Home » Eclipse Projects » Eclipse Platform » JVM terminated. Exit code 13 at startup (Eclipse 3.3)
JVM terminated. Exit code 13 at startup (Eclipse 3.3) [message #323605] Thu, 03 January 2008 19:05 Go to next message
Originally posted by: niewiemek.gmail.com
I have downloaded eclipse-SDK-3.3.1.1-win32.zip and I can't start it at
all. At the very begining of start up I got an error message (see below).
I've googled for this problem and found some solutions unfortunately none
worked for me (deleting configuration folder or starting eclipse with
-clean parameter)
JVM terminated. Exit code=13
-Xms40m
-Xmx256m
-XX:MaxPermSize=256m
-Djava.class.path=C:\#java\eclipse\plugins\org.eclipse.equin ox.launcher_1.0.1.R33x_v20070828.jar
-os win32
-ws win32
-arch x86
-showsplash
c:\#java\eclipse\\plugins\org.eclipse.platform_3.3.2.R33x_20 071022\splash.bmp
-launcher C:\#java\eclipse\eclipse.exe
-name Eclipse
-launcher.library
C:\#java\eclipse\plugins\org.eclipse.equinox.launcher.win23. win32.x86_1.0.2.R331_v20071019\eclipse_1021.dll
-startup
C:\#java\eclipse\plugins\org.eclipse.equinox.launcher_1.0.1. R33x_v20070828.jar
-data C:\#java\workspace
-vm C:\Programme\Java\jre1.5.0_14\bin\client\jvm.dll
-vmargs
-Xms40m
-Xmx256m
My JVM is:
java version "1.5.0_14"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_14-b03)
Java HotSpot(TM) Client VM (build 1.5.0_14-b03, mixed mode, sharing)
I am running Windows XP SP2
So far I was(am) using eclipse 3.2 without any problems why doesn't 3.3
start?
Thank for your support
Marcin
Re: JVM terminated. Exit code 13 at startup (Eclipse 3.3) [message #323608 is a reply to message #323605] Thu, 03 January 2008 19:44 Go to previous messageGo to next message
Steve Blass is currently offline Steve BlassFriend
Try taking the # out of the c:\#java\... pathname. Renaming my install
folder with # at the front like that gave me the same error you reported.
Steve
Maricn L. wrote:
> none worked for me (deleting configuration folder or starting eclipse
> with -clean parameter)
> -Xms40m
> -Xmx256m
> -os win32
> -ws win32
> -arch x86
> -showsplash
> -name Eclipse
> -launcher.library
> -startup
> -vmargs
> -Xms40m
> -Xmx256m
> My JVM is:
> start?
> Marcin
Re: JVM terminated. Exit code 13 at startup (Eclipse 3.3) [message #323609 is a reply to message #323608] Thu, 03 January 2008 20:08 Go to previous message
Steve Blass wrote:
> Try taking the # out of the c:#java... pathname. Renaming my install
> Steve
Yes it was exactly the source of my problem. I would have never thought
that # would cause such problems :) and my 3.2 is indeed in a folder
without any #.
Thank you.
Marcin
Previous Topic:Where is it stored whether a directory is 'derived'?
Next Topic:problem with CommonNavigator and undo/redo
Current Time: Tue Apr 16 07:51:10 GMT 2024
Powered by FUDForum. Page generated in 0.11871 seconds
