Home » Archived » XML Schema Definition (XSD) » Maximum content for <all> ??
Re: Maximum content for <all> ?? [message #32903 is a reply to message #32831] |
Mon, 10 November 2003 11:54 |
Hayden,
In order to validate the Unique Particle Attribute rule the XSD model builds a finite state
machine for each content model. Unfortunately a finite state machine for an <all> content
model with n alternatives has n! states. So in cases where the finite state machine is too
big to construct I put out a message to that effect. I really need to revisit this issue
eventually, and handle it more gracefully so you're welcome to open a bugzilla defect
requesting that; I probably won't have time to look at it for quite a while.
Hayden Marchant wrote:
> I was parsing a pretty simple xsd with the following complex type:
> <xsd:complexType name="PowerRequest">
> <xsd:all>
> <xsd:element name="power" type="xsd:string"/>
> <xsd:element name="page" type="xsd:string"/>
> <xsd:element name="mode" type="xsd:string"/>
> <xsd:element name="tag" type="xsd:string"/>
> <xsd:element name="type" type="xsd:string"/>
> <xsd:element name="devtag" type="xsd:string"/>
> <xsd:element name="sort" type="xsd:string" minOccurs="0"/>
> <xsd:element name="variations" type="xsd:string" minOccurs="0"/>
> <xsd:element name="locale" type="xsd:string" minOccurs="0"/>
> </xsd:all>
> </xsd:complexType>
> and I got the following message:
> Line 60 : bookNs#PowerRequest : XSD: The <all> content model with 9
> options is too large.
> Is this according to W3C spec or is it some kind of bug?
Re: Maximum content for <all> ?? [message #37915 is a reply to message #37816] |
Thu, 04 March 2004 16:46 |
Hayden,
Which version of XSD are you using?
> We're having quite a performance issue with this problem at a client site.
> They have a schema with an <all> with more than 40 particles. Apparently
> they can go out for lunch while the schema is being parsed.
> Can you suggest any workaround for this? I have an ugly idea, which is
> pre-processing the schema to change the <all> to a <sequence>. This would
> be a temporary fix until this issue is resolved. What would be the best
> way to do that? I could do this rename through a URIConverter. Do you have
> any other ideas?
> Hayden
> Ed Merks wrote:
> > Hayden,
> a finite state
> <all> content
> machine is too
> revisit this issue
> bugzilla defect
> > > <xsd:all>
> minOccurs="0"/>
> minOccurs="0"/>
> minOccurs="0"/>
> > > </xsd:all>
> > > </xsd:complexType>
> > > Thanks,
Re: Maximum content for <all> ?? [message #38046 is a reply to message #37995] |
Mon, 08 March 2004 11:52 |
Hayden,
In version 2.0 we don't produce this warning anymore because we use an approximate
DFA to validate the unique particle attribution rule.
> I'm currently using 1.1.1. We're are pretty advanced into release cycle
> and am a bit weary of upgrading eclipse at this stage. Obviously if a
> newer release of Eclipse solves this elegantly, then I can try to postpone
> this issue.
> Hayden
> Ed Merks wrote:
> > Hayden,
> > > any other ideas?
> > > Thanks,
> > > Hayden
> > > Ed Merks wrote:
> > > > Hayden,
> builds
> > > a finite state
> for an
> > > <all> content
> state
> > > machine is too
> > > revisit this issue
> > > bugzilla defect
> while.
> > > > > <xsd:all>
> > > minOccurs="0"/>
> type="xsd:string"
> > > minOccurs="0"/>
> > > minOccurs="0"/>
> > > > > </xsd:all>
> > > > > </xsd:complexType>
> > > > > Thanks,
Re: Maximum content for <all> ?? [message #38239 is a reply to message #38046] |
Mon, 08 March 2004 15:44 |
Hayden Marchant Messages: 90 Registered: July 2009 |
Member |
Does this mean that in Version 2.0, both the performance problem and the
excessive warnings are resolved?
Ed Merks wrote:
> Hayden,
approximate
> > this issue.
> > Thanks,
> > Hayden
> > Ed Merks wrote:
> > > Hayden,
site.
Apparently
would
have
> > > > any other ideas?
> > > > Thanks,
> > > > Hayden
> > > > Ed Merks wrote:
> > > > > Hayden,
> > builds
> > > > a finite state
> > for an
> > > > <all> content
finite
> > state
> > > > machine is too
to
> > > > revisit this issue
> > > > bugzilla defect
> > while.
> > > > > > <xsd:all>
type="xsd:string"/>
type="xsd:string"/>
type="xsd:string"/>
type="xsd:string"/>
type="xsd:string"/>
> > > > minOccurs="0"/>
> > type="xsd:string"
> > > > minOccurs="0"/>
type="xsd:string"
> > > > minOccurs="0"/>
> > > > > > </xsd:all>
> > > > > > </xsd:complexType>
> > > > > > Thanks,
Re: Maximum content for <all> ?? [message #38338 is a reply to message #38239] |
Mon, 08 March 2004 16:32 |
Hayden,
I don't know about the peformance problem, you'll have to try it and see.
> Ed Merks wrote:
> > Hayden,
> approximate
> > > this issue.
> > > Thanks,
> > > Hayden
> > > Ed Merks wrote:
> > > > Hayden,
> site.
> Apparently
> would
> have
> > > > > any other ideas?
> > > > > Thanks,
> > > > > Hayden
> > > > > Ed Merks wrote:
> > > > > > Hayden,
> > > builds
> > > > > a finite state
> > > for an
> > > > > <all> content
> finite
> > > state
> > > > > machine is too
> to
> > > > > revisit this issue
> > > > > bugzilla defect
> > > while.
> > > > > > > <xsd:all>
> type="xsd:string"/>
> type="xsd:string"/>
> type="xsd:string"/>
> type="xsd:string"/>
> type="xsd:string"/>
> > > > > minOccurs="0"/>
> > > type="xsd:string"
> > > > > minOccurs="0"/>
> type="xsd:string"
> > > > > minOccurs="0"/>
> > > > > > > </xsd:all>
> > > > > > > </xsd:complexType>
> > > > > > > Thanks,
Re: Maximum content for <all> ?? [message #38439 is a reply to message #38338] |
Tue, 09 March 2004 08:41 |
Member |
I didn't see that version 2.0.0 helped in performance so I'm going ahead
with a hack to try to speed up the validation since that is the problem
for <all>. I tried parsing and validating 2 very similar schemas - 1 with
<all>s and 1 with <sequence>s and the <all> took more than 20 minutes, and
the <sequence> took 1 minute.
I am trying to change the schema temporarily before validation, and then
change it back. The change that I am making is to change all the model
groups with the ALL compositor to SEQUENCE on the actual XSDSchema that I
am holding in memory. I have written the code and it is not speeding up
the validation the same way that a clean schema with <sequence> would. I
think that my changes are not being propogated through.
I am doing the following:
1. XSDSchema.setIncrementalUpdate(false);
2. XSDModelGroup.setCompositor(XSDComposite.SEQUENCE_LITERAL) - if it is
an ALL_LITERAL
3. XSDSchema.update();
4. XSDSchema.validate();
5. XSDModelGroup.seCompositor(XSDComposite.ALL_LITERAL) - for all those
that I changed.
6. XSDSchema.update().
The validation step at 4. is still taking ages. If I stick in a
XSDSchema.eResource().save(..), in between 3. and 4. I do see my changes,
but I think that I have a step missing to really solve the problem.
Ed Merks wrote:
> Hayden,
> > Thanks,
> > Ed Merks wrote:
> > > Hayden,
> > approximate
postpone
> > > > this issue.
> > > > Thanks,
> > > > Hayden
> > > > Ed Merks wrote:
> > > > > Hayden,
client
> > site.
> > Apparently
which is
> > would
best
you
> > have
> > > > > > any other ideas?
> > > > > > Thanks,
> > > > > > Hayden
> > > > > > Ed Merks wrote:
> > > > > > > Hayden,
model
> > > > builds
> > > > > > a finite state
machine
> > > > for an
> > > > > > <all> content
> > finite
> > > > state
> > > > > > machine is too
need
> > to
> > > > > > revisit this issue
open a
> > > > > > bugzilla defect
quite a
> > > > while.
type:
> > > > > > > > <xsd:all>
> > type="xsd:string"/>
> > type="xsd:string"/>
> > type="xsd:string"/>
type="xsd:string"/>
> > type="xsd:string"/>
> > type="xsd:string"/>
type="xsd:string"
> > > > > > minOccurs="0"/>
> > > > type="xsd:string"
> > > > > > minOccurs="0"/>
> > type="xsd:string"
> > > > > > minOccurs="0"/>
> > > > > > > > </xsd:all>
> > > > > > > > </xsd:complexType>
with 9
> > > > > > > > Thanks,
Re: Maximum content for <all> ?? [message #38605 is a reply to message #38439] |
Wed, 10 March 2004 11:32 |
--------------5B936E16B0F12894FB171CDC
Content-Type: text/plain; charset=us-ascii
Hayden,
If you open a bugzilla defect with your sample schema, I'll look at making changes
in the XSD code to help improve things. One thing I'll try is to change the code
in XSDParticleImpl that tests the size of the <all> to decide if an exact DFA would
be too big:
if (xsdModelGroup.getParticles().size() > 8)
Changing this to perhaps 4 or 5 might help a great deal...
> an ALL_LITERAL
> that I changed.
> Ed Merks wrote:
> > Hayden,
> > > Thanks,
> > > Ed Merks wrote:
> > > > Hayden,
> > > approximate
> postpone
> > > > > this issue.
> > > > > Thanks,
> > > > > Hayden
> > > > > Ed Merks wrote:
> > > > > > Hayden,
> client
> > > site.
> > > Apparently
> which is
> > > would
> best
> you
> > > have
> > > > > > > any other ideas?
> > > > > > > Thanks,
> > > > > > > Hayden
> > > > > > > Ed Merks wrote:
> > > > > > > > Hayden,
> model
> > > > > builds
> > > > > > > a finite state
> machine
> > > > > for an
> > > > > > > <all> content
> > > finite
> > > > > state
> > > > > > > machine is too
> need
> > > to
> > > > > > > revisit this issue
> open a
> > > > > > > bugzilla defect
> quite a
> > > > > while.
> type:
> > > > > > > > > <xsd:all>
> > > type="xsd:string"/>
> > > type="xsd:string"/>
> > > type="xsd:string"/>
> type="xsd:string"/>
> > > type="xsd:string"/>
> > > type="xsd:string"/>
> type="xsd:string"
> > > > > > > minOccurs="0"/>
> > > > > type="xsd:string"
> > > > > > > minOccurs="0"/>
> > > type="xsd:string"
> > > > > > > minOccurs="0"/>
> > > > > > > > > </xsd:all>
> > > > > > > > > </xsd:complexType>
> with 9
> > > > > > > > > Thanks,
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
Hayden,
<p>If you open a bugzilla defect with your sample schema, I'll look at
making changes in the XSD code to help improve things. One thing
I'll try is to change the code in XSDParticleImpl that tests the size of
the <all> to decide if an exact DFA would be too big:
<blockquote>if (xsdModelGroup.getParticles().size() > 8)</blockquote>
<br>
<p>Hayden Marchant wrote:
<blockquote TYPE=CITE>I didn't see that version 2.0.0 helped in performance
so I'm going ahead
<br>with a hack to try to speed up the validation since that is the problem
<br>for <all>. I tried parsing and validating 2 very similar schemas
- 1 with
<br><all>s and 1 with <sequence>s and the <all> took more than
20 minutes, and
<br>the <sequence> took 1 minute.
<p>I am trying to change the schema temporarily before validation, and
then
<br>change it back. The change that I am making is to change all the model
<br>groups with the ALL compositor to SEQUENCE on the actual XSDSchema
that I
<br>am holding in memory. I have written the code and it is not speeding
up
<br>the validation the same way that a clean schema with <sequence>
would. I
<br>think that my changes are not being propogated through.
<p>I am doing the following:
<p>1. XSDSchema.setIncrementalUpdate(false);
<br>2. XSDModelGroup.setCompositor(XSDComposite.SEQUENCE_LITERAL) - if
it is
<br>an ALL_LITERAL
<br>3. XSDSchema.update();
<br>4. XSDSchema.validate();
<br>5. XSDModelGroup.seCompositor(XSDComposite.ALL_LITERAL) - for all those
<br>that I changed.
<br>6. XSDSchema.update().
<p>The validation step at 4. is still taking ages. If I stick in a
<br>XSDSchema.eResource().save(..), in between 3. and 4. I do see my changes,
<br>but I think that I have a step missing to really solve the problem.
<p>Thanks,
<p>Ed Merks wrote:
<p>> Hayden,
<p>> I don't know about the peformance problem, you'll have to try it and
see.
<p>> Hayden Marchant wrote:
<p>> > Does this mean that in Version 2.0, both the performance problem
and the
<br>> > excessive warnings are resolved?
<br>> >
<br>> > Thanks,
<br>> >
<br>> > Ed Merks wrote:
<br>> >
<br>> > > Hayden,
<br>> >
<br>> > > In version 2.0 we don't produce this warning anymore because
we use an
<br>> > approximate
<br>> > > DFA to validate the unique particle attribution rule.
<br>> >
<br>> > > Hayden Marchant wrote:
<br>> >
<br>> > > > I'm currently using 1.1.1. We're are pretty advanced into release
cycle
<br>> > > > and am a bit weary of upgrading eclipse at this stage. Obviously
if a
<br>> > > > newer release of Eclipse solves this elegantly, then I can
try to
<br>postpone
<br>> > > > this issue.
<br>> > > >
<br>> > > > Thanks,
<br>> > > > Hayden
<br>> > > >
<br>> > > > Ed Merks wrote:
<br>> > > >
<br>> > > > > Hayden,
<br>> > > >
<br>> > > > > Which version of XSD are you using?
<br>> > > >
<br>> > > > > Hayden Marchant wrote:
<br>> > > >
<br>> > > > > > We're having quite a performance issue with this problem
at a
<br>client
<br>> > site.
<br>> > > > > > They have a schema with an <all> with more than 40 particles.
<br>> > Apparently
<br>> > > > > > they can go out for lunch while the schema is being parsed.
<br>> > > > > >
<br>> > > > > > Can you suggest any workaround for this? I have an ugly
idea,
<br>which is
<br>> > > > > > pre-processing the schema to change the <all> to a <sequence>.
This
<br>> > would
<br>> > > > > > be a temporary fix until this issue is resolved. What would
be the
<br>best
<br>> > > > > > way to do that? I could do this rename through a URIConverter.
Do
<br>you
<br>> > have
<br>> > > > > > any other ideas?
<br>> > > > > >
<br>> > > > > > Thanks,
<br>> > > > > > Hayden
<br>> > > > > >
<br>> > > > > > Ed Merks wrote:
<br>> > > > > >
<br>> > > > > > > Hayden,
<br>> > > > > >
<br>> > > > > > > In order to validate the Unique Particle Attribute rule
the XSD
<br>model
<br>> > > > builds
<br>> > > > > > a finite state
<br>> > > > > > > machine for each content model. Unfortunately a
finite state
<br>machine
<br>> > > > for an
<br>> > > > > > <all> content
<br>> > > > > > > model with n alternatives has n! states. So in
cases where the
<br>> > finite
<br>> > > > state
<br>> > > > > > machine is too
<br>> > > > > > > big to construct I put out a message to that effect.
I really
<br>need
<br>> > to
<br>> > > > > > revisit this issue
<br>> > > > > > > eventually, and handle it more gracefully so you're welcome
to
<br>open a
<br>> > > > > > bugzilla defect
<br>> > > > > > > requesting that; I probably won't have time to look at
it for
<br>quite a
<br>> > > > while.
<br>> > > > > >
<br>> > > > > > > Hayden Marchant wrote:
<br>> > > > > >
<br>> > > > > > > > I was parsing a pretty simple xsd with the following
complex
<br>type:
<br>> > > > > > > > <xsd:complexType
<br>> > > > > > > >
<xsd:all>
<br>> > > > > > > >
<br>> > type="xsd:string"/>
<br>> > > > > > > >
<br>> > > > > > > >
<br>> > > > > > > >
<br>type="xsd:string"/>
<br>> > > > > > > >
<br>> > > > > > > >
<br>> > > > > > > >
<br>> > > > > > minOccurs="0"/>
<br>> > > > > > > >
<br>> > > > type="xsd:string"
<br>> > > > > > > >
<br>> > > > > > > >
</xsd:all>
<br>> > > > > > > > </xsd:complexType>
<br>> > > > > > > >
<br>> > > > > > > > and I got the following message:
<br>> > > > > > > >
<br>> > > > > > > > Line 60 : bookNs#PowerRequest : XSD: The <all> content
model
<br>with 9
<br>> > > > > > > > options is too large.
<br>> > > > > > > >
<br>> > > > > > > > Is this according to W3C spec or is it some kind of
bug?
<br>> > > > > > > >
<br>> > > > > > > > Thanks,</blockquote>
</html>
--------------5B936E16B0F12894FB171CDC--
Re: Maximum content for <all> ?? [message #38638 is a reply to message #38605] |
Wed, 10 March 2004 14:49 |
Member |
I just entered Bugzilla #54289.
Ed Merks wrote:
> Hayden,
changes
code
DFA would
> be too big:
> > an ALL_LITERAL
> > that I changed.
> > Thanks,
> > Ed Merks wrote:
> > > Hayden,
the
> > > > Thanks,
> > > > Ed Merks wrote:
> > > > > Hayden,
an
> > > > approximate
cycle
if a
> > postpone
> > > > > > this issue.
> > > > > > Thanks,
> > > > > > Hayden
> > > > > > Ed Merks wrote:
> > > > > > > Hayden,
> > client
> > > > site.
> > > > Apparently
> > which is
This
> > > > would
the
> > best
Do
> > you
> > > > have
> > > > > > > > any other ideas?
> > > > > > > > Thanks,
> > > > > > > > Hayden
> > > > > > > > Ed Merks wrote:
> > > > > > > > > Hayden,
XSD
> > model
> > > > > > builds
> > > > > > > > a finite state
> > machine
> > > > > > for an
> > > > > > > > <all> content
the
> > > > finite
> > > > > > state
> > > > > > > > machine is too
really
> > need
> > > > to
> > > > > > > > revisit this issue
to
> > open a
> > > > > > > > bugzilla defect
> > quite a
> > > > > > while.
complex
> > type:
> > > > > > > > > > <xsd:all>
> > > > type="xsd:string"/>
> > > > type="xsd:string"/>
> > > > type="xsd:string"/>
> > type="xsd:string"/>
> > > > type="xsd:string"/>
> > > > type="xsd:string"/>
> > type="xsd:string"
> > > > > > > > minOccurs="0"/>
> > > > > > type="xsd:string"
> > > > > > > > minOccurs="0"/>
> > > > type="xsd:string"
> > > > > > > > minOccurs="0"/>
> > > > > > > > > > </xsd:all>
> > > > > > > > > > </xsd:complexType>
model
> > with 9
> > > > > > > > > > Thanks,
Re: Maximum content for <all> ?? [message #580645 is a reply to message #32831] |
Ed Merks Messages: 33141 Registered: July 2009 |
Hayden,
> <xsd:all>
> </xsd:all>
> </xsd:complexType>
Ed Merks
Re: Maximum content for <all> ?? [message #583750 is a reply to message #37816] |
Hayden,
> any other ideas?
> Hayden
> Ed Merks wrote:
> > Hayden,
> a finite state
> <all> content
> machine is too
> revisit this issue
> bugzilla defect
> > > <xsd:all>
> minOccurs="0"/>
> minOccurs="0"/>
> minOccurs="0"/>
> > > </xsd:all>
> > > </xsd:complexType>
> > > Thanks,
Ed Merks
Re: Maximum content for <all> ?? [message #583833 is a reply to message #37995] |
Hayden,
> this issue.
> Hayden
> Ed Merks wrote:
> > Hayden,
> > > any other ideas?
> > > Thanks,
> > > Hayden
> > > Ed Merks wrote:
> > > > Hayden,
> builds
> > > a finite state
> for an
> > > <all> content
> state
> > > machine is too
> > > revisit this issue
> > > bugzilla defect
> while.
> > > > > <xsd:all>
> > > minOccurs="0"/>
> type="xsd:string"
> > > minOccurs="0"/>
> > > minOccurs="0"/>
> > > > > </xsd:all>
> > > > > </xsd:complexType>
> > > > > Thanks,
Ed Merks
Re: Maximum content for <all> ?? [message #583917 is a reply to message #38046] |
Member |
Ed Merks wrote:
> Hayden,
approximate
> > this issue.
> > Thanks,
> > Hayden
> > Ed Merks wrote:
> > > Hayden,
site.
Apparently
would
have
> > > > any other ideas?
> > > > Thanks,
> > > > Hayden
> > > > Ed Merks wrote:
> > > > > Hayden,
> > builds
> > > > a finite state
> > for an
> > > > <all> content
finite
> > state
> > > > machine is too
to
> > > > revisit this issue
> > > > bugzilla defect
> > while.
> > > > > > <xsd:all>
type="xsd:string"/>
type="xsd:string"/>
type="xsd:string"/>
type="xsd:string"/>
type="xsd:string"/>
> > > > minOccurs="0"/>
> > type="xsd:string"
> > > > minOccurs="0"/>
type="xsd:string"
> > > > minOccurs="0"/>
> > > > > > </xsd:all>
> > > > > > </xsd:complexType>
> > > > > > Thanks,
Re: Maximum content for <all> ?? [message #583975 is a reply to message #38239] |
Hayden,
> Ed Merks wrote:
> > Hayden,
> approximate
> > > this issue.
> > > Thanks,
> > > Hayden
> > > Ed Merks wrote:
> > > > Hayden,
> site.
> Apparently
> would
> have
> > > > > any other ideas?
> > > > > Thanks,
> > > > > Hayden
> > > > > Ed Merks wrote:
> > > > > > Hayden,
> > > builds
> > > > > a finite state
> > > for an
> > > > > <all> content
> finite
> > > state
> > > > > machine is too
> to
> > > > > revisit this issue
> > > > > bugzilla defect
> > > while.
> > > > > > > <xsd:all>
> type="xsd:string"/>
> type="xsd:string"/>
> type="xsd:string"/>
> type="xsd:string"/>
> type="xsd:string"/>
> > > > > minOccurs="0"/>
> > > type="xsd:string"
> > > > > minOccurs="0"/>
> type="xsd:string"
> > > > > minOccurs="0"/>
> > > > > > > </xsd:all>
> > > > > > > </xsd:complexType>
> > > > > > > Thanks,
Ed Merks
Re: Maximum content for <all> ?? [message #584012 is a reply to message #38338] |
Member |
an ALL_LITERAL
that I changed.
Ed Merks wrote:
> Hayden,
> > Thanks,
> > Ed Merks wrote:
> > > Hayden,
> > approximate
postpone
> > > > this issue.
> > > > Thanks,
> > > > Hayden
> > > > Ed Merks wrote:
> > > > > Hayden,
client
> > site.
> > Apparently
which is
> > would
best
you
> > have
> > > > > > any other ideas?
> > > > > > Thanks,
> > > > > > Hayden
> > > > > > Ed Merks wrote:
> > > > > > > Hayden,
model
> > > > builds
> > > > > > a finite state
machine
> > > > for an
> > > > > > <all> content
> > finite
> > > > state
> > > > > > machine is too
need
> > to
> > > > > > revisit this issue
open a
> > > > > > bugzilla defect
quite a
> > > > while.
type:
> > > > > > > > <xsd:all>
> > type="xsd:string"/>
> > type="xsd:string"/>
> > type="xsd:string"/>
type="xsd:string"/>
> > type="xsd:string"/>
> > type="xsd:string"/>
type="xsd:string"
> > > > > > minOccurs="0"/>
> > > > type="xsd:string"
> > > > > > minOccurs="0"/>
> > type="xsd:string"
> > > > > > minOccurs="0"/>
> > > > > > > > </xsd:all>
> > > > > > > > </xsd:complexType>
with 9
> > > > > > > > Thanks,
Re: Maximum content for <all> ?? [message #584088 is a reply to message #38439] |
Hayden,
be too big:
> an ALL_LITERAL
> that I changed.
> Ed Merks wrote:
> > Hayden,
> > > Thanks,
> > > Ed Merks wrote:
> > > > Hayden,
> > > approximate
> postpone
> > > > > this issue.
> > > > > Thanks,
> > > > > Hayden
> > > > > Ed Merks wrote:
> > > > > > Hayden,
> client
> > > site.
> > > Apparently
> which is
> > > would
> best
> you
> > > have
> > > > > > > any other ideas?
> > > > > > > Thanks,
> > > > > > > Hayden
> > > > > > > Ed Merks wrote:
> > > > > > > > Hayden,
> model
> > > > > builds
> > > > > > > a finite state
> machine
> > > > > for an
> > > > > > > <all> content
> > > finite
> > > > > state
> > > > > > > machine is too
> need
> > > to
> > > > > > > revisit this issue
> open a
> > > > > > > bugzilla defect
> quite a
> > > > > while.
> type:
> > > > > > > > > <xsd:all>
> > > type="xsd:string"/>
> > > type="xsd:string"/>
> > > type="xsd:string"/>
> type="xsd:string"/>
> > > type="xsd:string"/>
> > > type="xsd:string"/>
> type="xsd:string"
> > > > > > > minOccurs="0"/>
> > > > > type="xsd:string"
> > > > > > > minOccurs="0"/>
> > > type="xsd:string"
> > > > > > > minOccurs="0"/>
> > > > > > > > > </xsd:all>
> > > > > > > > > </xsd:complexType>
> with 9
> > > > > > > > > Thanks,
<html>
Hayden,
<br>
so I'm going ahead
- 1 with
20 minutes, and
then
that I
up
would. I
it is
<br>an ALL_LITERAL
<br>that I changed.
<p>Thanks,
<p>Ed Merks wrote:
<p>> Hayden,
see.
and the
<br>> >
<br>> > Thanks,
<br>> >
<br>> >
<br>> > > Hayden,
<br>> >
we use an
<br>> > approximate
<br>> >
<br>> >
cycle
if a
try to
<br>postpone
<br>> > > >
<br>> > > > Thanks,
<br>> > > > Hayden
<br>> > > >
<br>> > > >
<br>> > > >
<br>> > > >
<br>> > > >
at a
<br>client
<br>> > site.
<br>> > Apparently
<br>> > > > > >
idea,
<br>which is
This
<br>> > would
be the
<br>best
Do
<br>you
<br>> > have
<br>> > > > > >
<br>> > > > > >
<br>> > > > > >
<br>> > > > > >
the XSD
<br>model
<br>> > > > builds
finite state
<br>machine
<br>> > > > for an
cases where the
<br>> > finite
<br>> > > > state
I really
<br>need
<br>> > to
to
<br>open a
it for
<br>quite a
<br>> > > > while.
<br>> > > > > >
<br>> > > > > >
complex
<br>type:
<br>> > > > > > > >
<xsd:all>
<br>> > > > > > > >
<br>> > > > > > > >
<br>> > > > > > > >
<br>> > > > > > > >
<br>> > > > > > > >
<br>> > > > > > > >
<br>> > > > > > > >
<br>> > > > > > > >
<br>> > > > > > > >
<br>> > > > > > > >
</xsd:all>
<br>> > > > > > > >
<br>> > > > > > > >
model
<br>with 9
<br>> > > > > > > >
bug?
<br>> > > > > > > >
</html>
Ed Merks
Re: Maximum content for <all> ?? [message #584099 is a reply to message #38605] |
Member |
Ed Merks wrote:
> Hayden,
changes
code
DFA would
> be too big:
> > an ALL_LITERAL
> > that I changed.
> > Thanks,
> > Ed Merks wrote:
> > > Hayden,
the
> > > > Thanks,
> > > > Ed Merks wrote:
> > > > > Hayden,
an
> > > > approximate
cycle
if a
> > postpone
> > > > > > this issue.
> > > > > > Thanks,
> > > > > > Hayden
> > > > > > Ed Merks wrote:
> > > > > > > Hayden,
> > client
> > > > site.
> > > > Apparently
> > which is
This
> > > > would
the
> > best
Do
> > you
> > > > have
> > > > > > > > any other ideas?
> > > > > > > > Thanks,
> > > > > > > > Hayden
> > > > > > > > Ed Merks wrote:
> > > > > > > > > Hayden,
XSD
> > model
> > > > > > builds
> > > > > > > > a finite state
> > machine
> > > > > > for an
> > > > > > > > <all> content
the
> > > > finite
> > > > > > state
> > > > > > > > machine is too
really
> > need
> > > > to
> > > > > > > > revisit this issue
to
> > open a
> > > > > > > > bugzilla defect
> > quite a
> > > > > > while.
complex
> > type:
> > > > > > > > > > <xsd:all>
> > > > type="xsd:string"/>
> > > > type="xsd:string"/>
> > > > type="xsd:string"/>
> > type="xsd:string"/>
> > > > type="xsd:string"/>
> > > > type="xsd:string"/>
> > type="xsd:string"
> > > > > > > > minOccurs="0"/>
> > > > > > type="xsd:string"
> > > > > > > > minOccurs="0"/>
> > > > type="xsd:string"
> > > > > > > > minOccurs="0"/>
> > > > > > > > > > </xsd:all>
> > > > > > > > > > </xsd:complexType>
model
> > with 9
> > > > > > > > > > Thanks,
Current Time: Thu Apr 25 21:46:09 GMT 2024
Powered by FUDForum. Page generated in 0.05585 seconds
