STEM: problem building a project [message #32593] |
Mon, 23 July 2007 19:47 |
Originally posted by: araratjan.yahoo.com
Hi all,
I was finally able to populate all subfolders in the project with
appropriate scenior/graph/model/sequencer. However, when I try to run the
scenario, I got an error "The Scenario cannot be run becasue it does not
have a sequencer". Well, I did create a sequencer in the Sequencer folder.
Apparently, it will not associate the created sequencer with the Scenario.
Is there somthing I am not doing right?
Thanks.
Armen
Re: solved! [message #32697 is a reply to message #32662] |
Tue, 24 July 2007 15:57 |
The problem I was having was that I was dragging and dropping onto the
window, rather than onto the project icon/name. It is wokring now. May
also be another issue to incude in the documentation: to specify that the
items must be dragged and dropped onto the listing, not just anywehere on
the window.
Thanks!
Re: solved! [message #580660 is a reply to message #32662] |
the window.
Thanks!
FUDForum. Page generated in 0.03521 seconds
