Home » Eclipse Projects » Eclipse Platform » How to remove ANT Configurations?
How to remove ANT Configurations? [message #322879] Fri, 30 November 2007 11:32 Go to next message
Over time I have run my ANT script with various options. Now, when I
double-click an ANT target (I'm in the Ant view) I get a dialog box allowing
me to select an ANT configuration. Now that I'm done debugging the script,
I would like to remove all these configurations so that I can simply
double-click and have the target run without the dialog box.
I cannot find any way to delete these ununsed configurations.
Link to appropriate doc will be appreciated.
Michael Giroux
Re: How to remove ANT Configurations? [message #322881 is a reply to message #322879] Fri, 30 November 2007 11:46 Go to previous messageGo to next message
Never mind. I found it:
run -> external tools -> open external tools dialog...
Michael
How to remove ANT Configurations? [message #1800728 is a reply to message #322879] Mon, 07 January 2019 07:57 Go to previous messageGo to next message
Hello, Michael Giroux,
Thanks for sharing these information but I don't clear these process so, please share full details.
Re: How to remove ANT Configurations? [message #1866042 is a reply to message #1800728] Mon, 20 May 2024 11:37 Go to previous messageGo to next message
and where is external tools?
Re: How to remove ANT Configurations? [message #1866045 is a reply to message #1866042] Mon, 20 May 2024 11:40 Go to previous messageGo to next message
and what to do in external dialog?
Re: How to remove ANT Configurations? [message #1866069 is a reply to message #1866045] Tue, 21 May 2024 04:08 Go to previous message
On the main menu is Run -> External Tools (at the bottom) -> External Tools Configurations... There's also a toolbar button like a run symbol with a little red toolkit for convenience. The dialog shows run configurations grouped and here you can create, delete, or edit such things.
Previous Topic:HTTP ERROR 500 org.apache.jasper.JasperException: PWC6349: Cannot find a java compiler for compilati
Next Topic:2024-06 required Java Version: Wiki vs. eclipse.ini
Current Time: Sat May 24 00:39:45 EDT 2025
Powered by FUDForum. Page generated in 0.03741 seconds
