Home » Modeling » TMF (Xtext) » Deadlock during injector initialization
Deadlock during injector initialization [message #1679046] |
Mon, 16 March 2015 12:50 |
Stephan Herrmann Messages: 1853 Registered: July 2009 |
I'm observing a deadlock during injector initialization, which seems to
be due to the synchronization in MyDslActivator.getInjector().
Here are the relevant parts of the two deadlocked threads:
Thread 1 triggered by the builder
Scopes$1$1.get() line: 64
InternalFactoryToProviderAdapter<T>.get(Errors, InternalContext, Dependency<?>, boolean) line: 40
InternalInjectorCreator$1.call(InternalContext) line: 204
InternalInjectorCreator$1.call(InternalContext) line: 198
InjectorImpl.callInContext(ContextualCallable<T>) line: 1024
InternalInjectorCreator.loadEagerSingletons(InjectorImpl, Stage, Errors) line: 198
InternalInjectorCreator.injectDynamically() line: 179
InternalInjectorCreator.build() line: 109
Guice.createInjector(Stage, Iterable<Module>) line: 95
Guice.createInjector(Iterable<Module>) line: 72
Guice.createInjector(Module...) line: 62
MyDslActivator(MyDslActivator).createInjector(String) line: 67
MyDslActivator.createInjector(String) line: 89
MyDslActivator.getInjector(String) line: 76
MyDslExecutableExtensionFactory.getInjector() line: 26
MyDslExecutableExtensionFactory(AbstractGuiceAwareExecutableExtensionFactory).create() line: 49
ConfigurationElement.createExecutableExtension(String) line: 262
ConfigurationElementHandle.createExecutableExtension(String) line: 55
ResourceServiceProviderDescriptor.get(URI, String) line: 39
ResourceServiceProviderRegistryImpl$InternalData.getServiceProvider(URI, String) line: 46
ResourceServiceProviderRegistryImpl.getResourceServiceProvider(URI, String) line: 108
ResourceServiceProviderRegistryImpl.getResourceServiceProvider(URI) line: 124
UriValidator.isValid(URI, IStorage) line: 27
Storage2UriMapperImpl.isValidUri(URI, IStorage) line: 233
Storage2UriMapperImpl.getUri(IStorage) line: 219
ToBeBuiltComputer.getUri(IStorage) line: 326
ToBeBuiltComputer.updateStorage(IProgressMonitor, ToBeBuilt, IStorage) line: 268
ToBeBuiltComputer$2.visit(IResource) line: 241
Resource$2.visit(IResourceProxy) line: 126
Resource$1.visitElement(ElementTree, IPathRequestor, Object) line: 85
ElementTreeIterator.doIteration(DataTreeNode, IElementContentVisitor) line: 82
ElementTreeIterator.doIteration(DataTreeNode, IElementContentVisitor) line: 86
ElementTreeIterator.iterate(IElementContentVisitor) line: 127
Project(Resource).accept(IResourceProxyVisitor, int, int) line: 95
Project(Resource).accept(IResourceProxyVisitor, int) line: 52
Project(Resource).accept(IResourceVisitor, int, int) line: 124
Project(Resource).accept(IResourceVisitor) line: 108
ToBeBuiltComputer.updateProject(IProject, IProgressMonitor) line: 236
ToBeBuiltComputer.updateProjectNewResourcesOnly(IProject, IProgressMonitor) line: 205
XtextBuilder.fullBuild(IProgressMonitor, boolean) line: 211
XtextBuilder.build(int, Map, IProgressMonitor) line: 89
Thread 2 triggered by initializing a view with injections
MyDslActivator.getInjector(String) line: 74
ElementSelectionConverter.initialize(Injector) line: 52
NativeMethodAccessorImpl.invoke0(Method, Object, Object[]) line: not available [native method]
NativeMethodAccessorImpl.invoke(Object, Object[]) line: 57
DelegatingMethodAccessorImpl.invoke(Object, Object[]) line: 43
Method.invoke(Object, Object...) line: 606
SingleMethodInjector$1.invoke(Object, Object...) line: 71
SingleMethodInjector.inject(Errors, InternalContext, Object) line: 90
MembersInjectorImpl<T>.injectMembers(T, Errors, InternalContext, boolean) line: 110
ConstructorInjector<T>.construct(Errors, InternalContext, Class<?>, boolean) line: 94
ConstructorBindingImpl$Factory<T>.get(Errors, InternalContext, Dependency<?>, boolean) line: 254
ProviderToInternalFactoryAdapter$1.call(InternalContext) line: 46
InjectorImpl.callInContext(ContextualCallable<T>) line: 1031
ProviderToInternalFactoryAdapter<T>.get() line: 40
Scopes$1$1.get() line: 65
SingleFieldInjector.inject(Errors, InternalContext, Object) line: 53
InjectorImpl$4$1.call(InternalContext) line: 978
InjectorImpl$4.get() line: 974
InjectorImpl.getInstance(Class<T>) line: 1013
GraphViewExecutableExtensionFactory(AbstractGuiceAwareExecutableExtensionFactory).create() line: 50
ViewDescriptor.createView() line: 63
Contention regards
- com.google.inject.internal.InternalInjectorCreator - owned by the view thread
- Collections$SynchronizedMap<K,V> - which is MyDslActivator.injectors - owned by the builder thread
Has anybody seen anything like this before?
The problem started to occur after adding just one more injected action to the view.
The action itself has the same set of injected fields as other actions do, none of which caused problems before. Perhaps the risk of deadlock has always been there?
Should the (generated) method getInjector() try to first acquire the lock on InternalInjectorCreator before taking its own lock?
Stephan
Current Time: Thu Apr 25 19:58:04 GMT 2024
Powered by FUDForum. Page generated in 0.03256 seconds
