:ThreadItem" href="oda4Emf.mindmap#//@map/@rootTopics.2/@comments.0/@items.10 "/>
<layoutConstraint xmi:type="notation:Location" xmi:id="_WoPa4YvjEdy3F4CgSLvFkw"/>
</children>
<styles xmi:type="notation:SortingStyle" xmi:id="_pG7n8ovcEdy3F4CgSLvFkw"/>
<styles xmi:type="notation:FilteringStyle" xmi:id="_pG7n84vcEdy3F4CgSLvFkw"/>
</children>
<styles xmi:type="notation:ShapeStyle" xmi:id="_pG7A4YvcEdy3F4CgSLvFkw" fontName="Sans"/>
<element xmi:type="mindmap:Thread" href="oda4Emf.mindmap#//@map/@rootTopics.2/@comments.0"/>
<layoutConstraint xmi:type="notation:Bounds" xmi:id="_pG7A4ovcEdy3F4CgSLvFkw" x="15" y="83"/>
</children>
<children xmi:type="notation:Node" xmi:id="_L5SgsIvqEdy3F4CgSLvFkw" type="3001">
<children xmi:type="notation:Node" xmi:id="_L5Sgs4vqEdy3F4CgSLvFkw" type="5001"/>
<children xmi:type="notation:Node" xmi:id="_L5THwIvqEdy3F4CgSLvFkw" type="7002">
<children xmi:type="notation:Node" xmi:id="_MLo_gIvrEdy3F4CgSLvFkw" type="3002">
<element xmi:type="mindmap:ThreadItem" href="oda4Emf.mindmap#//@map/@rootTopics.2/@comments.1/@items.0 "/>
<layoutConstraint xmi:type="notation:Location" xmi:id="_MLo_gYvrEdy3F4CgSLvFkw"/>
</children>
<children xmi:type="notation:Node" xmi:id="_ZXhVgIvsEdy3F4CgSLvFkw" type="3002">
<element xmi:type="mindmap:ThreadItem" href="oda4Emf.mindmap#//@map/@rootTopics.2/@comments.1/@items.1 "/>
<layoutConstraint xmi:type="notation:Location" xmi:id="_ZXhVgYvsEdy3F4CgSLvFkw"/>
</children>
<styles xmi:type="notation:SortingStyle" xmi:id="_L5THwYvqEdy3F4CgSLvFkw"/>
<styles xmi:type="notation:FilteringStyle" xmi:id="_L5THwovqEdy3F4CgSLvFkw"/>
</children>
<styles xmi:type="notation:ShapeStyle" xmi:id="_L5SgsYvqEdy3F4CgSLvFkw" fontName="Sans"/>
<element xmi:type="mindmap:Thread" href="oda4Emf.mindmap#//@map/@rootTopics.2/@comments.1"/>
<layoutConstraint xmi:type="notation:Bounds" xmi:id="_L5SgsovqEdy3F4CgSLvFkw" x="15" y="3"/>
</children>
<styles xmi:type="notation:DrawerStyle" xmi:id="_aVyH0ovcEdy3F4CgSLvFkw"/>
<styles xmi:type="notation:SortingStyle" xmi:id="_aVyH04vcEdy3F4CgSLvFkw"/>
<styles xmi:type="notation:FilteringStyle" xmi:id="_aVyH1IvcEdy3F4CgSLvFkw"/>
</children>
<styles xmi:type="notation:ShapeStyle" xmi:id="_aVxgwYvcEdy3F4CgSLvFkw" fontName="Sans"/>
<element xmi:type="mindmap:Topic" href="oda4Emf.mindmap#//@map/@rootTopics.2"/>
<layoutConstraint xmi:type="notation:Bounds" xmi:id="_aVxgwovcEdy3F4CgSLvFkw" x="620" y="100"/>
</children>
<children xmi:type="notation:Node" xmi:id="_tQ9_cIvcEdy3F4CgSLvFkw" type="2002">
<children xmi:type="notation:Node" xmi:id="_tQ_0oIvcEdy3F4CgSLvFkw" type="5003">
<layoutConstraint xmi:type="notation:Location" xmi:id="_tQ_0oYvcEdy3F4CgSLvFkw" x="60"/>
</children>
<styles xmi:type="notation:ShapeStyle" xmi:id="_tQ9_cYvcEdy3F4CgSLvFkw" fontName="Sans"/>
<element xmi:type="mindmap:Resource" href="oda4Emf.mindmap#//@map/@resources.2"/>
<layoutConstraint xmi:type="notation:Bounds" xmi:id="_tQ9_covcEdy3F4CgSLvFkw" y="-200"/>
</children>
<children xmi:type="notation:Node" xmi:id="_GGLJAIveEdy3F4CgSLvFkw" type="2002">
<children xmi:type="notation:Node" xmi:id="_GGLwEIveEdy3F4CgSLvFkw" type="5003">
<layoutConstraint xmi:type="notation:Location" xmi:id="_GGLwEYveEdy3F4CgSLvFkw" x="60"/>
</children>
<styles xmi:type="notation:ShapeStyle" xmi:id="_GGLJAYveEdy3F4CgSLvFkw" fontName="Sans"/>
<element xmi:type="mindmap:Resource" href="oda4Emf.mindmap#//@map/@resources.3"/>
<layoutConstraint xmi:type="notation:Bounds" xmi:id="_GGLJAoveEdy3F4CgSLvFkw" y="-140"/>
</children>
<children xmi:type="notation:Node" xmi:id="_Rj-6AIvnEdy3F4CgSLvFkw" type="2001">
<children xmi:type="notation:Node" xmi:id="_Rj_hEIvnEdy3F4CgSLvFkw" type="5002"/>
<children xmi:type="notation:Node" xmi:id="_Rj_hEYvnEdy3F4CgSLvFkw" type="7001">
<styles xmi:type="notation:DrawerStyle" xmi:id="_RkAIIIvnEdy3F4CgSLvFkw"/>
<styles xmi:type="notation:SortingStyle" xmi:id="_RkAIIYvnEdy3F4CgSLvFkw"/>
<styles xmi:type="notation:FilteringStyle" xmi:id="_RkAIIovnEdy3F4CgSLvFkw"/>
</children>
<styles xmi:type="notation:ShapeStyle" xmi:id="_Rj-6AYvnEdy3F4CgSLvFkw" fontName="Sans"/>
<element xmi:type="mindmap:Topic" href="oda4Emf.mindmap#//@map/@rootTopics.3"/>
<layoutConstraint xmi:type="notation:Bounds" xmi:id="_Rj-6AovnEdy3F4CgSLvFkw" x="820" y="20"/>
</children>
<children xmi:type="notation:Node" xmi:id="_1BbDAIvnEdy3F4CgSLvFkw" type="2001">
<children xmi:type="notation:Node" xmi:id="_1BbqEIvnEdy3F4CgSLvFkw" type="5002"/>
<children xmi:type="notation:Node" xmi:id="_1BcRIIvnEdy3F4CgSLvFkw" type="7001">
<children xmi:type="notation:Node" xmi:id="_w81G0IvUEdy3F4CgSLvFkw" type="3001">
<children xmi:type="notation:Node" xmi:id="_w81t4ovUEdy3F4CgSLvFkw" type="5001"/>
<children xmi:type="notation:Node" xmi:id="_w82U8IvUEdy3F4CgSLvFkw" type="7002">
<children xmi:type="notation:Node" xmi:id="_5e8R0IvUEdy3F4CgSLvFkw" type="3002">
<element xmi:type="mindmap:ThreadItem" href="oda4Emf.mindmap#//@map/@rootTopics.4/@comments.0/@items.0 "/>
<layoutConstraint xmi:type="notation:Location" xmi:id="_5e8R0YvUEdy3F4CgSLvFkw"/>
</children>
<children xmi:type="notation:Node" xmi:id="_XcJdsIvbEdy3F4CgSLvFkw" type="3002">
<element xmi:type="mindmap:ThreadItem" href="oda4Emf.mindmap#//@map/@rootTopics.4/@comments.0/@items.1 "/>
<layoutConstraint xmi:type="notation:Location" xmi:id="_XcJdsYvbEdy3F4CgSLvFkw"/>
</children>
<children xmi:type="notation:Node" xmi:id="_9ko3sIvbEdy3F4CgSLvFkw" type="3002">
<element xmi:type="mindmap:ThreadItem" href="oda4Emf.mindmap#//@map/@rootTopics.4/@comments.0/@items.2 "/>
<layoutConstraint xmi:type="notation:Location" xmi:id="_9ko3sYvbEdy3F4CgSLvFkw"/>
</children>
<styles xmi:type="notation:SortingStyle" xmi:id="_w82U8YvUEdy3F4CgSLvFkw"/>
<styles xmi:type="notation:FilteringStyle" xmi:id="_w82U8ovUEdy3F4CgSLvFkw"/>
</children>
<styles xmi:type="notation:ShapeStyle" xmi:id="_w81t4IvUEdy3F4CgSLvFkw" fontName="Sans"/>
<element xmi:type="mindmap:Thread" href="oda4Emf.mindmap#//@map/@rootTopics.4/@comments.0"/>
<layoutConstraint xmi:type="notation:Bounds" xmi:id="_w81t4YvUEdy3F4CgSLvFkw" x="-11" y="-14" width="147"/>
</children>
<children xmi:type="notation:Node" xmi:id="_DZYnEIvoEdy3F4CgSLvFkw" type="3001">
<children xmi:type="notation:Node" xmi:id="_DZYnE4voEdy3F4CgSLvFkw" type="5001"/>
<children xmi:type="notation:Node" xmi:id="_DZZOIIvoEdy3F4CgSLvFkw" type="7002">
<children xmi:type="notation:Node" xmi:id="_hnY2wIvoEdy3F4CgSLvFkw" type="3002">
<element xmi:type="mindmap:ThreadItem" href="oda4Emf.mindmap#//@map/@rootTopics.4/@comments.1/@items.0 "/>
<layoutConstraint xmi:type="notation:Location" xmi:id="_hnY2wYvoEdy3F4CgSLvFkw"/>
</children>
<children xmi:type="notation:Node" xmi:id="_iOAx4IvoEdy3F4CgSLvFkw" type="3002">
<element xmi:type="mindmap:ThreadItem" href="oda4Emf.mindmap#//@map/@rootTopics.4/@comments.1/@items.1 "/>
<layoutConstraint xmi:type="notation:Location" xmi:id="_iOAx4YvoEdy3F4CgSLvFkw"/>
</children>
<styles xmi:type="notation:SortingStyle" xmi:id="_DZZOIYvoEdy3F4CgSLvFkw"/>
<styles xmi:type="notation:FilteringStyle" xmi:id="_DZZOIovoEdy3F4CgSLvFkw"/>
</children>
<styles xmi:type="notation:ShapeStyle" xmi:id="_DZYnEYvoEdy3F4CgSLvFkw" fontName="Sans"/>
<element xmi:type="mindmap:Thread" href="oda4Emf.mindmap#//@map/@rootTopics.4/@comments.1"/>
<layoutConstraint xmi:type="notation:Bounds" xmi:id="_DZYnEovoEdy3F4CgSLvFkw" x="-16" y="63"/>
</children>
<children xmi:type="notation:Node" xmi:id="_zyYLEIvpEdy3F4CgSLvFkw" type="3001">
<children xmi:type="notation:Node" xmi:id="_zyYLE4vpEdy3F4CgSLvFkw" type="5001"/>
<children xmi:type="notation:Node" xmi:id="_zyYyIIvpEdy3F4CgSLvFkw" type="7002">
<styles xmi:type="notation:SortingStyle" xmi:id="_zyYyIYvpEdy3F4CgSLvFkw"/>
<styles xmi:type="notation:FilteringStyle" xmi:id="_zyYyIovpEdy3F4CgSLvFkw"/>
</children>
<styles xmi:type="notation:ShapeStyle" xmi:id="_zyYLEYvpEdy3F4CgSLvFkw" fontName="Sans"/>
<element xmi:type="mindmap:Thread" href="oda4Emf.mindmap#//@map/@rootTopics.4/@comments.2"/>
<layoutConstraint xmi:type="notation:Bounds" xmi:id="_zyYLEovpEdy3F4CgSLvFkw" x="-11" y="113"/>
</children>
<styles xmi:type="notation:DrawerStyle" xmi:id="_1BcRIYvnEdy3F4CgSLvFkw"/>
<styles xmi:type="notation:SortingStyle" xmi:id="_1BcRIovnEdy3F4CgSLvFkw"/>
<styles xmi:type="notation:FilteringStyle" xmi:id="_1BcRI4vnEdy3F4CgSLvFkw"/>
</children>
<styles xmi:type="notation:ShapeStyle" xmi:id="_1BbDAYvnEdy3F4CgSLvFkw" fontName="Sans"/>
<element xmi:type="mindmap:Topic" href="oda4Emf.mindmap#//@map/@rootTopics.4"/>
<layoutConstraint xmi:type="notation:Bounds" xmi:id="_1BbDAovnEdy3F4CgSLvFkw" x="100" y="290" width="271" height="211"/>
</children>
<children xmi:type="notation:Node" xmi:id="_df05kIvqEdy3F4CgSLvFkw" type="2001">
<children xmi:type="notation:Node" xmi:id="_df2HsIvqEdy3F4CgSLvFkw" type="5002"/>
<children xmi:type="notation:Node" xmi:id="_df2uwIvqEdy3F4CgSLvFkw" type="7001">
<styles xmi:type="notation:DrawerStyle" xmi:id="_df2uwYvqEdy3F4CgSLvFkw"/>
<styles xmi:type="notation:SortingStyle" xmi:id="_df2uwovqEdy3F4CgSLvFkw"/>
<styles xmi:type="notation:FilteringStyle" xmi:id="_df2uw4vqEdy3F4CgSLvFkw"/>
</children>
<styles xmi:type="notation:ShapeStyle" xmi:id="_df05kYvqEdy3F4CgSLvFkw" fontName="Sans"/>
<element xmi:type="mindmap:Topic" href="oda4Emf.mindmap#//@map/@rootTopics.5"/>
<layoutConstraint xmi:type="notation:Bounds" xmi:id="_df1goIvqEdy3F4CgSLvFkw" x="630" y="-20"/>
</children>
<children xmi:type="notation:Node" xmi:id="_K43osIvuEdy3F4CgSLvFkw" type="2001">
<children xmi:type="notation:Node" xmi:id="_K44PwIvuEdy3F4CgSLvFkw" type="5002"/>
<children xmi:type="notation:Node" xmi:id="_K44PwYvuEdy3F4CgSLvFkw" type="7001">
<styles xmi:type="notation:DrawerStyle" xmi:id="_K44PwovuEdy3F4CgSLvFkw"/>
<styles xmi:type="notation:SortingStyle" xmi:id="_K44Pw4vuEdy3F4CgSLvFkw"/>
<styles xmi:type="notation:FilteringStyle" xmi:id="_K44PxIvuEdy3F4CgSLvFkw"/>
</children>
<styles xmi:type="notation:ShapeStyle" xmi:id="_K43osYvuEdy3F4CgSLvFkw" fontName="Sans"/>
<element xmi:type="mindmap:Topic" href="oda4Emf.mindmap#//@map/@rootTopics.6"/>
<layoutConstraint xmi:type="notation:Bounds" xmi:id="_K43osovuEdy3F4CgSLvFkw" x="620" y="-240"/>
</children>
<children xmi:type="notation:Node" xmi:id="_Z7-bgIvuEdy3F4CgSLvFkw" type="2001">
<children xmi:type="notation:Node" xmi:id="_Z7_CkIvuEdy3F4CgSLvFkw" type="5002"/>
<children xmi:type="notation:Node" xmi:id="_Z7_CkYvuEdy3F4CgSLvFkw" type="7001">
<styles xmi:type="notation:DrawerStyle" xmi:id="_Z7_CkovuEdy3F4CgSLvFkw"/>
<styles xmi:type="notation:SortingStyle" xmi:id="_Z7_Ck4vuEdy3F4CgSLvFkw"/>
<styles xmi:type="notation:FilteringStyle" xmi:id="_Z7_ClIvuEdy3F4CgSLvFkw"/>
</children>
<styles xmi:type="notation:ShapeStyle" xmi:id="_Z7-bgYvuEdy3F4CgSLvFkw" fontName="Sans"/>
<element xmi:type="mindmap:Topic" href="oda4Emf.mindmap#//@map/@rootTopics.7"/>
<layoutConstraint xmi:type="notation:Bounds" xmi:id="_Z7-bgovuEdy3F4CgSLvFkw" x="921" y="-200"/>
</children>
<children xmi:type="notation:Node" xmi:id="_uAh5gIvvEdy3F4CgSLvFkw" type="2001">
<children xmi:type="notation:Node" xmi:id="_uAigkIvvEdy3F4CgSLvFkw" type="5002"/>
<children xmi:type="notation:Node" xmi:id="_uAigkYvvEdy3F4CgSLvFkw" type="7001">
<styles xmi:type="notation:DrawerStyle" xmi:id="_uAigkovvEdy3F4CgSLvFkw"/>
<styles xmi:type="notation:SortingStyle" xmi:id="_uAjHoIvvEdy3F4CgSLvFkw"/>
<styles xmi:type="notation:FilteringStyle" xmi:id="_uAjHoYvvEdy3F4CgSLvFkw"/>
</children>
<styles xmi:type="notation:ShapeStyle" xmi:id="_uAh5gYvvEdy3F4CgSLvFkw" fontName="Sans"/>
<element xmi:type="mindmap:Topic" href="oda4Emf.mindmap#//@map/@rootTopics.8"/>
<layoutConstraint xmi:type="notation:Bounds" xmi:id="_uAh5govvEdy3F4CgSLvFkw" x="1170" y="-240"/>
</children>
<children xmi:type="notation:Node" xmi:id="__1do0IvxEdy3F4CgSLvFkw" type="2001">
<children xmi:type="notation:Node" xmi:id="__1eP4IvxEdy3F4CgSLvFkw" type="5002"/>
<children xmi:type="notation:Node" xmi:id="__1eP4YvxEdy3F4CgSLvFkw" type="7001">
<styles xmi:type="notation:DrawerStyle" xmi:id="__1eP4ovxEdy3F4CgSLvFkw"/>
<styles xmi:type="notation:SortingStyle" xmi:id="__1eP44vxEdy3F4CgSLvFkw"/>
<styles xmi:type="notation:FilteringStyle" xmi:id="__1eP5IvxEdy3F4CgSLvFkw"/>
</children>
<styles xmi:type="notation:ShapeStyle" xmi:id="__1do0YvxEdy3F4CgSLvFkw" fontName="Sans"/>
<element xmi:type="mindmap:Topic" href="oda4Emf.mindmap#//@map/@rootTopics.9"/>
<layoutConstraint xmi:type="notation:Bounds" xmi:id="__1do0ovxEdy3F4CgSLvFkw" x="1120" y="-70"/>
</children>
<children xmi:type="notation:Node" xmi:id="_z88tQIvyEdy3F4CgSLvFkw" type="2001">
<children xmi:type="notation:Node" xmi:id="_z89UUIvyEdy3F4CgSLvFkw" type="5002"/>
<children xmi:type="notation:Node" xmi:id="_z89UUYvyEdy3F4CgSLvFkw" type="7001">
<styles xmi:type="notation:DrawerStyle" xmi:id="_z89UUovyEdy3F4CgSLvFkw"/>
<styles xmi:type="notation:SortingStyle" xmi:id="_z89UU4vyEdy3F4CgSLvFkw"/>
<styles xmi:type="notation:FilteringStyle" xmi:id="_z89UVIvyEdy3F4CgSLvFkw"/>
</children>
<styles xmi:type="notation:ShapeStyle" xmi:id="_z88tQYvyEdy3F4CgSLvFkw" fontName="Sans"/>
<element xmi:type="mindmap:Topic" href="oda4Emf.mindmap#//@map/@rootTopics.10"/>
<layoutConstraint xmi:type="notation:Bounds" xmi:id="_z88tQovyEdy3F4CgSLvFkw" x="1300" y="10"/>
</children>
<children xmi:type="notation:Node" xmi:id="_IYeWQIvzEdy3F4CgSLvFkw" type="2001">
<children xmi:type="notation:Node" xmi:id="_IYe9UIvzEdy3F4CgSLvFkw" type="5002"/>
<children xmi:type="notation:Node" xmi:id="_IYe9UYvzEdy3F4CgSLvFkw" type="7001">
<styles xmi:type="notation:DrawerStyle" xmi:id="_IYe9UovzEdy3F4CgSLvFkw"/>
<styles xmi:type="notation:SortingStyle" xmi:id="_IYe9U4vzEdy3F4CgSLvFkw"/>
<styles xmi:type="notation:FilteringStyle" xmi:id="_IYe9VIvzEdy3F4CgSLvFkw"/>
</children>
<styles xmi:type="notation:ShapeStyle" xmi:id="_IYeWQYvzEdy3F4CgSLvFkw" fontName="Sans"/>
<element xmi:type="mindmap:Topic" href="oda4Emf.mindmap#//@map/@rootTopics.11"/>
<layoutConstraint xmi:type="notation:Bounds" xmi:id="_IYeWQovzEdy3F4CgSLvFkw" x="1179" y="-164"/>
</children>
<styles xmi:type="notation:DiagramStyle" xmi:id="_NwOUUYvCEdy3F4CgSLvFkw"/>
<element xmi:type="mindmap:Map" href="oda4Emf.mindmap#//@map"/>
<edges xmi:type="notation:Edge" xmi:id="_wCRN8IvSEdy3F4CgSLvFkw" type="4002" source="_dnK94IvNEdy3F4CgSLvFkw" target="_SroIQIvLEdy3F4CgSLvFkw">
<children xmi:type="notation:Node" xmi:id="_wCR1AIvSEdy3F4CgSLvFkw" type="6001">
<layoutConstraint xmi:type="notation:Location" xmi:id="_wCR1AYvSEdy3F4CgSLvFkw" x="-43" y="-36"/>
</children>
<styles xmi:type="notation:ConnectorStyle" xmi:id="_wCRN8YvSEdy3F4CgSLvFkw"/>
<styles xmi:type="notation:FontStyle" xmi:id="_wCRN8ovSEdy3F4CgSLvFkw" fontName="Sans"/>
<element xmi:type="mindmap:Relationship" href="oda4Emf.mindmap#//@map/@relations.0"/>
<bendpoints xmi:type="notation:RelativeBendpoints" xmi:id="_wCRN84vSEdy3F4CgSLvFkw" points="[19, -20, -84, 90]$[84, -90, -19, 20]"/>
</edges>
<edges xmi:type="notation:Edge" xmi:id="_eKo4gIvnEdy3F4CgSLvFkw" type="4002" source="_aVxgwIvcEdy3F4CgSLvFkw" target="_Rj-6AIvnEdy3F4CgSLvFkw">
<children xmi:type="notation:Node" xmi:id="_eKpfkYvnEdy3F4CgSLvFkw" type="6001">
<layoutConstraint xmi:type="notation:Location" xmi:id="_eKpfkovnEdy3F4CgSLvFkw" x="2" y="22"/>
</children>
<styles xmi:type="notation:ConnectorStyle" xmi:id="_eKo4gYvnEdy3F4CgSLvFkw"/>
<styles xmi:type="notation:FontStyle" xmi:id="_eKo4govnEdy3F4CgSLvFkw" fontName="Sans"/>
<element xmi:type="mindmap:Relationship" href="oda4Emf.mindmap#//@map/@relations.1"/>
<bendpoints xmi:type="notation:RelativeBendpoints" xmi:id="_eKpfkIvnEdy3F4CgSLvFkw" points="[-29, -11, 336, 25]$[-365, -36, 0, 0]"/>
<sourceAnchor xmi:type="notation:IdentityAnchor" xmi:id="_eKsi4IvnEdy3F4CgSLvFkw" id="(0.3831872,0.055837564)"/>
<targetAnchor xmi:type="notation:IdentityAnchor" xmi:id="_eKtJ8IvnEdy3F4CgSLvFkw" id="(1.0,1.0)"/>
</edges>
<edges xmi:type="notation:Edge" xmi:id="_dgAfwIvqEdy3F4CgSLvFkw" type="4003" source="_1BbDAIvnEdy3F4CgSLvFkw" target="_dnK94IvNEdy3F4CgSLvFkw">
<children xmi:type="notation:Node" xmi:id="_dgBG0IvqEdy3F4CgSLvFkw" type="6002">
<layoutConstraint xmi:type="notation:Location" xmi:id="_dgBG0YvqEdy3F4CgSLvFkw" x="6" y="25"/>
</children>
<styles xmi:type="notation:ConnectorStyle" xmi:id="_dgAfwYvqEdy3F4CgSLvFkw"/>
<styles xmi:type="notation:FontStyle" xmi:id="_dgAfwovqEdy3F4CgSLvFkw" fontName="Sans"/>
<element xmi:type="mindmap:Relationship" href="oda4Emf.mindmap#//@map/@relations.2"/>
<bendpoints xmi:type="notation:RelativeBendpoints" xmi:id="_dgAfw4vqEdy3F4CgSLvFkw" points="[94, -105, -99, 110]$[175, -195, -18, 20]"/>
</edges>
<edges xmi:type="notation:Edge" xmi:id="_uA2CkIvvEdy3F4CgSLvFkw" type="4003" source="_K43osIvuEdy3F4CgSLvFkw" target="_df05kIvqEdy3F4CgSLvFkw">
<children xmi:type="notation:Node" xmi:id="_uA2ClIvvEdy3F4CgSLvFkw" type="6002">
<layoutConstraint xmi:type="notation:Location" xmi:id="_uA2ClYvvEdy3F4CgSLvFkw" y="40"/>
</children>
<styles xmi:type="notation:ConnectorStyle" xmi:id="_uA2CkYvvEdy3F4CgSLvFkw"/>
<styles xmi:type="notation:FontStyle" xmi:id="_uA2CkovvEdy3F4CgSLvFkw" fontName="Sans"/>
<element xmi:type="mindmap:Relationship" href="oda4Emf.mindmap#//@map/@relations.3"/>
<bendpoints xmi:type="notation:RelativeBendpoints" xmi:id="_uA2Ck4vvEdy3F4CgSLvFkw" points="[6, 20, 0, -200]$[0, 200, -6, -20]"/>
</edges>
<edges xmi:type="notation:Edge" xmi:id="_uA33wIvvEdy3F4CgSLvFkw" type="4003" source="_K43osIvuEdy3F4CgSLvFkw" target="_Z7-bgIvuEdy3F4CgSLvFkw">
<children xmi:type="notation:Node" xmi:id="_uA4e0IvvEdy3F4CgSLvFkw" type="6002">
<layoutConstraint xmi:type="notation:Location" xmi:id="_uA4e0YvvEdy3F4CgSLvFkw" x="-11" y="28"/>
</children>
<styles xmi:type="notation:ConnectorStyle" xmi:id="_uA33wYvvEdy3F4CgSLvFkw"/>
<styles xmi:type="notation:FontStyle" xmi:id="_uA33wovvEdy3F4CgSLvFkw" fontName="Sans"/>
<element xmi:type="mindmap:Relationship" href="oda4Emf.mindmap#//@map/@relations.4"/>
<bendpoints xmi:type="notation:RelativeBendpoints" xmi:id="_uA33w4vvEdy3F4CgSLvFkw" points="[45, 6, -236, -34]$[256, 36, -25, -4]"/>
</edges>
<edges xmi:type="notation:Edge" xmi:id="_uA5s8IvvEdy3F4CgSLvFkw" type="4003" source="_df05kIvqEdy3F4CgSLvFkw" target="_Rj-6AIvnEdy3F4CgSLvFkw">
<children xmi:type="notation:Node" xmi:id="_uA6UAIvvEdy3F4CgSLvFkw" type="6002">
<layoutConstraint xmi:type="notation:Location" xmi:id="_uA6UAYvvEdy3F4CgSLvFkw" x="21" y="-16"/>
</children>
<styles xmi:type="notation:ConnectorStyle" xmi:id="_uA5s8YvvEdy3F4CgSLvFkw"/>
<styles xmi:type="notation:FontStyle" xmi:id="_uA5s8ovvEdy3F4CgSLvFkw" fontName="Sans"/>
<element xmi:type="mindmap:Relationship" href="oda4Emf.mindmap#//@map/@relations.5"/>
<bendpoints xmi:type="notation:RelativeBendpoints" xmi:id="_uA5s84vvEdy3F4CgSLvFkw" points="[41, 9, -149, -31]$[149, 31, -41, -9]"/>
</edges>
<edges xmi:type="notation:Edge" xmi:id="_uA7iIIvvEdy3F4CgSLvFkw" type="4003" source="_df05kIvqEdy3F4CgSLvFkw" target="_SroIQIvLEdy3F4CgSLvFkw">
<children xmi:type="notation:Node" xmi:id="_uA8JM4vvEdy3F4CgSLvFkw" type="6002">
<layoutConstraint xmi:type="notation:Location" xmi:id="_uA8JNIvvEdy3F4CgSLvFkw" x="10" y="23"/>
</children>
<styles xmi:type="notation:ConnectorStyle" xmi:id="_uA8JMIvvEdy3F4CgSLvFkw"/>
<styles xmi:type="notation:FontStyle" xmi:id="_uA8JMYvvEdy3F4CgSLvFkw" fontName="Sans"/>
<element xmi:type="mindmap:Relationship" href="oda4Emf.mindmap#//@map/@relations.6"/>
<bendpoints xmi:type="notation:RelativeBendpoints" xmi:id="_uA8JMovvEdy3F4CgSLvFkw" points="[-41, 20, 103, -50]$[-107, 52, 37, -18]"/>
</edges>
<edges xmi:type="notation:Edge" xmi:id="__1p2EIvxEdy3F4CgSLvFkw" type="4002" source="__1do0IvxEdy3F4CgSLvFkw" target="_Z7-bgIvuEdy3F4CgSLvFkw">
<children xmi:type="notation:Node" xmi:id="__1qdIIvxEdy3F4CgSLvFkw" type="6001">
<layoutConstraint xmi:type="notation:Location" xmi:id="__1qdIYvxEdy3F4CgSLvFkw" y="40"/>
</children>
<styles xmi:type="notation:ConnectorStyle" xmi:id="__1p2EYvxEdy3F4CgSLvFkw"/>
<styles xmi:type="notation:FontStyle" xmi:id="__1p2EovxEdy3F4CgSLvFkw" fontName="Sans"/>
<element xmi:type="mindmap:Relationship" href="oda4Emf.mindmap#//@map/@relations.8"/>
<bendpoints xmi:type="notation:RelativeBendpoints" xmi:id="__1p2E4vxEdy3F4CgSLvFkw" points="[0, 0, -946, 180]$[921, -175, -25, 5]"/>
</edges>
<edges xmi:type="notation:Edge" xmi:id="_vjARgIvyEdy3F4CgSLvFkw" type="4002" source="_uAh5gIvvEdy3F4CgSLvFkw" target="_Z7-bgIvuEdy3F4CgSLvFkw">
<children xmi:type="notation:Node" xmi:id="_vjARhIvyEdy3F4CgSLvFkw" type="6001">
<layoutConstraint xmi:type="notation:Location" xmi:id="_vjARhYvyEdy3F4CgSLvFkw" y="40"/>
</children>
<styles xmi:type="notation:ConnectorStyle" xmi:id="_vjARgYvyEdy3F4CgSLvFkw"/>
<styles xmi:type="notation:FontStyle" xmi:id="_vjARgovyEdy3F4CgSLvFkw" fontName="Sans"/>
<element xmi:type="mindmap:Relationship" href="oda4Emf.mindmap#//@map/@relations.7"/>
<bendpoints xmi:type="notation:RelativeBendpoints" xmi:id="_vjARg4vyEdy3F4CgSLvFkw" points="[-98, 3, 227, -7]$[-302, 9, 23, -1]"/>
</edges>
<edges xmi:type="notation:Edge" xmi:id="_IYp8cIvzEdy3F4CgSLvFkw" type="4003" source="__1do0IvxEdy3F4CgSLvFkw" target="_z88tQIvyEdy3F4CgSLvFkw">
<children xmi:type="notation:Node" xmi:id="_IYqjgIvzEdy3F4CgSLvFkw" type="6002">
<layoutConstraint xmi:type="notation:Location" xmi:id="_IYqjgYvzEdy3F4CgSLvFkw" y="40"/>
</children>
<styles xmi:type="notation:ConnectorStyle" xmi:id="_IYp8cYvzEdy3F4CgSLvFkw"/>
<styles xmi:type="notation:FontStyle" xmi:id="_IYp8covzEdy3F4CgSLvFkw" fontName="Sans"/>
<element xmi:type="mindmap:Relationship" href="oda4Emf.mindmap#//@map/@relations.9"/>
<bendpoints xmi:type="notation:RelativeBendpoints" xmi:id="_IYp8c4vzEdy3F4CgSLvFkw" points="[40, 20, -121, -60]$[121, 60, -40, -20]"/>
</edges>
<edges xmi:type="notation:Edge" xmi:id="_IYxRMIvzEdy3F4CgSLvFkw" type="4002" source="_IYeWQIvzEdy3F4CgSLvFkw" target="_Z7-bgIvuEdy3F4CgSLvFkw">
<children xmi:type="notation:Node" xmi:id="_IYx4QIvzEdy3F4CgSLvFkw" type="6001">
<layoutConstraint xmi:type="notation:Location" xmi:id="_IYx4QYvzEdy3F4CgSLvFkw" y="40"/>
</children>
<styles xmi:type="notation:ConnectorStyle" xmi:id="_IYxRMYvzEdy3F4CgSLvFkw"/>
<styles xmi:type="notation:FontStyle" xmi:id="_IYxRMovzEdy3F4CgSLvFkw" fontName="Sans"/>
<element xmi:type="mindmap:Relationship" href="oda4Emf.mindmap#//@map/@relations.10"/>
<bendpoints xmi:type="notation:RelativeBendpoints" xmi:id="_IYxRM4vzEdy3F4CgSLvFkw" points="[0, 0, -943, 180]$[921, -176, -22, 4]"/>
</edges>
</notation:Diagram>
--------------080403060101020806020705--
Re: Help with Ecore ODA Driver - Need MindMap data [message #38287 is a reply to message #38123] Wed, 07 November 2007 07:49 Go to previous messageGo to next message
Hi John,
> Cool. Glad to help.
I'm not really familiar with the problem domain, so I was actually a bit
hung up here because my time was limited.
Because the use case called out in the Bugzilla entry specifies Mindmap:
<https://bugs.eclipse.org/bugs/show_bug.cgi?id=132958>. If the
contribution proved capable of achieving the test case but didn't use
Mindmap data in the test cases I'm sure it would be accepted anyway.
It's just nice to have the test prove the capability.
> First things first.
Yup.
>> goal is to donate the code (but that takes a while, from what I hear)
>> we need a place to park until the process is complete.
Yes. I started a newer thread on this subject entitled "Attempt to avoid
misuse of Eclipse Foundation trademarks".
> regards,
> John
Jeff
Re: Help with Ecore ODA Driver - Need MindMap data [message #38319 is a reply to message #38219] Wed, 07 November 2007 07:53 Go to previous messageGo to next message
Thanks John,
Big help! No worries if there are any mistakes--just getting this sort
of test data will help me move forward and I'm sure someone will provide
a correction somewhere along the line if it's needed.
Trying to figure out how best to collaborate. See the newer thread for
more...
Jeff
> Hi Jeff,
> need for test data.
> the report writers?
> cheers,
> John
Re: Help with Ecore ODA Driver - Need MindMap data [message #38759 is a reply to message #38219] Tue, 13 November 2007 01:46 Go to previous messageGo to next message
--------------090300070508000101040007
Have attached
1. an updated mindMap instance to use for test data
2. its gmf editor file
3. and a set of simple example ocl queries
Please note:
My OCL skills are not very acute and so are not quite up to the level
necessary to weave together sensible queries for this very (too??)
abstract mindmap model. In order to do so one would need to use nested
ocl expressions to first capture relationship source and targets in
order to follow the edges from node to node. Ugh!
Anyone knows ocl well enough to craft us a couple of nested ocl queries??
As an alternative I suggest we abandon the mindmap metamodel and just
use the perennially favorite EXTLibrary metamodel for our testing
purposes instead.
kind regards,
John
> Hi Jeff,
> need for test data.
> the report writers?
> cheers,
> John
>> driver working but I don't have much for the UI yet.
>> Jeff
>>> Hi Jeff,
>>> best regards,
>>> John Conlon
>>>> I most need right now is more robust test data. Would someone be
>>>> Bugzilla entry:
>>>> Model:
>>>> Thanks,
>>>> Jeff
aWNzIGR1cmF0aW9uPSI5LjAiIGVuZERhdGU9IjIwMDctMDctMTYiIG5hbWU9 ImVjbGlwc2Uu
ZHRwIiBwZXJjZW50Q29tcGxldGU9IjEwMC4wIiBwcmlvcml0eT0iVFdPIiBz dGFydERhdGU9
IjIwMDctMDctMDciPgogICAgPGNvbW1lbnRzIGF1dGhvcj0iIy8vQG1hcC9A cmVzb3VyY2Vz
LjIiIHBvc3REYXRlPSIyMDA3LTA3LTE2IiBzdWJqZWN0PSJIZWxwIHdpdGgg RWNvcmUgT0RB
IERyaXZlciAtIE5lZWQgTWluZE1hcCBkYXRhIj4KICAgICAgPGl0ZW1zLz4K ICAgICAgPGl0
ZW1zIGF1dGhvcj0iIy8vQG1hcC9AcmVzb3VyY2VzLjIiIGJvZHk9IkkgaGFk IHNldmVyYWwg
b2ZmZXJzIHRvIGhlbHAgd2l0aCB3b3JrIG9uIGFuIEVjb3JlIE9EQSBkcml2 ZXIuIFdoYXQg
SSBtb3N0IG5lZWQgcmlnaHQgbm93IGlzIG1vcmUgcm9idXN0IHRlc3QgZGF0 YS4gV291bGQg
c29tZW9uZSBiZSB3aWxsaW5nICYjeEE7dG8gcHJvZHVjZSBzb21lIHNhbXBs ZSBkYXRhIGNv
bmZvcm1pbmcgdG8gdGhlIE1pbmRNYXAgbW9kZWwgYXMgbWVudGlvbmVkIGlu IHRoZSBCdWd6
aWxsYSBlbnRyeSBmb3IgdGhpcyBmZWF0dXJlIHJlcXVlc3Q/IiBpdGVtUG9z dERhdGU9IjIw
MDctMDctMTYiLz4KICAgICAgPGl0ZW1zLz4KICAgICAgPGl0ZW1zIGF1dGhv cj0iIy8vQG1h
cC9AcmVzb3VyY2VzLjMiIGJvZHk9IiIvPgogICAgICA8aXRlbXMgYXV0aG9y PSIjLy9AbWFw
L0ByZXNvdXJjZXMuMyIgYm9keT0iSmVmZiwgUHJvYmFibHkgaXQncyBiZXN0 IGp1c3QgdG8g
bWFudWZhY3R1cmUgeW91ciBvd24gdXNpbmcgdGhlIGdlbmVyYXRlZCBlZGl0 b3IuICBJJ20g
bm90IHN1cmUgdGhlcmUgYXJlIGFueSByZWFsIHdvcmxkIHVzZXMgb2YgdGhp cyBzYW1wbGUg
bW9kZWwuLi4iIGl0ZW1Qb3N0RGF0ZT0iMjAwNy0wNy0xOSIvPgogICAgICA8 aXRlbXMgYXV0
aG9yPSIjLy9AbWFwL0ByZXNvdXJjZXMuMCIgYm9keT0iSGkgSmVmZiwgSSd2 ZSBiZWVuIGEg
c2xlZXAgYXQgdGhlIHdoZWVsIC0ganVzdCBub3cgY2hlY2tlZCB0aGUgZHRw IG1haWwgbGlz
dCBhbmQgc2F3IHlvdXIgRWNvcmUgdGhyZWFkcy4gIChIYWQgYmVlbiB3YXRj aGluZyBFTUYg
YW5kIEJpcnQuIERVSC4pJiN4QTsmI3hBO0RvIHlvdSBzdGlsbCBuZWVkIE1p bmRNYXAgZGF0
YT8/IElzIHRoZXJlIGFueXRoaW5nIGVsc2UgSSBjYW4gZG8gdG8gaGVscD8g YmVzdCByZWdh
cmRzLCBKb2huIENvbmxvbiIgaXRlbVBvc3REYXRlPSIyMDA3LTExLTAzIi8+ CiAgICAgIDxp
dGVtcy8+CiAgICAgIDxpdGVtcy8+CiAgICAgIDxpdGVtcy8+CiAgICAgIDxp dGVtcyBhdXRo
b3I9IiMvL0BtYXAvQHJlc291cmNlcy4yIiBib2R5PSJTdXJlIHRoaW5nISBJ J2Qgc2xvd2Vk
IGRvd24gYSBiaXQgd29ya2luZyBvbiBpdCwgYnV0IHdhcyBqdXN0IGVhc2lu ZyBiYWNrIGlu
dG8gZGV2ZWxvcG1lbnQuIENvdWxkIHN0aWxsIHVzZSBzb21lIGdvb2QgdGVz dCBkYXRhLS1p
ZiB5b3UnZCB3YW50IHRvIGp1bXAgaW4gdGhhdCdkIGJlIGEgZ29vZCBwbGFj ZS4gSSBiZWxp
ZXZlIEkgaGF2ZSBhIGJhc2ljIGRyaXZlciB3b3JraW5nIGJ1dCBJIGRvbid0 IGhhdmUgbXVj
aCBmb3IgdGhlIFVJIHlldC4mI3hBOyYjeEE7U29tZW9uZSBlbHNlIGhhcyBj b250YWN0ZWQg
bWUgYWJvdXQgaGVscGluZyBvbiB0aGUgcHJvamVjdCBidXQgd2Ugd2VyZSBq dXN0IGdldHRp
bmcgc3RhcnRlZCBkaXNjdXNzaW5nIGhvdyBiZXN0IHRvIGNvbGxhYm9yYXRl LiBTaW5jZSBv
dXIgZ29hbCBpcyB0byBkb25hdGUgdGhlIGNvZGUgKGJ1dCB0aGF0IHRha2Vz IGEgd2hpbGUs
IGZyb20gd2hhdCBJIGhlYXIpIHdlIG5lZWQgYSBwbGFjZSB0byBwYXJrIHVu dGlsIHRoZSBw
cm9jZXNzIGlzIGNvbXBsZXRlLiBKZWZmICIgaXRlbVBvc3REYXRlPSIyMDA3 LTExLTA0Ii8+
CiAgICAgIDxpdGVtcyBhdXRob3I9IiMvL0BtYXAvQHJlc291cmNlcy4wIiBi b2R5PSJDb29s
LiAgR2xhZCB0byBoZWxwLiBZb3Ugc3RpbGwgd2FudCBpdCBhcyBhIG1pbmRt YXAgbW9kZWw/
ICBOb3QgdG9vIGZhbWlsaWFyIHdpdGggdGhlIG1vZGVsLCBidXQgSSBkbyB1 c2UgdGhlIEph
dmEgYmFzZWQgbWluZG1hcCBhcHBsaWNhdGlvbiBGcmVlTWluZCBzbyBJIGFt IGZhbWlsaWFy
IHdpdGggdGhlIHByb2JsZW0gZG9tYWluLiAgKEkgYW0gYXNzdW1pbmcgaXQg aXMgdGhlIHNh
bWUuKSBJZiB5b3Ugd2FuZCB0aGUgZGF0YSBhcyBhIG1pbmRtYXAgbW9kZWwg YSB0cml2aWFs
IHF1ZXN0aW9uIGNvbWVzIHRvIG1pbmQgLSBkbyB5b3UgaGF2ZSBhIHN1Ympl Y3QgeW91IHdv
dWxkIGxpa2UgdG8gbWFwIG91dD8mI3hBOyYjeEE7QlRXLVdoeSBtaW5kbWFw IGFuZCBub3Qg
dGhlIHBlcmVubmlhbGx5IGZhdm9yaXRlIExpYnJhcnkgb3IgUHVyY2hhc2VP cmRlciB2YXJp
YW50cz8gIiBpdGVtUG9zdERhdGU9IjIwMDctMTEtMDUiLz4KICAgIDwvY29t bWVudHM+CiAg
ICA8Y29tbWVudHMgYXV0aG9yPSIjLy9AbWFwL0ByZXNvdXJjZXMuMiIgcG9z dERhdGU9IjIw
MDctMDctMDciIHN1YmplY3Q9IkVjb3JlICZhbXA7IE9EQSI+CiAgICAgIDxp dGVtcyBhdXRo
b3I9IiMvL0BtYXAvQHJlc291cmNlcy4yIiBib2R5PSJJIGhhdmUgbmVlZCBv ZiBhbiBPREEg
ZGF0YSBwcm92aWRlciBmb3IgRWNvcmUgbW9kZWxzICh1bHRpbWF0ZWx5IGZv ciBCSVJUIHJl
cG9ydGluZykuIEkndmUgc2VlbiB0aGlzIHJlcXVlc3RlZCBiZWZvcmUgYnV0 IGxpdHRsZSBj
b252ZXJzYXRpb24gYXJvdW5kIHRoZSB0b3BpYy4gSSdtIGNvbnRlbXBsYXRp bmcgYXR0ZW1w
dGluZyB0byB3cml0ZSBhIHByb3ZpZGVyIGJ1dCBJJ20gZmFpcmx5IG5ldyB0 byBEVFAgYW5k
IE9EQSBhbmQgdW5zdXJlIG9mIHRoZSBwaXRmYWxscyBJIG1heSBlbmNvdW50 ZXIuIEFueW9u
ZSB3YW50IHRvIG9mZmVyIHdvcmRzIG9mIHdhcm5pbmcgb3IgZW5jb3VyYWdl bWVudD9KZWZm
IiBpdGVtUG9zdERhdGU9IjIwMDctMDctMDciLz4KICAgICAgPGl0ZW1zIGF1 dGhvcj0iIy8v
QG1hcC9AcmVzb3VyY2VzLjMiIGJvZHk9IkplZmYsIEhvcGVmdWxseSB5b3Un bGwgZXhjdXNl
IG15IGlnbm9yYW5jZSwgYnV0IHdoYXQncyBhbiBPREEgZGF0YSBwcm92aWRl cj8iIGl0ZW1Q
b3N0RGF0ZT0iMjAwNy0wNy0wOSIvPgogICAgPC9jb21tZW50cz4KICA8L3Jv b3RUb3BpY3M+
CiAgPHJvb3RUb3BpY3MgbmFtZT0iTmV3c2dyb3VwIi8+CiAgPHJvb3RUb3Bp Y3MgZHVyYXRp
b249IjcuMCIgZW5kRGF0ZT0iMjAwNy0xMC0wMSIgbmFtZT0iT0RBIEV4dGVu c2lvbnMgYW5k
IEJpcnQiIHBlcmNlbnRDb21wbGV0ZT0iOTAuMCIgcHJpb3JpdHk9Ik9ORSIg c3RhcnREYXRl
PSIyMDA3LTAzLTAxIj4KICAgIDxjb21tZW50cyBhdXRob3I9IiMvL0BtYXAv QHJlc291cmNl
cy4xIiBwb3N0RGF0ZT0iMjAwNy0wMy0wMSIgc3ViamVjdD0iQSBQcmltZXIg b24gT0RBIEV4
dGVuc2lvbnMgYW5kIEJJUlQiPgogICAgICA8aXRlbXMgYXV0aG9yPSIjLy9A bWFwL0ByZXNv
dXJjZXMuMCIgYm9keT0iIi8+CiAgICAgIDxpdGVtcyBhdXRob3I9IiMvL0Bt YXAvQHJlc291
cmNlcy4xIiBib2R5PSJDcmVhdGluZyBDdXN0b20gRGF0YSBTb3VyY2VzIGZv ciBCSVJUIFJl
cG9ydHMgVXNpbmcgT0RBIEV4dGVuc2lvbiBQb2ludHMiIGl0ZW1Qb3N0RGF0 ZT0iMjAwMS0w
MS0xMSIvPgogICAgICA8aXRlbXMgYm9keT0iU2Vjb25kIGl0ZW0iLz4KICAg IDwvY29tbWVu
dHM+CiAgICA8Y29tbWVudHMgYXV0aG9yPSIjLy9AbWFwL0ByZXNvdXJjZXMu MSIgc3ViamVj
dD0iT0RBIEV4dGVuc2lvbnMgYW5kIEJJUlQgLSBQYXJ0IDIiPgogICAgICA8 aXRlbXMvPgog
ICAgICA8aXRlbXMgYXV0aG9yPSIjLy9AbWFwL0ByZXNvdXJjZXMuMSIgYm9k eT0iQ3VzdG9t
aXppbmcgdGhlIFVzZXLigJlzIEV4cGVyaWVuY2UiIGl0ZW1Qb3N0RGF0ZT0i MjAwNy0wNC0w
MSIvPgogICAgPC9jb21tZW50cz4KICAgIDxjb21tZW50cyBhdXRob3I9IiMv L0BtYXAvQHJl
c291cmNlcy4xIiBwb3N0RGF0ZT0iMjAwNy0xMC0wMSIgc3ViamVjdD0iT0RB IEV4dGVuc2lv
bnMgYW5kIEJJUlQ6IFBhcnQgMyIvPgogIDwvcm9vdFRvcGljcz4KICA8cm9v dFRvcGljcyBu
YW1lPSJSZWZlcmVuY2VzIi8+CiAgPHJvb3RUb3BpY3MgbmFtZT0iT0RBIGZv ciBFTUYiLz4K
ICA8cm9vdFRvcGljcyBuYW1lPSJUYXNrIi8+CiAgPHJvb3RUb3BpY3MgbmFt ZT0iQ3JlYXRl
IEN1c3RvbSBFTUYgRGF0YVNvdXJjZSIvPgogIDxyb290VG9waWNzIG5hbWU9 IkNyZWF0ZSBJ
bnRlZ3JhdGlvbiBUZXN0cyIvPgogIDxyb290VG9waWNzIG5hbWU9IkNyZWF0 ZSBUZXN0IERh
dGEiLz4KICA8cm9vdFRvcGljcyBuYW1lPSJDcmVhdGUgRGVzaWduZXIgVUkg UGx1Z2luIi8+
CiAgPHJlbGF0aW9ucyBsYWJlbD0iZWNsaXBzZSBtYWdhemluZXMiIHNvdXJj ZT0iIy8vQG1h
cC9Acm9vdFRvcGljcy4xIiB0YXJnZXQ9IiMvL0BtYXAvQHJvb3RUb3BpY3Mu MCIgdHlwZT0i
RVhURU5EUyIvPgogIDxyZWxhdGlvbnMgbGFiZWw9ImVjbGlwc2UgbmV3c2dy b3VwcyIgc291
cmNlPSIjLy9AbWFwL0Byb290VG9waWNzLjIiIHRhcmdldD0iIy8vQG1hcC9A cm9vdFRvcGlj
cy4zIiB0eXBlPSJFWFRFTkRTIi8+CiAgPHJlbGF0aW9ucyBsYWJlbD0ic2Vy aWVzT25PZGFB
bmRCaXJ0IiBzb3VyY2U9IiMvL0BtYXAvQHJvb3RUb3BpY3MuNCIgdGFyZ2V0 PSIjLy9AbWFw
L0Byb290VG9waWNzLjEiIHR5cGU9IklOQ0xVREVTIi8+CiAgPHJlbGF0aW9u cyBsYWJlbD0i
cmVmZXJlbmNlcyIgc291cmNlPSIjLy9AbWFwL0Byb290VG9waWNzLjYiIHRh cmdldD0iIy8v
QG1hcC9Acm9vdFRvcGljcy41IiB0eXBlPSJJTkNMVURFUyIvPgogIDxyZWxh dGlvbnMgbGFi
ZWw9InRhc2tzIiBzb3VyY2U9IiMvL0BtYXAvQHJvb3RUb3BpY3MuNiIgdGFy Z2V0PSIjLy9A
bWFwL0Byb290VG9waWNzLjciIHR5cGU9IklOQ0xVREVTIi8+CiAgPHJlbGF0 aW9ucyBsYWJl
bD0ibmV3c2dyb3VwcyIgc291cmNlPSIjLy9AbWFwL0Byb290VG9waWNzLjUi IHRhcmdldD0i
Iy8vQG1hcC9Acm9vdFRvcGljcy4zIiB0eXBlPSJJTkNMVURFUyIvPgogIDxy ZWxhdGlvbnMg
bGFiZWw9InBlcmlvZGljYWxzIiBzb3VyY2U9IiMvL0BtYXAvQHJvb3RUb3Bp Y3MuNSIgdGFy
Z2V0PSIjLy9AbWFwL0Byb290VG9waWNzLjAiIHR5cGU9IklOQ0xVREVTIi8+ CiAgPHJlbGF0
aW9ucyBsYWJlbD0iZXh0ZW5kcyIgc291cmNlPSIjLy9AbWFwL0Byb290VG9w aWNzLjgiIHRh
cmdldD0iIy8vQG1hcC9Acm9vdFRvcGljcy43IiB0eXBlPSJFWFRFTkRTIi8+ CiAgPHJlbGF0
aW9ucyBsYWJlbD0iZXh0ZW5kcyIgc291cmNlPSIjLy9AbWFwL0Byb290VG9w aWNzLjkiIHRh
aW9ucyBsYWJlbD0iaW5jbHVkZXMiIHNvdXJjZT0iIy8vQG1hcC9Acm9vdFRv cGljcy45IiB0
YXJnZXQ9IiMvL0BtYXAvQHJvb3RUb3BpY3MuMTAiIHR5cGU9IklOQ0xVREVT Ii8+CiAgPHJl
bGF0aW9ucyBsYWJlbD0iZXh0ZW5kcyIgc291cmNlPSIjLy9AbWFwL0Byb290 VG9waWNzLjEx
IiB0YXJnZXQ9IiMvL0BtYXAvQHJvb3RUb3BpY3MuNyIgdHlwZT0iRVhURU5E UyIvPgogIDxy
ZXNvdXJjZXMgZW1haWw9Impjb25sb25AdmVydGljb24uY29tIiBuYW1lPSJK b2huIENvbmxv
biIvPgogIDxyZXNvdXJjZXMgY29tbWVudHM9IiMvL0BtYXAvQHJvb3RUb3Bp Y3MuNC9AY29t
bWVudHMuMCAjLy9AbWFwL0Byb290VG9waWNzLjQvQGNvbW1lbnRzLjEgIy8v QG1hcC9Acm9v
dFRvcGljcy40L0Bjb21tZW50cy4yIiBuYW1lPSJTY290dCBSb3NlbmJhdW0i Lz4KICA8cmVz
b3VyY2VzIGNvbW1lbnRzPSIjLy9AbWFwL0Byb290VG9waWNzLjIvQGNvbW1l bnRzLjAgIy8v
QG1hcC9Acm9vdFRvcGljcy4yL0Bjb21tZW50cy4xIiBlbWFpbD0iamVmZi5y YW1zZGFsZUBn
bWFpbC5jb20iIG5hbWU9IkplZmYgUmFtc2RhbGUiLz4KICA8cmVzb3VyY2Vz IGVtYWlsPSJt
ZXJrc0BjYS5pYm0uY29tIiBuYW1lPSJFZCBNZXJrcyIvPgo8L21pbmRtYXA6 bWFwPg==
name="oda4Emf.mmd"
<notation:Diagram xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:mindmap="http://www.example.org/mindmap" xmlns:notation="http://www.eclipse.org/gmf/runtime/1.0.1/notation" xmi:id="_NwOUUIvCEdy3F4CgSLvFkw" type="Mindmap" name="oda4Emf.mmd" measurementUnit="Pixel">
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</edges>
</children>
</edges>
</children>
</edges>
</children>
</edges>
</children>
</edges>
</children>
</edges>
</children>
</edges>
</children>
</edges>
</children>
</edges>
</children>
</edges>
</children>
</edges>
</notation:Diagram>
name="ODATestDataQueries"
filename="ODATestDataQueries"
-- The following OCL Queries use the Document Root as the context
-- List all the resources
self.map.resources
-- List the names and emails of all the resources
self.map.resources -> collect(
r: Resource | Tuple {
name: String = r.name,
email: String = r.email
-- List all the relations
self.map.relations
-- List the label, the source, and the target Topics of all the relations
self.map.relations -> collect(
r: Relationship | Tuple {
label: String = r.label,
source: Topic = r.source,
target: Topic = r.target
-- List the label, the source, and the target names of all the relations of
-- eclipse magazines
self.map.relations -> select(label='eclipse magazines') -> collect(
source: String = r.source.name,
target: String = r.target.name
-- List all the rootTopics
self.map.rootTopics
self.map.rootTopics -> collect(
r: Topic | Tuple {
-- List all the names and dates for the rootTopics
r: Topic | Tuple {
startDate: Date = r.startDate,
endDate: Date = r.endDate
-- List all the names and dates for rootTopics with a startDate
self.map.rootTopics -> select(not startDate.oclIsUndefined()) -> collect(
r: Topic | Tuple {
--------------090300070508000101040007--
Re: Help with Ecore ODA Driver - Need MindMap data [message #39152 is a reply to message #32918] Wed, 28 November 2007 11:41 Go to previous messageGo to next message
Philipp W. Kutter is currently offline Philipp W. KutterFriend
Hi, Jeff.
As mentioned, we need an Ecore driver for Birt too.
Do you still need help? Is there already something to test?
Best, Philipp
> Bugzilla entry:
> Model:
> Jeff
Re: Help with Ecore ODA Driver - Need MindMap data [message #39183 is a reply to message #39152] Wed, 28 November 2007 13:02 Go to previous messageGo to next message
Philipp,
Jeff tends to hang out on IRC's #eclipse-modeling so you might try
chatting with him there. He's asimino, or some spelling variation of
that. It think it would be a very valuable contribution if this work
resulted in being able to feed EMF model data into BIRT. I could
imagine a great many uses for that...
Philipp W. Kutter wrote:
> Hi, Jeff.
> Best, Philipp
>> Bugzilla entry:
>> Model:
>> Thanks,
>> Jeff
Re: Help with Ecore ODA Driver - Need MindMap data [message #39214 is a reply to message #39183] Wed, 28 November 2007 17:00 Go to previous message
Hi, Ed.
I'll see whether I manage to get hooked to IRC....
For my case: I committed to one of our clients that we get Birt
reporting running over his EMF data, we adviced him to build.
I wonder if CDO would be a good intermediate technology too. I am
thinking of looking at Birt's report types, and then create a mapping
model from EMF to these report types, and then drive the
parameterization of Birt along these mapping models. Birt would
then think it accesses a normal DB, and all the logic is in the
interpreter of the mapping model. This may have as advantage, that it
may allow to connect different reporting solutions.
On the other hand, if we can contribute to Jeff's work, and then take
advantage of this, I would like this too.
Best, Philipp
Ed Merks wrote:
> Philipp,
>> Hi, Jeff.
>> Best, Philipp
>>> Bugzilla entry:
>>> Model:
>>> Thanks,
>>> Jeff
Re: Help with Ecore ODA Driver - Need MindMap data [message #586634 is a reply to message #32918] Thu, 19 July 2007 15:41 Go to previous message
Jeff,
> Bugzilla entry:
> Model:
> Jeff
Ed Merks
Re: Help with Ecore ODA Driver - Need MindMap data [message #588400 is a reply to message #32918] Fri, 02 November 2007 20:20 Go to previous message
Hi Jeff,
best regards,
John Conlon
> Bugzilla entry:
> Model:
> Jeff
Re: Help with Ecore ODA Driver - Need MindMap data [message #588405 is a reply to message #37971] Mon, 05 November 2007 05:53 Go to previous message
Jeff
> Hi Jeff,
> best regards,
> John Conlon
>> Bugzilla entry:
>> Model:
>> Thanks,
>> Jeff
Re: Help with Ecore ODA Driver - Need MindMap data [message #588445 is a reply to message #37997] Mon, 05 November 2007 16:18 Go to previous message
Cool. Glad to help.
First things first.
regards,
John
> Jeff
>> Hi Jeff,
>> best regards,
>> John Conlon
>>> Bugzilla entry:
>>> Model:
>>> Thanks,
>>> Jeff
Re: Help with Ecore ODA Driver - Need MindMap data [message #588471 is a reply to message #37997] Tue, 06 November 2007 00:50 Go to previous message
Hi Jeff,
need for test data.
the report writers?
cheers,
John
> Jeff
>> Hi Jeff,
>> best regards,
>> John Conlon
>>> Bugzilla entry:
>>> Model:
>>> Thanks,
>>> Jeff
name="oda4Emf.mmd"
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</edges>
</children>
</edges>
</children>
</edges>
</children>
</edges>
</children>
</edges>
</children>
</edges>
</children>
</edges>
</children>
</edges>
</children>
</edges>
</children>
</edges>
</children>
</edges>
</notation:Diagram>
Re: Help with Ecore ODA Driver - Need MindMap data [message #588488 is a reply to message #38123] Wed, 07 November 2007 07:49 Go to previous message
Hi John,
> Cool. Glad to help.
> First things first.
Yup.
> regards,
> John
Jeff
Re: Help with Ecore ODA Driver - Need MindMap data [message #588497 is a reply to message #38219] Wed, 07 November 2007 07:53 Go to previous message
Thanks John,
more...
Jeff
> Hi Jeff,
> need for test data.
> the report writers?
> cheers,
> John
Re: Help with Ecore ODA Driver - Need MindMap data [message #588621 is a reply to message #38219] Tue, 13 November 2007 01:46 Go to previous message
Have attached
Please note:
purposes instead.
kind regards,
John
> Hi Jeff,
> need for test data.
> the report writers?
> cheers,
> John
>> Jeff
>>> Hi Jeff,
>>> best regards,
>>> John Conlon
>>>> Bugzilla entry:
>>>> Model:
>>>> Thanks,
>>>> Jeff
name="oda4Emf.mmd"
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</children>
</edges>
</children>
</edges>
</children>
</edges>
</children>
</edges>
</children>
</edges>
</children>
</edges>
</children>
</edges>
</children>
</edges>
</children>
</edges>
</children>
</edges>
</children>
</edges>
</notation:Diagram>
self.map.resources
self.map.relations
self.map.rootTopics
r: Topic | Tuple {
r: Topic | Tuple {
r: Topic | Tuple {
Re: Help with Ecore ODA Driver - Need MindMap data [message #588734 is a reply to message #32918] Wed, 28 November 2007 11:41 Go to previous message
Hi, Jeff.
Best, Philipp
Jeff Ramsdale wrote:
> I had several offers to help with work on an Ecore ODA driver. What I
> most need right now is more robust test data. Would someone be willing
> to produce some sample data conforming to the MindMap model as mentioned
> Bugzilla entry:
> < https://bugs.eclipse.org/bugs/show_bug.cgi?id=132958&que ry_format=specific&order=relevance+desc&bug_status=_ _open__>
> Model:
> < http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.gmf/exa mples/org.eclipse.gmf.examples.mindmap/model/mindmap.ecore?r evision=1.1&root=Modeling_Project>
> Jeff
Re: Help with Ecore ODA Driver - Need MindMap data [message #588746 is a reply to message #39152] Wed, 28 November 2007 13:02 Go to previous message
Philipp,
> Hi, Jeff.
> Best, Philipp
>> Bugzilla entry:
>> Model:
>> Thanks,
>> Jeff
Ed Merks
Re: Help with Ecore ODA Driver - Need MindMap data [message #588754 is a reply to message #39183] Wed, 28 November 2007 17:00 Go to previous message
Hi, Ed.
Best, Philipp
Ed Merks wrote:
> Philipp,
>> Hi, Jeff.
>> Best, Philipp
>>> Bugzilla entry:
>>> Model:
>>> Thanks,
>>> Jeff
Previous Topic:generic JDBC is unsupported
Next Topic:Edit or add column to mysql database?
Current Time: Fri Jan 22 01:09:43 GMT 2021
Powered by FUDForum. Page generated in 0.04280 seconds
