Re: Explanation of the Activity Diagram Loop Node [message #1688180 is a reply to message #1687651] |
Fri, 20 March 2015 09:23 |
Camille Letavernier Messages: 952 Registered: February 2011 |
Hi Chris,
Papyrus doesn't provide any specific help for defining such LoopNodes. The UML Specification mentions (UML 2.5 16.11.4):
Quote:No standard notation is defined for ConditionalNodes, LoopNodes or SequenceNodes
The general idea is that any node inside the LoopNode may be graphically grouped in any way you like, and then you use the Properties page to identify which one(s) is/are in the Setup, Test or Body. If additional grouping is required, then you should have a single "Setup", "Test" and "Body" node (One for each), and add the details inside each (More or less like your example, except that the Body/Setup/Tests are not graphically explicit)
Camille
Camille Letavernier
FUDForum. Page generated in 0.03258 seconds
